Jetson Orin DevKit - Unable to locate package nvidia-jetpack
I was following this guide to setup.
I managed to Flash the Orin Devkit. I am able to login to the orin device.
I am seeing errors trying to install Jetpack components following this section of the guide
I found this existing issue but the fix mentioned there did not help me.
Some relevant information:
sudo apt update
sudo apt dist-upgrade
sudo reboot
### These commands run sucessfully.
sudo apt install nvidia-jetpack
[sudo] password for <....>:
Reading package lists... Done
Building dependency tree
Reading state information... Done
E: Unable to locate package nvidia-jetpack
apt list nvidia-l4t-core
Listing... Done
nvidia-l4t-core/now 35.1.0-20220810203728 arm64 [installed,local]
cat /etc/apt/sources.list.d/nvidia-l4t-apt-source.list
# SPDX-FileCopyrightText: Copyright (c) 2019-2021 NVIDIA CORPORATION & AFFILIATES. All rights reserved.
# SPDX-License-Identifier: LicenseRef-NvidiaProprietary
# NVIDIA CORPORATION, its affiliates and licensors retain all intellectual
# property and proprietary rights in and to this material, related
# documentation and any modifications thereto. Any use, reproduction,
# disclosure or distribution of this material and related documentation
# without an express license agreement from NVIDIA CORPORATION or
# its affiliates is strictly prohibited.
deb https://repo.download.nvidia.com/jetson/common r35.1 main
deb https://repo.download.nvidia.com/jetson/t234 r35.1 main
I also found this thread and ran
sudo apt install --fix-broken -o Dpkg::Options::="--force-overwrite"
but that did not help.
Any help would be appreciated and please let me know if any additional information is needed.
Thanks in advance.
Please refer to this section of the User Guide to flash your Jetson AGX Orin device using a Linux host PC
Jetson AGX Orin Developer Kit User Guide - Two Ways to Set Up Software | NVIDIA Developer
