While upgrading to L35.4 from L35.3 using apt upgrade, I got a following message from package nvidia-l4t-bootloader. What should I do?
Setting up nvidia-l4t-bootloader (35.4.1-20230801124926) ...
Warning: Not all of the space available to /dev/nvme0n1 appears to be used, you can fix the GPT to use all of the space (an extra 6 blocks) or continue
with the current setting?
Fix/Ignore? Ignore
Partition number?
Partition number? 1
Partition name? [APP]?
Fix/Ignore? Ignore
Partition number? 1
Fix/Ignore? Fix
Partition number?
Partition number?
Partition number?
Partition number?
[1]+ Stopped apt upgrade
What does it mean, and what I suppose to answer here?
Then, i change l34.4 to l34.5 in the sources list and run:
sudo apt update
sudo apt upgrade
I was forced to stop upgrade process because I have no idea how I should answer to questions about disk space and Partition number. Then, i run sudo dpkg --configure -a to finish installation
dpkg --configure -a output:
Summary
# sudo dpkg --configure -a
Setting up libdbusmenu-gtk3-4:arm64 (16.04.1+18.10.20180917-0ubuntu6) ...
Setting up nvidia-l4t-vulkan-sc-sdk (35.4.1-20230801124926) ...
Setting up nvidia-l4t-nvfancontrol (35.4.1-20230801124926) ...
Setting up nvidia-l4t-x11 (35.4.1-20230801124926) ...
Setting up gir1.2-gtk-3.0:arm64 (3.24.20-0ubuntu1.1) ...
Setting up libappindicator3-1 (12.10.1+20.04.20200408.1-0ubuntu1) ...
Setting up python3-pil:arm64 (7.0.0-4ubuntu0.7) ...
Setting up gir1.2-appindicator3-0.1 (12.10.1+20.04.20200408.1-0ubuntu1) ...
3767--0005--1--jetson-orin-nano-devkit-
Info. Active boot storage: nvme0n1
Info. Legacy mode: false
TNSPEC 3767-300-0005-K.2-1-1-jetson-orin-nano-devkit-
COMPATIBLE_SPEC 3767--0005--1--jetson-orin-nano-devkit-
TEGRA_LEGACY_UPDATE false
TEGRA_BOOT_STORAGE nvme0n1
TEGRA_EMMC_ONLY false
TEGRA_CHIPID 0x23
TEGRA_OTA_BOOT_DEVICE /dev/mtdblock0
TEGRA_OTA_GPT_DEVICE /dev/mtdblock0
Info: Write TegraPlatformCompatSpec with 3767--0005--1--jetson-orin-nano-devkit-.
INFO. Dump slots info:
Current version: 35.3.1
Capsule update status: 0
Current bootloader slot: A
Active bootloader slot: A
num_slots: 2
slot: 0, status: normal
slot: 1, status: normal
INFO. Dump nv_boot_control.conf:
TEGRA_CHIPID 0x23
Starting bootloader post-install procedure.
INFO. Copy capsule payload: TEGRA_BL_3767.Cap.
INFO. Copy capsule payload to /opt/nvidia/esp/EFI/UpdateCapsule/ and l4tlauncher to /opt/nvidia/esp/EFI/BOOT/ done.
INFO. Set capsule UEFI variable /sys/firmware/efi/efivars/OsIndications-8be4df61-93ca-11d2-aa0d-00e098032b8c done.
Updating extlinux.conf...
Root device is set in the extlinux.conf
Reboot the target system for updates to take effect.
Setting up libtcl8.6:arm64 (8.6.10+dfsg-1) ...
Setting up python3-numpy (1:1.17.4-5ubuntu3.1) ...
Setting up nvidia-l4t-nvsci (35.4.1-20230801124926) ...
Setting up nvidia-l4t-vulkan-sc (35.4.1-20230801124926) ...
Setting up nvidia-l4t-wayland (35.4.1-20230801124926) ...
Setting up python3-dateutil (2.7.3-3ubuntu1) ...
Setting up libgtk2.0-common (2.24.32-4ubuntu4) ...
