Unable to install jetpack on Orin devkit p3710
i have tried working with this guideline:
https://docs.nvidia.com/jetson/archives/r35.1/DeveloperGuide/text/SD/SoftwarePackagesAndTheUpdateMechanism.html#updating-a-jetson-device
this is what i am getting:
nvidia@tegra-ubuntu:~$ cat /etc/apt/sources.list.d/nvidia-l4t-apt-source.list
deb https://repo.download.nvidia.com/jetson/common r35.1 main
deb https://repo.download.nvidia.com/jetson/t234 r35.1 main
the log from the update:
nvidia@tegra-ubuntu:~$ sudo apt update
Get:1 https://repo.download.nvidia.com/jetson/common r35.1 InRelease [2555 B]
Get:2 https://repo.download.nvidia.com/jetson/t234 r35.1 InRelease [2550 B]
Err:1 https://repo.download.nvidia.com/jetson/common r35.1 InRelease
The following signatures couldn’t be verified because the public key is not available: NO_PUBKEY 0D296FFB880FB004
Hit:3 Index of /ubuntu-ports focal InRelease
Hit:4 Index of /ubuntu-ports focal-updates InRelease
Err:2 https://repo.download.nvidia.com/jetson/t234 r35.1 InRelease
Hit:5 Index of /ubuntu-ports focal-security InRelease
Reading package lists… Done
W: GPG error: https://repo.download.nvidia.com/jetson/common r35.1 InRelease: The following signatures couldn’t be verified because the public key is not available: NO_PUBKEY 0D296FFB880FB004
E: The repository ‘https://repo.download.nvidia.com/jetson/common r35.1 InRelease’ is not signed.
N: Updating from such a repository can’t be done securely, and is therefore disabled by default.
N: See apt-secure(8) manpage for repository creation and user configuration details.
W: GPG error: https://repo.download.nvidia.com/jetson/t234 r35.1 InRelease: The following signatures couldn’t be verified because the public key is not available: NO_PUBKEY 0D296FFB880FB004
E: The repository ‘https://repo.download.nvidia.com/jetson/t234 r35.1 InRelease’ is not signed.
W: Target Packages (main/binary-arm64/Packages) is configured multiple times in /etc/apt/sources.list:14 and /etc/apt/sources.list.d/nvidia-l4t-apt-source.list:1
W: Target Packages (main/binary-all/Packages) is configured multiple times in /etc/apt/sources.list:14 and /etc/apt/sources.list.d/nvidia-l4t-apt-source.list:1
W: Target Translations (main/i18n/Translation-en) is configured multiple times in /etc/apt/sources.list:14 and /etc/apt/sources.list.d/nvidia-l4t-apt-source.list:1
W: Target DEP-11 (main/dep11/Components-arm64.yml) is configured multiple times in /etc/apt/sources.list:14 and /etc/apt/sources.list.d/nvidia-l4t-apt-source.list:1
W: Target DEP-11 (main/dep11/Components-all.yml) is configured multiple times in /etc/apt/sources.list:14 and /etc/apt/sources.list.d/nvidia-l4t-apt-source.list:1
W: Target DEP-11-icons-small (main/dep11/icons-48x48.tar) is configured multiple times in /etc/apt/sources.list:14 and /etc/apt/sources.list.d/nvidia-l4t-apt-source.list:1
W: Target DEP-11-icons (main/dep11/icons-64x64.tar) is configured multiple times in /etc/apt/sources.list:14 and /etc/apt/sources.list.d/nvidia-l4t-apt-source.list:1
W: Target Packages (main/binary-arm64/Packages) is configured multiple times in /etc/apt/sources.list:15 and /etc/apt/sources.list.d/nvidia-l4t-apt-source.list:2
W: Target Packages (main/binary-all/Packages) is configured multiple times in /etc/apt/sources.list:15 and /etc/apt/sources.list.d/nvidia-l4t-apt-source.list:2
W: Target Translations (main/i18n/Translation-en) is configured multiple times in /etc/apt/sources.list:15 and /etc/apt/sources.list.d/nvidia-l4t-apt-source.list:2
W: Target DEP-11 (main/dep11/Components-arm64.yml) is configured multiple times in /etc/apt/sources.list:15 and /etc/apt/sources.list.d/nvidia-l4t-apt-source.list:2
W: Target DEP-11 (main/dep11/Components-all.yml) is configured multiple times in /etc/apt/sources.list:15 and /etc/apt/sources.list.d/nvidia-l4t-apt-source.list:2
W: Target DEP-11-icons-small (main/dep11/icons-48x48.tar) is configured multiple times in /etc/apt/sources.list:15 and /etc/apt/sources.list.d/nvidia-l4t-apt-source.list:2
W: Target DEP-11-icons (main/dep11/icons-64x64.tar) is configured multiple times in /etc/apt/sources.list:15 and /etc/apt/sources.list.d/nvidia-l4t-apt-source.list:2
nvidia@tegra-ubuntu:~$ sudo apt install nvidia-jetpack
Building dependency tree
Reading state information… Done
E: Unable to locate package nvidia-jetpack
Any idea what is the issue?
