Trying OTA upgrade from 35.3.1 to 35.5 on Orin NX and got these errors:
I followed the instructions here:
https://docs.nvidia.com/jetson/archives/r35.3.1/DeveloperGuide/text/SD/SoftwarePackagesAndTheUpdateMechanism.html#updating-from-the-nvidia-apt-server
So I edited the file and mentioned from 35.3 → 35.5.
…but I end up with this (the same if I run it again).
oliver@Jetson-Dev:~$ sudo apt dist-upgrade
Reading package lists... Done
Building dependency tree
Reading state information... Done
Calculating upgrade... Done
Get more security updates through Ubuntu Pro with 'esm-apps' enabled:
  libavformat58 libavfilter7 libswresample3 libzmq5 iperf3 libswresample-dev
  libpostproc55 libavutil-dev libavcodec-dev libavcodec58 libavutil56
  libswscale5 libopenexr24 libsdl2-2.0-0 libmysofa1 libiperf0 python3-scipy
Learn more about Ubuntu Pro at https://ubuntu.com/pro
0 to upgrade, 0 to newly install, 0 to remove and 0 not to upgrade.
5 not fully installed or removed.
After this operation, 0 B of additional disk space will be used.
Do you want to continue? [Y/n] y
Setting up nvidia-l4t-kernel (5.10.192-tegra-35.5.0-20240219203809) ...
Using the existing boot entry 'primary'
Warning: Cannot get compatible board name.
3767--0001--1--p3509-a02+p3767-0000-
Info. Active boot storage: nvme0n1
Info. Legacy mode: false
TNSPEC 3767-300-0001-N.2-1-1-p3509-a02+p3767-0000-
COMPATIBLE_SPEC 3767--0001--1--p3509-a02+p3767-0000-
TEGRA_LEGACY_UPDATE false
TEGRA_BOOT_STORAGE nvme0n1
TEGRA_EMMC_ONLY false
TEGRA_CHIPID 0x23
TEGRA_OTA_BOOT_DEVICE /dev/mtdblock0
TEGRA_OTA_GPT_DEVICE /dev/mtdblock0
Info: Write TegraPlatformCompatSpec with 3767--0001--1--p3509-a02+p3767-0000-.
Starting kernel post-install procedure.
Rootfs AB is not enabled.
ERROR. Procedure for A_kernel update FAILED.
Cannot install package. Exiting...
dpkg: error processing package nvidia-l4t-kernel (--configure):
 installed nvidia-l4t-kernel package post-installation script subprocess returned error exit status 1
dpkg: dependency problems prevent configuration of nvidia-l4t-kernel-headers:
 nvidia-l4t-kernel-headers depends on nvidia-l4t-kernel (= 5.10.192-tegra-35.5.0-20240219203809); however:
  Package nvidia-l4t-kernel is not configured yet.
dpkg: error processing package nvidia-l4t-kernel-headers (--configure):
 dependency problems - leaving unconfigured
dpkg: dependency problems prevent configuration of nvidia-l4t-jetson-io:
 nvidia-l4t-jetson-io depends on nvidia-l4t-kernel (>> 5.10.192-tegra-35.5-0); however:
 nvidia-l4t-jetson-io depends on nvidia-l4t-kernel (<< 5.10.192-tegra-35.6-0); however:
dpkg: error processing package nvidia-l4t-jetson-io (--configure):
No apport report written because the error message indicates it's a follow-up error from a previous failure.
lure.
     dpkg: dependency problems prevent configuration of nvidia-l4t-display-kernel:
 nvidia-l4t-display-kernel depends on nvidia-l4t-kernel (= 5.10.192-tegra-35.5.0-20240219203809); however:
dpkg: error processing package nvidia-l4t-display-kernel (--configure):
dpkg: dependency problems prevent configuration of nvidia-l4t-kernel-dtbs:
 nvidia-l4t-kernel-dtbs depends on nvidia-l4t-kernel (= 5.10.192-tegra-35.5.0-20240219203809); however:
dpkg: error processing package nvidia-l4t-kernel-dtbs (--configure):
No apport report written because MaxReports has already been reached
        Errors were encountered while processing:
 nvidia-l4t-kernel
E: Sub-process /usr/bin/dpkg returned an error code (1)
Is there a solution?
I’ve seen some commands to do weird stuff with the disk partitions,. mentioned in this solution:
So maybe I need something similar?
Here is my disk layout:
oliver@Jetson-Dev:~$ sudo parted /dev/nvme0n1 print
Model: FORESEE VP1000F128G (nvme)
Disk /dev/nvme0n1: 128GB
Sector size (logical/physical): 512B/512B
Partition Table: gpt
Disk Flags:
Number  Start   End     Size    File system  Name                       Flags
 2      20.5kB  67.1MB  67.1MB               A_kernel                   msftdata
 3      67.1MB  67.6MB  459kB                A_kernel-dtb               msftdata
 4      67.6MB  101MB   33.6MB               reserved_for_chain_A_user  msftdata
 5      101MB   168MB   67.1MB               B_kernel                   msftdata
 6      168MB   169MB   459kB                B_kernel-dtb               msftdata
 7      169MB   202MB   33.6MB               reserved_for_chain_B_user  msftdata
 8      202MB   286MB   83.9MB               recovery                   msftdata
 9      286MB   287MB   524kB                recovery-dtb               msftdata
10      287MB   601MB   315MB                RECROOTFS                  msftdata
11      601MB   668MB   67.1MB  fat32        esp                        boot, esp
12      668MB   752MB   83.9MB               recovery_alt               msftdata
13      752MB   753MB   524kB                recovery-dtb_alt           msftdata
14      753MB   820MB   67.1MB               esp_alt                    msftdata
 1      820MB   128GB   127GB   ext4         APP                        msftdata
Hi oviano,
Are you using the devkit or custom board for Orin NX?
Please share the result of the following command on your board.
$ cat /etc/nv_tegra_release
$ cat /etc/nv_boot_control.conf
This is a reComputer 401 board.
oliver@Jetson-Dev:~$ cat /etc/nv_tegra_release
# R35 (release), REVISION: 5.0, GCID: 35550185, BOARD: t186ref, EABI: aarch64, DATE: Tue Feb 20 04:46:31 UTC 2024
oliver@Jetson-Dev:~$ cat /etc/nv_boot_control.conf
TEGRA_CHIPID 0x23
It seems you are using the custom carrier board so that debian based OTA would not work for your board.
Please use the custom BSP package to perform the image-based OTA update.
Ok no problem.
