Jetson Orin NX Industrial J4012 apt upgrade problem
Hi, I try to do sudo apt upgrade, bur console return me:
Reading package lists... Done
Building dependency tree... Done
Reading state information... Done
Calculating upgrade... Done
Get more security updates through Ubuntu Pro with 'esm-apps' enabled:
  python2.7-minimal libopencv-videoio4.5d libzvbi-common liburiparser1
  libopencv-objdetect4.5d libopencv-videoio-dev libopencv-superres4.5d
  libopencv-objdetect-dev libopencv-contrib4.5d libopencv-superres-dev
  libopencv-contrib-dev libzbar0 libheif1 libopencv-imgcodecs4.5d
  libopencv-imgcodecs-dev libiperf0 libjs-jquery-ui libopenexr-dev libcjson1
  libopencv-video4.5d libopencv-shape4.5d libopencv-video-dev libopenexr25
  libopencv-shape-dev python3-scipy libpostproc55 libopencv-highgui4.5d
  libopencv-core4.5d libopencv-stitching4.5d libopencv-highgui-dev
  libopencv-core-dev libswscale-dev libopencv-stitching-dev libavcodec58
  libgstreamer-plugins-bad1.0-0 iperf3 libpython2.7 libavutil56 libswscale5
  libopencv-viz4.5d libavutil-dev libopencv-viz-dev libopencv-features2d4.5d
  libopencv-dev gir1.2-gst-plugins-bad-1.0 libopencv-features2d-dev
  libswresample3 libopencv-dnn4.5d libopencv-dnn-dev libopencv-ml4.5d
  libavformat58 libzvbi0 gstreamer1.0-plugins-bad libopencv-ml-dev
  libopencv-calib3d4.5d libopencv-flann4.5d libgstreamer-opencv1.0-0
  libopencv-calib3d-dev libopencv-videostab4.5d libopencv-imgproc4.5d
  libopencv-flann-dev python2.7 libavformat-dev libopencv-videostab-dev
  libavcodec-dev libopencv-imgproc-dev libde265-0 libpython2.7-minimal
  libpmix2 libopencv-photo4.5d libpython2.7-stdlib libswresample-dev
  libopencv-photo-dev libgstreamer-plugins-bad1.0-dev libavfilter7
Learn more about Ubuntu Pro at https://ubuntu.com/pro
The following packages have been kept back:
  libopencv-dev
0 upgraded, 0 newly installed, 0 to remove and 1 not upgraded.
7 not fully installed or removed.
After this operation, 0 B of additional disk space will be used.
Do you want to continue? [Y/n] Y
Setting up nvidia-l4t-kernel (5.15.148-tegra-36.4.4-20250616085344) ...
Using the existing boot entry 'primary'
Warning: Cannot get compatible board name.
3767-000-0000--1--recomputer-orin-j401-
TNSPEC 3767-300-0000-K.1-1-1-recomputer-orin-j401-
COMPATIBLE_SPEC 3767-000-0000--1--recomputer-orin-j401-
TEGRA_BOOT_STORAGE nvme0n1
TEGRA_CHIPID 0x23
TEGRA_OTA_BOOT_DEVICE /dev/mtdblock0
TEGRA_OTA_GPT_DEVICE /dev/mtdblock0
Info: Write TegraPlatformCompatSpec with 3767-000-0000--1--recomputer-orin-j401-.
Info: The esp is already mounted to /boot/efi.
Starting kernel post-install procedure.
Rootfs AB is not enabled.
ERROR. Procedure for A_kernel update FAILED.
Cannot install package. Exiting...
dpkg: error processing package nvidia-l4t-kernel (--configure):
 installed nvidia-l4t-kernel package post-installation script subprocess returned error exit status 1
dpkg: dependency problems prevent configuration of nvidia-l4t-kernel-headers:
 nvidia-l4t-kernel-headers depends on nvidia-l4t-kernel (= 5.15.148-tegra-36.4.4-20250616085344); however:
  Package nvidia-l4t-kernel is not configured yet.
dpkg: error processing package nvidia-l4t-kernel-headers (--configure):
 dependency problems - leaving unconfigured
No apport report written because the error message indicates its a followup error from a previous failure.