Regards,
Liron
Hi liron.g,
What is your current Jetpack version in use?
Please run the following command on the board to check
$cat /etc/nv_tegra_release
Do you make sure that your board can access network?
Or try to reboot the board first.
Hi Kevin,
  1. The board can access the internet
  2. The there is no nv_tegra_release file
see log:
nvidia@tegra-ubuntu:~$ cat /etc/nv_tegra_release
cat: /etc/nv_tegra_release: No such file or directory
nvidia@tegra-ubuntu:~$ ls -la /etc/
total 940
drwxr-xr-x 116 root root    4096 Apr  9 12:55 .
drwxr-xr-x  21 root root    4096 Mar  5 15:11 ..
-rw-------   1 root root       0 Jul 31  2020 .pwd.lock
drwxr-xr-x   2 root root    4096 Mar 12 16:09 PackageKit
drwxr-xr-x   2 root root    4096 Mar  5 16:16 UPower
drwxr-xr-x  12 root root    4096 Mar 30 10:41 X11
-rw-r--r--   1 root root    3028 Jul 31  2020 adduser.conf
drwxr-xr-x   3 root root    4096 Apr 25  2022 alsa
drwxr-xr-x   2 root root    4096 Apr  9 08:41 alternatives
-rw-r--r--   1 root root     433 Oct  1  2017 apg.conf
drwxr-xr-x   5 root root    4096 Apr 25  2022 apm
drwxr-xr-x   3 root root    4096 Mar 30 13:13 apparmor
drwxr-xr-x   8 root root    4096 Mar 30 13:13 apparmor.d
drwxr-xr-x   4 root root    4096 Mar 30 10:41 apport
-rw-r--r--   1 root root     769 Jan 18  2020 appstream.conf
drwxr-xr-x   7 root root    4096 Mar 30 13:26 apt
-rw-r--r--   1 root root    2319 Feb 25  2020 bash.bashrc
-rw-r--r--   1 root root      45 Jan 26  2020 bash_completion
drwxr-xr-x   3 root root    4096 Mar 30 10:41 bash_completion.d
-rw-r--r--   1 root root     367 Apr 14  2020 bindresvport.blacklist
drwxr-xr-x   2 root root    4096 Jan 10  2022 binfmt.d
drwxr-xr-x   2 root root    4096 Mar  5 16:17 bluetooth
drwxr-xr-x   3 root root    4096 Apr 25  2022 ca-certificates
-rw-r--r--   1 root root    5889 Mar  5 16:11 ca-certificates.conf
-rw-r--r--   1 root root    5635 Apr 25  2022 ca-certificates.conf.dpkg-old
drwxr-xr-x   2 root root    4096 Mar 30 10:41 calendar
drwxr-xr-x   2 root root    4096 Mar  5 15:40 chromium-browser
drwx------   3 root root    4096 Mar  5 15:14 cni
drwxr-xr-x   2 root root    4096 Mar  5 16:17 console-setup
drwxr-xr-x   2 root root    4096 Mar  5 16:16 cron.d
drwxr-xr-x   2 root root    4096 Mar 30 10:41 cron.daily
drwxr-xr-x   2 root root    4096 Mar 30 10:41 cron.weekly
-rw-r--r--   1 root root      54 Apr 25  2022 crypttab
drwxr-xr-x   2 root root    4096 Apr 25  2022 cupshelpers
drwxr-xr-x   4 root root    4096 Apr 25  2022 dbus-1
drwxr-xr-x   3 root root    4096 Apr 25  2022 dconf
-rw-r--r--   1 root root    2969 Aug  3  2019 debconf.conf
-rw-r--r--   1 root root      13 Dec  5  2019 debian_version
drwxr-xr-x   3 root root    4096 Mar 30 10:41 default
-rw-r--r--   1 root root     604 Sep 15  2018 deluser.conf
drwxr-xr-x   2 root root    4096 Mar  5 16:16 depmod.d
drwxr-xr-x   4 root root    4096 Mar  5 16:16 dhcp
drwxr-xr-x   2 root root    4096 Mar  5 16:17 dictionaries-common
drwxr-xr-x   2 root root    4096 Mar  5 15:15 docker