Setting up nvidia-l4t-xusb-firmware (35.4.1-20230801124926) ...
Setting up nvidia-l4t-cuda (35.4.1-20230801124926) ...
Setting up nvidia-l4t-optee (35.4.1-20230801124926) ...
Setting up python-matplotlib-data (3.1.2-1ubuntu4) ...
Setting up python3-distro-info (0.23ubuntu1.1) ...
Setting up nvidia-l4t-kernel (5.10.120-tegra-35.4.1-20230801124926) ...
Using the existing boot entry 'primary'
TEGRA_CHIPID 0x23
Starting kernel post-install procedure.
Rootfs AB is not enabled.
Reboot the target system for changes to take effect.
Setting up nvidia-l4t-nvpmodel-gui-tools (35.4.1-20230801124926) ...
Setting up python3-matplotlib (3.1.2-1ubuntu4) ...
Setting up nvidia-l4t-openwfd (35.4.1-20230801124926) ...
Setting up libgtk2.0-0:arm64 (2.24.32-4ubuntu4) ...
Setting up nvidia-l4t-kernel-headers (5.10.120-tegra-35.4.1-20230801124926) ...
Setting up libtk8.6:arm64 (8.6.10-1) ...
Setting up nvidia-l4t-jetson-io (35.4.1-20230801124926) ...
Setting up libopencv (4.5.4-8-g3e4c170df4) ...
Setting up nvidia-l4t-3d-core (35.4.1-20230801124926) ...
Setting up nvidia-l4t-display-kernel (5.10.120-tegra-35.4.1-20230801124926) ...
depmod: WARNING: could not open modules.order at /lib/modules/5.10.104-tegra: No such file or directory
depmod: WARNING: could not open modules.builtin at /lib/modules/5.10.104-tegra: No such file or directory
Setting up nvidia-l4t-initrd (35.4.1-20230801124926) ...
Setting up nvidia-l4t-multimedia (35.4.1-20230801124926) ...
Setting up nvidia-l4t-kernel-dtbs (5.10.120-tegra-35.4.1-20230801124926) ...
Setting up nvidia-l4t-pva (35.4.1-20230801124926) ...
Setting up libgail18:arm64 (2.24.32-4ubuntu4) ...
Setting up libgtk2.0-bin (2.24.32-4ubuntu4) ...
Setting up nvidia-l4t-gbm (35.4.1-20230801124926) ...
Setting up tk8.6-blt2.5 (2.5.3+dfsg-4) ...
Setting up libgail-common:arm64 (2.24.32-4ubuntu4) ...
Setting up nvidia-l4t-vulkan-sc-samples (35.4.1-20230801124926) ...
Setting up nvidia-l4t-camera (35.4.1-20230801124926) ...
Setting up blt (2.5.3+dfsg-4) ...
Setting up nvidia-l4t-gstreamer (35.4.1-20230801124926) ...
Setting up python3-tk:arm64 (3.8.10-0ubuntu1~20.04) ...
Setting up nvidia-l4t-weston (35.4.1-20230801124926) ...
Setting up nvidia-l4t-graphics-demos (35.4.1-20230801124926) ...
Setting up nvidia-l4t-jetsonpower-gui-tools (35.4.1-20230801124926) ...
Processing triggers for libc-bin (2.31-0ubuntu9.9) ...
Processing triggers for man-db (2.9.1-1) ...
Processing triggers for fontconfig (2.13.1-2ubuntu3) ...
Processing triggers for nvidia-l4t-kernel (5.10.120-tegra-35.4.1-20230801124926) ...
An finally, my system is unbootable: serial.log (82.7 KB)
space (an extra 6 blocks) or continue with the current setting?
Fix/Ignore? Ignore
Partition number?
Partition number?
Partition number?
Partition number?
Partition number?
Partition number? 1
I don’t know if ‘1’ was the right choice and I don’t know what ‘APP’ is referring to. Can someone please let me know what I was suppose to select? Should I just press enter now?
Fix/Ignore? Fix
Fix
Partition number? 1
1
Warning: Cannot get compatible board name.
