Upgrade to Jetpack 5.1 failed
I tried upgrading two Orin AGX dev kits to Jetpack 5.1. The first one was ok (possibly because it was using JP 5.0.2). The second one (which was running 5.0.1) fails to upgrade:
Setting up nvidia-l4t-kernel (5.10.104-tegra-35.2.1-20230124153320) ...
Using the existing boot entry 'primary'
3701--0000--1--jetson-agx-orin-devkit-
Info. Active boot storage: mmcblk0
Info. Legacy mode: true
Starting kernel post-install procedure.
Starting legacy update procedure.
ERROR. Procedure for A_kernel-dtb update FAILED.
Cannot install package. Exiting...
dpkg: error processing package nvidia-l4t-kernel (--configure):
 installed nvidia-l4t-kernel package post-installation script subprocess returned error exit status 1
dpkg: dependency problems prevent configuration of nvidia-l4t-kernel-headers:
 nvidia-l4t-kernel-headers depends on nvidia-l4t-kernel (= 5.10.104-tegra-35.2.1-20230124153320); however:
  Package nvidia-l4t-kernel is not configured yet.
dpkg: error processing package nvidia-l4t-kernel-headers (--configure):
 dependency problems - leaving unconfigured
dpkg: dependency problems prevent configuration of nvidia-l4t-jetson-io:
 nvidia-l4t-jetson-io depends on nvidia-l4t-kernel (>> 5.10.104-tegra-35.2-0); however:
 nvidia-l4t-jetson-io depends on nvidia-l4t-kernel (<< 5.10.104-tegra-35.3-0); however:
dpkg: error processing package nvidia-l4t-jetson-io (--configure):
dpkg: dependency problems prevent configuration of nvidia-l4t-display-kernel:
 nvidia-l4t-display-kernel depends on nvidia-l4t-kernel (= 5.10.104-tegra-3No apport report written because the error message indicates its a followup error from a previous failure.
        No a
        No apport report written because MaxReports is reached already
dpkg: error processing package nvidia-l4t-display-kernel (--configure):
dpkg: dependency problems prevent configuration of nvidia-l4t-kernel-dtbs:
 nvidia-l4t-kernel-dtbs depends on nvidia-l4t-kernel (= 5.10.104-tegra-35.2.1-20230124153320); however:
dpkg: error processing package nvidia-l4t-kernel-dtbs (--configure):
Errors were encountered while processing:
 nvidia-l4t-kernel
E: Sub-process /usr/bin/dpkg returned an error code (1)
To upgrade I changed /etc/apt/sources.list.d/nvidia-l4t-apt-source.list to point to r35.2 and then sudo apt update and sudo apt dist-upgrade.
Hi sandberg,
Have you tried to upgrade from 5.0.1 to 5.0.2 first?
Or you could try to remove some packages before upgrade:
$ sudo apt purge nvidia-l4t-kernel nvidia-l4t-kernel-headers nvidia-l4t-jetson-io nvidia-l4t-display-kernel nvidia-l4t-kernel-dtbs
I found this JetPack 5.1 with Jetson Linux 35.2.1 Released - #3 by suhash which helped me out.
Running this fixed my issue:
sudo parted /dev/mmcblk0 -s rm 4
sudo parted /dev/mmcblk0 -s resizepart 3 67.9MB
sudo parted /dev/mmcblk0 mkpart -s A_reserved_on_user 67.9MB 101MB
