0.system info
Filesystem 1K-blocks Used Available Use% Mounted on
none 15497564 0 15497564 0% /dev
tmpfs 15634720 52 15634668 1% /dev/shm
tmpfs 3126944 26700 3100244 1% /run
tmpfs 5120 0 5120 0% /run/lock
tmpfs 15634720 0 15634720 0% /sys/fs/cgroup
/dev/nvme0n1p1 464293624 72689528 367949596 17% /
tmpfs 3126944 16 3126928 1% /run/user/124
tmpfs 3126944 0 3126944 0% /run/user/0
/etc/nv_boot_control.conf
TNSPEC 3701-500-0004-G.0-1-1-y-c8-agx-orin-351-
COMPATIBLE_SPEC 3701–0004–1–y-c8-agx-orin-351-
TEGRA_LEGACY_UPDATE false
TEGRA_BOOT_STORAGE nvme0n1
TEGRA_EMMC_ONLY false
TEGRA_CHIPID 0x23
TEGRA_OTA_BOOT_DEVICE /dev/mtdblock0
TEGRA_OTA_GPT_DEVICE /dev/mtdblock0
1.modify /etc/apt/sources.list.d/nvidia-l4t-apt-source.list
deb https://repo.download.nvidia.com/jetson/common r35.4 main
deb https://repo.download.nvidia.com/jetson/t234 r35.4 main
2.apt update
3.apt dist-update
Setting up nvidia-l4t-bootloader (35.4.1-20230801124926) …
Warning: Cannot get compatible board name.
Info. Active boot storage: nvme0n1
Info. Legacy mode: false
TEGRA_CHIPID 0x23
Info: Write TegraPlatformCompatSpec with 3701–0004–1–y-c8-agx-orin-351-.
Error: uuid of esp is not found.
ERROR. Mount active boot media’s esp failed.
Cannot install capsule package. Exiting…
dpkg: error processing package nvidia-l4t-bootloader (–configure):
installed nvidia-l4t-bootloader package post-installation script subprocess returned error exit status 1
Setting up nvidia-l4t-kernel (5.10.120-tegra-35.4.1-20230801124926) …
Using the existing boot entry ‘primary’
TEGRA_CHIPID 0x23
Starting kernel post-install procedure.
ERROR. Failed to get number of rootfs slots. Exiting…
dpkg: error processing package nvidia-l4t-kernel (–configure):
installed nvidia-l4t-kernel package post-installation script subprocess returned error exit status 1
dpkg: dependency problems prevent configuration of nvidia-l4t-kernel-headers:
nvidia-l4t-kernel-headers depends on nvidia-l4t-kernel (= 5.10.120-tegra-35.4.1-20230801124926); however:
Package nvidia-l4t-kernel is not configured yet.
dpkg: error processing package nvidia-l4t-kernel-headers (–configure):
dependency problems - leaving unconfigured
dpkg: dependency problems prevent configuration of nvidia-l4t-jetson-io:
nvidia-l4t-jetson-io depends on nvidia-l4t-kernel (>> 5.10.120-tegra-35.4-0); however:
nvidia-l4t-jetson-io depends on nvidia-l4t-kernel (<< 5.10.120-tegra-35.5-0); however:
dpkg: error processing package nvidia-l4t-jetson-io (–configure):
dpkg: dependency problems prevent configuration of nvidia-l4t-display-kernel:
nvidia-l4t-display-kernel depends on nvidia-l4t-kernel (= 5.10.120-tegra-35.4.1-20230801124926); however:
dpkg: error processing package nvidia-l4t-display-kernel (–configure):
No apport report written because the error message indicates its a followup error from a previous failure.
No apport report written because MaxReports is reached already
dpkg: dependency problems prevent configuration of nvidia-l4t-kernel-dtbs:
nvidia-l4t-kernel-dtbs depends on nvidia-l4t-kernel (= 5.10.120-tegra-35.4.1-20230801124926); however:
dpkg: error processing package nvidia-l4t-kernel-dtbs (–configure):
Errors were encountered while processing:
nvidia-l4t-kernel
E: Sub-process /usr/bin/dpkg returned an error code (1)