drwxr-xr-x   4 root root    4096 Mar  5 16:17 dpkg
-rw-r--r--   1 root root     685 Feb 14  2020 e2scrub.conf
drwxr-xr-x   3 root root    4096 Apr 25  2022 emacs
-rw-r--r--   1 root root     106 Apr 25  2022 environment
-rw-r--r--   1 root root    1816 Dec 27  2019 ethertypes
drwxr-xr-x   2 root root    4096 Mar 30 13:13 firefox
drwxr-xr-x   4 root root    4096 Mar  5 16:17 fonts
-rw-r--r--   1 root root      37 Jul 31  2020 fstab
-rw-r--r--   1 root root     280 Jun 20  2014 fuse.conf
drwxr-xr-x   3 root root    4096 Mar 12 16:10 fwupd
-rw-r--r--   1 root root    2584 Feb  1  2020 gai.conf
drwxr-xr-x   2 root root    4096 Apr  9 12:55 gdb
drwxr-xr-x   8 root root    4096 Mar  5 16:17 gdm3
drwxr-xr-x   2 root root    4096 Mar  5 16:16 geoclue
drwxr-xr-x   3 root root    4096 Apr 25  2022 glvnd
drwxr-xr-x   2 root root    4096 Mar  5 16:16 gnome
drwxr-xr-x   2 root root    4096 Mar 30 10:41 groff
-rw-r--r--   1 root root    1119 Mar 30 10:41 group
-rw-r--r--   1 root root    1107 Mar 30 10:40 group-
drwxr-xr-x   2 root root    4096 Mar 12 16:10 grub.d
-rw-r-----   1 root shadow   935 Mar 30 10:41 gshadow
-rw-r-----   1 root shadow   926 Mar 30 10:40 gshadow-
drwxr-xr-x   3 root root    4096 Apr 25  2022 gss
drwxr-xr-x   2 root root    4096 Mar  5 16:13 gtk-3.0
-rw-r--r--   1 root root      92 Dec  5  2019 host.conf
-rw-r--r--   1 root root      13 Apr 25  2022 hostname
-rw-r--r--   1 root root      43 Apr 25  2022 hosts
-rw-r--r--   1 root root     411 Apr 25  2022 hosts.allow
-rw-r--r--   1 root root     711 Apr 25  2022 hosts.deny
drwxr-xr-x   3 root root    4096 Apr 25  2022 ifplugd
drwxr-xr-x   2 root root    4096 Mar  5 16:17 init
drwxr-xr-x   2 root root    4096 Mar 30 13:13 init.d
-rw-r--r--   1 root root    1748 Feb 25  2020 inputrc
drwxr-xr-x   2 root root    4096 Mar  5 16:17 insserv.conf.d
drwxr-xr-x   4 root root    4096 Mar  5 16:16 iproute2
-rw-r--r--   1 root root      26 Mar 14 11:20 issue
-rw-r--r--   1 root root      26 Feb 17  2022 issue.dpkg-old
-rw-r--r--   1 root root      19 Mar 14 11:20 issue.net
-rw-r--r--   1 root root      19 Feb 17  2022 issue.net.dpkg-old
drwxr-xr-x   2 root root    4096 Apr 25  2022 ist_client
drwxr-xr-x   4 root root    4096 Apr 25  2022 kernel
-rw-r--r--   1 root root   85232 Apr  9 12:55 ld.so.cache
-rw-r--r--   1 root root      34 Apr 14  2020 ld.so.conf
drwxr-xr-x   2 root root    4096 Mar  5 16:15 ld.so.conf.d
drwxr-xr-x   2 root root    4096 Mar  5 16:16 ldap
-rw-r--r--   1 root root     267 Dec  5  2019 legal
-rw-r--r--   1 root root     191 Feb 18  2020 libaudit.conf
drwxr-xr-x   3 root root    4096 Apr 25  2022 libblockdev
drwxr-xr-x   2 root root    4096 Apr 25  2022 libibverbs.d
drwxr-xr-x   2 root root    4096 Mar  5 16:13 libnl-3
lrwxrwxrwx   1 root root      19 Apr 25  2022 locale.conf -> /etc/default/locale
lrwxrwxrwx   1 root root      27 Mar  5 16:13 localtime -> /usr/share/zoneinfo/Etc/UTC
drwxr-xr-x   3 root root    4096 Apr 25  2022 logcheck
-rw-r--r--   1 root root   10550 Feb  7  2020 login.defs