       No apport report written because MaxReports is reached already
                                                  dpkg: dependency problems prevent configuration of nvidia-l4t-jetson-io:
 nvidia-l4t-jetson-io depends on nvidia-l4t-kernel (>> 5.15.148-tegra-36.4-0); however:
 nvidia-l4t-jetson-io depends on nvidia-l4t-kernel (<< 5.15.148-tegra-36.5-0); however:
dpkg: error processing package nvidia-l4t-jetson-io (--configure):
dpkg: dependency problems prevent configuration of nvidia-l4t-kernel-oot-modules:
 nvidia-l4t-kernel-oot-modules depends on nvidia-l4t-kernel (= 5.15.148-tegra-36.4.4-20250616085344); however:
dpkg: error processing package nvidia-l4t-kernel-oot-modules (--configure):
dpkg: dependency problems prevent configuration of nvidia-l4t-display-kernel:
 nvidia-l4t-display-kernel depends on nvidia-l4t-kernel (= 5.15.148-tegra-36.4.4-20250616085344); however:
dpkg: error processing package nvidia-l4t-display-kernel (--configure):
dpkg: dependency problems prevent configuration of nvidia-l4t-kernel-oot-headers:
 nvidia-l4t-kernel-oot-headers depends on nvidia-l4t-kernel (= 5.15.148-tegra-36.4.4-20250616085344); however:
dpkg: error processing package nvidia-l4t-kernel-oot-headers (--configure):
dpkg: dependency problems prevent configuration of nvidia-l4t-kernel-dtbs:
 nvidia-l4t-kernel-dtbs depends on nvidia-l4t-kernel (= 5.15.148-tegra-36.4.4-20250616085344); however:
dpkg: error processing package nvidia-l4t-kernel-dtbs (--configure):
Processing triggers for nvidia-l4t-initrd (36.4.4-20250616085344) ...
Include /etc/nv-update-initrd/list.d/binlist
Include /etc/nv-update-initrd/list.d/modules
nv-update-initrd: Updating /boot/initrd from /etc/nv-update-initrd/list.d for kernel version 5.15.148-tegra..
Add /usr/sbin/nvluks-srv-app
Add /lib/modules/5.15.148-tegra/updates/drivers/net/ethernet/nvidia/nvethernet/nvethernet.ko
Add /lib/modules/5.15.148-tegra/updates/drivers/nvpps/nvpps.ko
Add /lib/modules/5.15.148-tegra/updates/drivers/net/ethernet/realtek/r8126/r8126.ko
Add /lib/modules/5.15.148-tegra/updates/drivers/net/ethernet/realtek/r8168/r8168.ko
Add /lib/modules/5.15.148-tegra/modules*
Add /lib/modules/5.15.148-tegra/kernel/drivers/nvme/host/nvme.ko
Add /lib/modules/5.15.148-tegra/kernel/drivers/nvme/host/nvme-core.ko
Add /lib/modules/5.15.148-tegra/kernel/drivers/thermal/tegra/tegra-bpmp-thermal.ko
Add /lib/modules/5.15.148-tegra/kernel/drivers/pwm/pwm-tegra.ko
Add /lib/modules/5.15.148-tegra/kernel/drivers/hwmon/pwm-fan.ko
Add /lib/modules/5.15.148-tegra/kernel/drivers/pci/controller/dwc/pcie-tegra194.ko
Add /lib/modules/5.15.148-tegra/kernel/drivers/phy/tegra/phy-tegra194-p2u.ko
Add /lib/modules/5.15.148-tegra/kernel/drivers/usb/gadget/udc/tegra-xudc.ko
Add /lib/modules/5.15.148-tegra/kernel/drivers/usb/typec/ucsi/typec_ucsi.ko
Add /lib/modules/5.15.148-tegra/kernel/drivers/usb/typec/ucsi/ucsi_ccg.ko
Add /lib/modules/5.15.148-tegra/kernel/drivers/usb/typec/typec.ko
Updating modprobe.d configuration directories for modprobe..
