ERROR: Unable to locate package nvidia-jetpack
Hi, I just started using the ORIN kit. I was following the setup instructions. But for some reason, the ORIN kit cannot locate the nvidia-jetpack package.
This is release details:
R34 (release), REVISION: 0.1, GCID: 29955323, BOARD: t186ref, EABI: aarch64, DATE: Tue Mar 15 08:13:50 UTC 2022
I checked the /etc/apt/sources.list.d/nvidia-l4t-apt-source.list
I entered next instructions:
sudo apt update
sudo apt dist-upgrade
sudo reboot
sudo apt install nvidia-jetpack
But it is unable to locate the package.
I found the solution. I had to change the source.list to 35.0. For some reason in setup manual for ORIN it says 34.1.
Which doc? We may need to reveiw if that’s a typo. Thanks
In the second step, it suggests the commands to update the source list. And it is written in 34.1.
The r34.1 is for JP 5.0.1 DP and was removed from the public APT server when the 5.0.2 GA was released, will have internal team to review to update it:
sudo bash -c ‘echo “deb https://repo.download.nvidia.com/jetson/common r35.1 main” >> /etc/apt/sources.list.d/nvidia-l4t-apt-source.list’
sudo bash -c ‘echo “deb https://repo.download.nvidia.com/jetson/t234 r35.1 main” >> /etc/apt/sources.list.d/nvidia-l4t-apt-source.list’