drwxr-xr-x   2 root root    4096 Mar 30 10:41 logrotate.d
-rw-r--r--   1 root root     104 Mar 14 11:20 lsb-release
-rw-r--r--   1 root root     104 Feb 17  2022 lsb-release.dpkg-old
-rw-r--r--   1 root root      33 Jan 10  2022 machine-id
-rw-r--r--   1 root root     111 Jan 16  2020 magic
-rw-r--r--   1 root root     111 Jan 16  2020 magic.mime
-rw-r--r--   1 root root   13012 Apr  9 08:53 mailcap
-rw-r--r--   1 root root     449 Oct 18  2019 mailcap.order
-rw-r--r--   1 root root    5215 Feb 25  2020 manpath.config
drwxr-xr-x   2 root root    4096 Mar  5 16:13 mc
drwxr-xr-x   4 root root    4096 Apr 25  2022 mft
-rw-r--r--   1 root root   24546 Oct 18  2019 mime.types
-rw-r--r--   1 root root     808 Feb 14  2020 mke2fs.conf
drwxr-xr-x   2 root root    4096 Mar  5 16:16 modprobe.d
-rw-r--r--   1 root root     911 Apr 25  2022 modules
drwxr-xr-x   2 root root    4096 Mar 12 16:12 modules-load.d
lrwxrwxrwx   1 root root      19 Apr 25  2022 mtab -> ../proc/self/mounts
drwxr-xr-x   3 root root    4096 Mar  5 16:13 mysql
-rw-r--r--   1 root root     767 Dec 27  2019 netconfig
drwxr-xr-x   6 root root    4096 Apr 25  2022 network
-rw-r--r--   1 root root      91 Dec  5  2019 networks
drwxr-xr-x   2 root root    4096 Apr 25  2022 newt
-rw-r--r--   1 root root     494 Apr 14  2020 nsswitch.conf
drwxr-xr-x   8 root root    4096 Apr 25  2022 nvidia
drwxr-xr-x   2 root root    4096 Apr 25  2022 nvidia-container-runtime
drwxr-xr-x   2 root root    4096 Apr 25  2022 nvpmodel
-rw-r--r--   1 root root    8719 Apr 25  2022 nvsciipc.cfg
drwxr-xr-x   2 root root    4096 Jul 31  2020 opt
lrwxrwxrwx   1 root root      21 Mar 14 11:20 os-release -> ../usr/lib/os-release
-rw-r--r--   1 root root     552 Dec 17  2019 pam.conf
drwxr-xr-x   2 root root    4096 Mar 30 10:41 pam.d
-rw-r--r--   1 root root    1944 Mar 30 10:41 passwd
-rw-r--r--   1 root root    1900 Mar 12 16:10 passwd-
drwxr-xr-x   3 root root    4096 Apr 25  2022 perl
drwxr-xr-x   4 root root    4096 Mar 12 16:09 pki
drwxr-xr-x   3 root root    4096 Apr 25  2022 pm
-rw-r--r--   1 root root     104 Apr  3  2018 pmount.allow
drwxr-xr-x   4 root root    4096 Apr 25  2022 polkit-1
-rw-r--r--   1 root root     581 Dec  5  2019 profile
drwxr-xr-x   2 root root    4096 Mar 30 13:12 profile.d
-rw-r--r--   1 root root    2932 Apr  1  2013 protocols
drwxr-xr-x   3 root root    4096 Mar  5 16:16 pulse
drwxr-xr-x   2 root root    4096 Mar  5 16:13 python2.7
drwxr-xr-x   2 root root    4096 Apr 25  2022 python3
drwxr-xr-x   2 root root    4096 Mar 30 13:13 python3.8
drwxr-xr-x   2 root root    4096 Mar 30 10:41 rc0.d
drwxr-xr-x   2 root root    4096 Mar 30 10:41 rc1.d
drwxr-xr-x   2 root root    4096 Mar 30 10:41 rc2.d
drwxr-xr-x   2 root root    4096 Mar 30 10:41 rc3.d
drwxr-xr-x   2 root root    4096 Mar 30 10:41 rc4.d
drwxr-xr-x   2 root root    4096 Mar 30 10:41 rc5.d
drwxr-xr-x   2 root root    4096 Mar 30 10:41 rc6.d
drwxr-xr-x   2 root root    4096 Mar  5 16:11 rcS.d
