The module is Orin Nano 8GB, I flash my NVME SSD (which serves as the system for the custom board) with R35.5.0 (jetpack 5.1.3), the flash command is as follows
sudo BOARDID=3767 BOARDSKU=0003 ./tools/kernel_flash/l4t_initrd_flash.sh --no-flash --external-device nvme0n1p1 -c ./tools/kernel_flash/flash_l4t_external.xml p3509-a02+p3767-0000 external
sudo ./tools/kernel_flash/l4t_initrd_flash.sh --flash-only --external-device nvme0n1p1 --direct sdb -c ./tools/kernel_flash/flash_l4t_external.xml p3509-a02+p3767-0000 external
Everything seems to work fine, until I run apt upgrade. Some nvidia packages give errors
Setting up nvidia-l4t-kernel (5.10.192-tegra-35.5.0-20240423174505) ...
Using the existing boot entry 'primary'
Warning: Cannot get compatible board name.
3767--0003--1--p3509-a02+p3767-0000-
Info. Installing mtdblock.
Info. Active boot storage: nvme0n1
Info. Legacy mode: false
TNSPEC 3767-300-0003-M.2-1-0-p3509-a02+p3767-0000-
COMPATIBLE_SPEC 3767--0003--1--p3509-a02+p3767-0000-
TEGRA_LEGACY_UPDATE false
TEGRA_BOOT_STORAGE nvme0n1
TEGRA_EMMC_ONLY false
TEGRA_CHIPID 0x23
TEGRA_OTA_BOOT_DEVICE /dev/mtdblock0
TEGRA_OTA_GPT_DEVICE /dev/mtdblock0
Info: Write TegraPlatformCompatSpec with 3767--0003--1--p3509-a02+p3767-0000-.
Starting kernel post-install procedure.
Rootfs AB is not enabled.
ERROR. Procedure for A_kernel update FAILED.
Cannot install package. Exiting...
dpkg: error processing package nvidia-l4t-kernel (--configure):
installed nvidia-l4t-kernel package post-installation script subprocess returned error exit status 1
dpkg: dependency problems prevent configuration of nvidia-l4t-kernel-headers:
nvidia-l4t-kernel-headers depends on nvidia-l4t-kernel (= 5.10.192-tegra-35.5.0-20240423174505); however:
Package nvidia-l4t-kernel is not configured yet.
dpkg: error processing package nvidia-l4t-kernel-headers (--configure):
dependency problems - leaving unconfigured
dpkg: dependency problems prevent configuration of nvidia-l4t-display-kernel:
nvidia-l4t-display-kernel depends on nvidia-l4t-kernel (= 5.10.192-tegra-35.5.0-20240423174505); however:
dpkg: error processing package nvidia-l4t-display-kernel (--configure):
dpkg: dependency problems prevent configuration of nvidia-l4t-kernel-dtbs:
nvidia-l4t-kernel-dtbs depends on nvidia-l4t-kernel (= 5.10.192-tegra-35.5.0-20240423174505); however:
dpkg: error processing package nvidia-l4t-kernel-dtbs (--configure):
No apport report written because the error message indicates its a followup error from a previous failure.
No apport report written because MaxReports is reached already
Errors were encountered while processing:
nvidia-l4t-kernel
E: Sub-process /usr/bin/dpkg returned an error code (1)
I noticed an error.
Why is this error reported?
Please help me fix these problems.