3767-000-0000--1--p3509-a02+p3767-0000-
and finally, after all of that:
dpkg: dependency problems prevent configuration of nvidia-l4t-kernel-headers:
nvidia-l4t-kernel-headers depends on nvidia-l4t-kernel (= 5.10.120-tegra-35.4.1-20230801124926); however:
Package nvidia-l4t-kernel is not configured yet.
dpkg: error processing package nvidia-l4t-kernel-headers (--configure):
dependency problems - leaving unconfigured
Setting up nvidia-cuda-dev (5.1.2-b104) ...
No apport report written because the error message indicates its a followup error from a previous failure.
dpkg: dependency problems prevent configuration of nvidia-l4t-jetson-io:
nvidia-l4t-jetson-io depends on nvidia-l4t-kernel (>> 5.10.120-tegra-35.4-0); however:
nvidia-l4t-jetson-io depends on nvidia-l4t-kernel (<< 5.10.120-tegra-35.5-0); however:
dpkg: error processing package nvidia-l4t-jetson-io (--configure):
Setting up samba-libs:arm64 (2:4.15.13+dfsg-0ubuntu0.20.04.4) ...
Setting up libpoppler97:arm64 (0.86.1-0ubuntu1.3) ...
Setting up ghostscript (9.50~dfsg-5ubuntu4.9) ...
Setting up software-properties-common (0.99.9.12) ...
Setting up libnvvpi2 (2.3.9) ...
pva_allow and/or /etc/pva/allow.d missing! Falling back to force-overwrite of system allowlist
Setting up libtiff-dev:arm64 (4.1.0+git191117-2ubuntu0.20.04.9) ...
dpkg: dependency problems prevent configuration of nvidia-l4t-display-kernel:
nvidia-l4t-display-kernel depends on nvidia-l4t-kernel (= 5.10.120-tegra-35.4.1-20230801124926); however:
dpkg: error processing package nvidia-l4t-display-kernel (--configure):
Setting up nvidia-l4t-initrd (No apport report written because MaxReports is reached already
Setting up vpi2-demos (2.3.9) ...
dpkg: dependency problems prevent configuration of nvidia-l4t-kernel-dtbs:
nvidia-l4t-kernel-dtbs depends on nvidia-l4t-kernel (= 5.10.120-tegra-35.4.1-20230801124926); however:
dpkg: error processing package nvidia-l4t-kernel-dtbs (--configure):
Setting up No apport report written because MaxReports is reached already
libsmbclient:arm64 (2:4.15.13+dfsg-0ubuntu0.20.04.4) ...
Setting up poppler-utils (0.86.1-0ubuntu1.3) ...
Setting up python3.9-vpi2 (2.3.9) ...
Setting up libpoppler-cpp0v5:arm64 (0.86.1-0ubuntu1.3) ...
Setting up libpoppler-glib8:arm64 (0.86.1-0ubuntu1.3) ...
Setting up vpi2-dev (2.3.9) ...
Setting up software-properties-gtk (0.99.9.12) ...
Setting up ghostscript-x (9.50~dfsg-5ubuntu4.9) ...
Setting up nvidia-l4t-jetson-multimedia-api (35.4.1-20230801124926) ...
Setting up python3.8-vpi2 (2.3.9) ...
Setting up vpi2-samples (2.3.9) ...
Setting up nvidia-vpi (5.1.2-b104) ...
Setting up nvidia-jetpack-runtime (5.1.2-b104) ...
Setting up nvidia-vpi-dev (5.1.2-b104) ...
Setting up nvidia-jetpack-dev (5.1.2-b104) ...
Setting up nvidia-jetpack (5.1.2-b104) ...
Processing triggers for shared-mime-info (1.15-1) ...
Processing triggers for desktop-file-utils (0.24-1ubuntu3) ...
Processing triggers for mime-support (3.64ubuntu1) ...
Processing triggers for hicolor-icon-theme (0.17-2) ...
Processing triggers for gnome-menus (3.36.0-1ubuntu1) ...
Processing triggers for libglib2.0-0:arm64 (2.64.6-1~ubuntu20.04.6) ...