lrwxrwxrwx   1 root root      39 Apr 25  2022 resolv.conf -> ../run/systemd/resolve/stub-resolv.conf
lrwxrwxrwx   1 root root      13 Feb  9 17:17 rmt -> /usr/sbin/rmt
-rw-r--r--   1 root root     887 Apr  1  2013 rpc
-rw-r--r--   1 root root    1382 Feb 11  2020 rsyslog.conf
drwxr-xr-x   2 root root    4096 Apr 25  2022 rsyslog.d
drwxr-xr-x   3 root root    4096 Mar  5 16:16 sane.d
drwxr-xr-x   4 root root    4096 Mar  5 16:16 security
drwxr-xr-x   2 root root    4096 Mar  5 16:16 selinux
drwxr-xr-x   2 root root    4096 Apr 25  2022 sensors.d
-rw-r--r--   1 root root   10593 Nov  6  2019 sensors3.conf
-rw-r--r--   1 root root   14464 Feb 16  2020 services
-rw-r-----   1 root shadow  1083 Mar 30 10:41 shadow
-rw-r-----   1 root shadow  1083 Mar 30 10:41 shadow-
-rw-r--r--   1 root root     116 Jul 31  2020 shells
drwxr-xr-x   2 root root    4096 Mar  5 16:15 skel
-rw-r--r--   1 root root    7042 Mar 21  2020 smartd.conf
drwxr-xr-x   4 root root    4096 Apr 25  2022 smartmontools
drwxr-xr-x   2 root root    4096 Mar 30 13:13 snmp
drwxr-xr-x   4 root root    4096 Mar  5 16:17 ssh
drwxr-xr-x   4 root root    4096 Mar  5 16:16 ssl
-rw-r--r--   1 root root      20 Mar 12 15:51 subgid
-rw-r--r--   1 root root      40 Mar  7 07:22 subgid-
-rw-r--r--   1 root root      20 Mar 12 15:51 subuid
-rw-r--r--   1 root root      40 Mar  7 07:22 subuid-
-r--r-----   1 root root     751 Apr 25  2022 sudoers
drwxr-xr-x   2 root root    4096 Mar  5 16:16 sudoers.d
-rw-r--r--   1 root root    2351 Feb 13  2020 sysctl.conf
drwxr-xr-x   2 root root    4096 Mar 12 16:12 sysctl.d
drwxr-xr-x   9 root root    4096 Mar 12 16:12 systemd
drwxr-xr-x   2 root root    4096 Apr 25  2022 tacp
drwxr-xr-x   2 root root    4096 Jul 31  2020 terminfo
-rw-r--r--   1 root root       8 Mar  5 16:13 timezone
drwxr-xr-x   2 root root    4096 Jan 10  2022 tmpfiles.d
drwxr-xr-x   2 root root    4096 Mar 12 16:09 ubuntu-advantage
-rw-r--r--   1 root root    1260 Dec 14  2018 ucf.conf
drwxr-xr-x   4 root root    4096 Mar 12 16:12 udev
drwxr-xr-x   2 root root    4096 Mar  5 16:16 udisks2
drwxr-xr-x   3 root root    4096 Apr 25  2022 ufw
drwxr-xr-x   3 root root    4096 Mar 12 16:09 update-manager
drwxr-xr-x   2 root root    4096 Mar 30 13:12 update-motd.d
drwxr-xr-x   2 root root    4096 Apr 25  2022 usbmount
drwxr-xr-x   2 root root    4096 Apr  9 08:53 vim
lrwxrwxrwx   1 root root      23 Apr 25  2022 vtrgb -> /etc/alternatives/vtrgb
drwxr-xr-x   3 root root    4096 Apr 25  2022 vulkan
-rw-r--r--   1 root root    4942 Nov 12  2021 wgetrc
-rw-r--r--   1 root root      30 Mar 30 10:48 whoopsie
drwxr-xr-x   2 root root    4096 Mar  5 16:16 wpa_supplicant
-rw-r--r--   1 root root     642 Sep 24  2019 xattr.conf
drwxr-xr-x   7 root root    4096 Mar  5 16:16 xdg
drwxr-xr-x   3 root root    4096 Mar 30 10:41 xrdp
How to proceed ?
Regards,
Liron
Is that the AGX Orin devkit?
If yes, I would suggest to re-flash the board with SDK manager.
Install Jetson Software with SDK Manager :: NVIDIA SDK Manager Documentation