Add config /etc/modprobe.d/alsa-base.conf
Add config /etc/modprobe.d/bcmdhd.conf
Add config /etc/modprobe.d/blacklist-ath_pci.conf
Add config /etc/modprobe.d/blacklist.conf
Add config /etc/modprobe.d/blacklist-firewire.conf
Add config /etc/modprobe.d/blacklist-framebuffer.conf
Add config /etc/modprobe.d/blacklist-modem.conf
Add config-link /etc/modprobe.d/blacklist-oss.conf
Add config /etc/modprobe.d/blacklist-rare-network.conf
Add config /etc/modprobe.d/denylist-nouveau.conf
Add config /etc/modprobe.d/denylist-oot-modules-audio.conf
Add config /etc/modprobe.d/denylist-ramoops.conf
Add config /etc/modprobe.d/denylist-tegra-safety.conf
Add config /etc/modprobe.d/denylist-tpm-ftpm-tee.conf
Add config /etc/modprobe.d/iwlwifi.conf
Add config /etc/modprobe.d/nvgpu.conf
Add config /etc/modprobe.d/nvidia-display.conf
Add config /etc/modprobe.d/tegra-udrm.conf
Add config /lib/modprobe.d/aliases.conf
Add config /lib/modprobe.d/fbdev-blacklist.conf
Add config /lib/modprobe.d/systemd.conf
Cleaning up the temporary directory for updating the initrd..
Errors were encountered while processing:
 nvidia-l4t-kernel
E: Sub-process /usr/bin/dpkg returned an error code (1)
What is wrong wth my setup?
When I execute:
 dpkg -l | grep nvidia-l4t-core
uname -r
I receive:
ii  nvidia-l4t-core                            36.4.4-20250616085344                       arm64        NVIDIA Core Package
5.15.148-tegra
Please refer to below topics
Since you are using a custom board, please hold mentioned packages.
I execute commands from: Jetson/L4T/r36.4.x patches - eLinux.org
Moreover, I execute:
sudo apt autoremove
sudo apt clean
sudo apt autoclean
But problem still exist:
$ sudo apt-mark hold nvidia-l4t-display-kernel nvidia-l4t-kernel nvidia-l4t-kernel-dtbs nvidia-l4t-kernel-headers nvidia-l4t-kernel-oot-headers nvidia-l4t-kernel-oot-modules
nvidia-l4t-display-kernel was already set on hold.
nvidia-l4t-kernel was already set on hold.
nvidia-l4t-kernel-dtbs was already set on hold.
nvidia-l4t-kernel-headers was already set on hold.
nvidia-l4t-kernel-oot-headers was already set on hold.
nvidia-l4t-kernel-oot-modules was already set on hold.
$ sudo apt-mark hold nvidia-l4t-kernel
Then after sudo apt upgrade:
  libopencv-dev
TEGRA_CHIPID 0x23
dpkg: errorNo apport report written because MaxReports is reached already
 nvidia-l4t-kernel
Some questions to confirm:
  • Why do you want to do the apt upgrade?
  • Is apt update meet your requirement?
Since sudo apt upgrade is our ota update methods, it might replace your some packages and make some problem.
For more information, please refer below:
DavidDDD, thank You for response.
I have this problem since last flash.
Each apt install command (for example sudo apt install htop last longer than usual, because after each update/install action, jetson try install nvidia-l4t-kernel too, and ofc stuck on this. It is not important problem, but I still dont know why it not working. I add files to hold, and working with clean and autoremove, but problem still exist.
Why it is important for me? Because each apt install/update command formally fails, so my CI/CD pipelines are failed too (because apt return non-zero code).
One more question to confirm:
What is your JP version?
Please execute below for us to review.
cat /etc/nv_tegra_release
Do you try apt update/install after you run apt-mark hold