Processing triggers for dbus (1.12.16-2ubuntu2.3) ...
Errors were encountered while processing:
nvidia-l4t-kernel
E: Sub-process /usr/bin/dpkg returned an error code (1)
W: Operation was interrupted before it could finish
I attempt to just rerun dist-upgrade again with similar errors.
$ sudo apt dist-upgrade
Reading package lists... Done
Building dependency tree
Reading state information... Done
Calculating upgrade... Done
The following packages were automatically installed and are no longer required:
cmake-data cupva-2.0-l4t gir1.2-goa-1.0 libexif-dev libfwupdplugin1 libgdcm-dev libgdcm3.0 libgl2ps1.4
libgphoto2-dev libhdf5-openmpi-103 libilmbase-dev libjsoncpp1 libnetcdf-c++4 libopencv-calib3d4.2
libopencv-contrib4.2 libopencv-dnn4.2 libopencv-features2d4.2 libopencv-flann4.2 libopencv-highgui4.2
libopencv-imgcodecs4.2 libopencv-imgproc4.2 libopencv-ml4.2 libopencv-objdetect4.2 libopencv-photo4.2
libopencv-shape4.2 libopencv-stitching4.2 libopencv-superres4.2 libopencv-video4.2 libopencv-videoio4.2
libopencv-videostab4.2 libopencv-viz4.2 libopencv4.2-java libopencv4.2-jni libopenexr-dev libpaps0 libpcaudio0
librhash0 libsocket++1 libsonic0 libvtk6.3 libxmlb1 nsight-systems-2022.5.2 paps
Use 'sudo apt autoremove' to remove them.
Get more security updates through Ubuntu Pro with 'esm-apps' enabled:
vlc-bin libavresample-dev vlc-plugin-video-output libavformat58
libpostproc-dev libavfilter7 libpython3.9-minimal liburiparser1
vlc-plugin-samba libswresample3 vlc-plugin-qt libopenexr-dev
libpython3.9-stdlib libzmq5 python2.7-minimal libhdf5-103 vlc-plugin-skins2
vlc-plugin-visualization vlc-l10n libpython2.7 python2.7 libavformat-dev
python3.9 vlc-plugin-notify libvlc5 libhdf5-dev libsdl2-dev
libswresample-dev libpostproc55 libvlccore9 libvlc-bin libavutil-dev
libavcodec-dev hdf5-helpers python3.9-minimal libhdf5-cpp-103 libavcodec58
libjs-jquery-ui vlc libavutil56 vlc-data libswscale5 libopenexr24
libsdl2-2.0-0 libmysofa1 vlc-plugin-video-splitter libpython2.7-minimal
libhdf5-openmpi-103 libswscale-dev vlc-plugin-base libpython2.7-stdlib
python3-scipy libavresample4
Learn more about Ubuntu Pro at https://ubuntu.com/pro
# You can verify the status of security fixes using the `pro fix` command.
# E.g., a recent Ruby vulnerability can be checked with: `pro fix USN-6219-1`
# For more detail see: https://ubuntu.com/security/notices/USN-6219-1
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
5 not fully installed or removed.
After this operation, 0 B of additional disk space will be used.
Do you want to continue? [Y/n]
TNSPEC 3767-RC1-0000-B.6-1-1-p3509-a02+p3767-0000-
COMPATIBLE_SPEC 3767-000-0000--1--p3509-a02+p3767-0000-
TEGRA_CHIPID 0x23
Info: Write TegraPlatformCompatSpec with 3767-000-0000--1--p3509-a02+p3767-0000-.
ERROR. Procedure for A_kernel update FAILED.
Cannot install package. Exiting...
dpkg: error processing package nvidia-l4t-kernel (--configure):
installed nvidia-l4t-kernel package post-installation script subprocess returned error exit status 1
No apport
nvidia-l4t-kernel
If I don’t have a choice, that will be the route I take. While it’s not /hard/ it is quite time-consuming considering the amount of custom software I have on the system. I was hoping that there would be a fix. Thank you!
