Command 'sudo apt install nvidia-jetpack' is failling after upgrading to JetPack 6.1
After flashing AGX Orin 64 DevKit to Jetpack 6.1 , trying to install or update the system is slow and failing.
Reading package lists… Done
Building dependency tree… Done
Reading state information… Done
The following packages were automatically installed and are no longer required:
gdal-data libaec0 libarmadillo10 libarpack2 libavcodec-dev libavformat-dev libavutil-dev libblosc1 libcfitsio9 libcharls2 libdc1394-dev libdeflate-dev
libdouble-conversion3 libevent-core-2.1-7 libevent-pthreads-2.1-7 libexif-dev libfabric1 libfreexl1 libfyba0 libgdal30 libgdcm-dev libgdcm3.0 libgeos-c1v5
libgeos3.10.2 libgeotiff5 libgl2ps1.4 libglew2.2 libgphoto2-dev libhdf4-0-alt libhdf5-103-1 libhdf5-hl-100 libheif1 libhwloc-plugins libhwloc15 libilmbase-dev
libjbig-dev libjpeg-dev libjpeg-turbo8-dev libjpeg8-dev libjsoncpp25 libkmlbase1 libkmldom1 libkmlengine1 liblept5 libminizip1 libmysqlclient21 libnetcdf19 libodbc2
libodbcinst2 libogdi4.1 libopencv-calib3d4.5d libopencv-contrib4.5d libopencv-dnn4.5d libopencv-features2d4.5d libopencv-flann4.5d libopencv-highgui4.5d
libopencv-imgcodecs4.5d libopencv-imgproc4.5d libopencv-ml4.5d libopencv-objdetect4.5d libopencv-photo4.5d libopencv-shape4.5d libopencv-stitching4.5d
libopencv-superres4.5d libopencv-video4.5d libopencv-videoio4.5d libopencv-videostab4.5d libopencv-viz4.5d libopenexr-dev libopenmpi3 libpmix2 libpng-dev libpq5
libproj22 libraw1394-dev librttopo1 libsocket++1 libspatialite7 libsuperlu5 libswresample-dev libswscale-dev libsz2 libtbb-dev libtesseract4 libtiff-dev libtiffxx5
libucx0 liburiparser1 libvtk9.1 libxerces-c3.2 libxnvctrl0 mysql-common proj-data unixodbc-common
Use ‘sudo apt autoremove’ to remove them.
The following additional packages will be installed:
build-essential cuda-command-line-tools-12-6 cuda-compiler-12-6 cuda-crt-12-6 cuda-cuobjdump-12-6 cuda-cupti-12-6 cuda-cupti-dev-12-6 cuda-cuxxfilt-12-6
cuda-documentation-12-6 cuda-gdb-12-6 cuda-libraries-dev-12-6 cuda-nsight-compute-12-6 cuda-nvcc-12-6 cuda-nvdisasm-12-6 cuda-nvml-dev-12-6 cuda-nvprune-12-6
cuda-nvrtc-dev-12-6 cuda-nvtx-12-6 cuda-nvvm-12-6 cuda-profiler-api-12-6 cuda-sanitizer-12-6 cuda-toolkit-12-6 cuda-tools-12-6 cuda-visual-tools-12-6 cupva-2.5-l4t
dpkg-dev fakeroot gds-tools-12-6 libalgorithm-diff-perl libalgorithm-diff-xs-perl libalgorithm-merge-perl libcublas-dev-12-6 libcudla-dev-12-6 libcudnn9-cuda-12
libcudnn9-dev-cuda-12 libcudnn9-samples libcufft-dev-12-6 libcufile-dev-12-6 libcurand-dev-12-6 libcusolver-dev-12-6 libcusparse-dev-12-6 libnpp-dev-12-6
libnvfatbin-dev-12-6 libnvidia-container-tools libnvidia-container1 libnvinfer-bin libnvinfer-dev libnvinfer-dispatch-dev libnvinfer-dispatch10
libnvinfer-headers-dev libnvinfer-headers-plugin-dev libnvinfer-lean-dev libnvinfer-lean10 libnvinfer-plugin-dev libnvinfer-plugin10 libnvinfer-samples
libnvinfer-vc-plugin-dev libnvinfer-vc-plugin10 libnvinfer10 libnvjitlink-dev-12-6 libnvonnxparsers-dev libnvonnxparsers10 libnvvpi3 libopencv libopencv-dev
libopencv-python libopencv-samples libxcb-cursor0 libxcb-icccm4-dev libxcb-xinerama0 libxcb-xinput0 lto-disabled-list nsight-compute-2024.3.1
nsight-graphics-for-embeddedlinux-2024.2.0.0 nsight-systems-2024.5.4 nvidia-container nvidia-container-toolkit nvidia-container-toolkit-base nvidia-cuda
nvidia-cuda-dev nvidia-cudnn9 nvidia-cudnn9-dev nvidia-cupva nvidia-jetpack-dev nvidia-jetpack-runtime nvidia-l4t-cudadebuggingsupport
nvidia-l4t-jetson-multimedia-api nvidia-nsight-graphics nvidia-nsight-systems nvidia-opencv nvidia-opencv-dev nvidia-tensorrt nvidia-tensorrt-dev nvidia-vpi
nvidia-vpi-dev opencv-licenses opencv-samples-data pva-allow-2 python3-libnvinfer python3-libnvinfer-dev python3-libnvinfer-dispatch python3-libnvinfer-lean
python3.10-vpi3 tensorrt tensorrt-libs vpi3-dev vpi3-python-src vpi3-samples
Suggested packages:
debian-keyring
The following packages will be REMOVED:
libopencv-calib3d-dev libopencv-contrib-dev libopencv-core-dev libopencv-dnn-dev libopencv-features2d-dev libopencv-flann-dev libopencv-highgui-dev
libopencv-imgcodecs-dev libopencv-imgproc-dev libopencv-ml-dev libopencv-objdetect-dev libopencv-photo-dev libopencv-shape-dev libopencv-stitching-dev
libopencv-superres-dev libopencv-video-dev libopencv-videoio-dev libopencv-videostab-dev libopencv-viz-dev
The following NEW packages will be installed:
libnvinfer-vc-plugin-dev libnvinfer-vc-plugin10 libnvinfer10 libnvjitlink-dev-12-6 libnvonnxparsers-dev libnvonnxparsers10 libnvvpi3 libopencv libopencv-python
nvidia-cuda-dev nvidia-cudnn9 nvidia-cudnn9-dev nvidia-cupva nvidia-jetpack nvidia-jetpack-dev nvidia-jetpack-runtime nvidia-l4t-cudadebuggingsupport
The following packages will be upgraded:
libopencv-dev
1 upgraded, 108 newly installed, 19 to remove and 5 not upgraded.
Need to get 3,018 MB of archives.
After this operation, 7,128 MB of additional disk space will be used.
Do you want to continue? [Y/n] Y
Get:1 Index of /ubuntu-ports jammy/main arm64 lto-disabled-list all 24 [12.5 kB]
Get:2 Index of /ubuntu-ports jammy-updates/main arm64 dpkg-dev all 1.21.1ubuntu2.3 [922 kB]
Ign:2 Index of /ubuntu-ports jammy-updates/main arm64 dpkg-dev all 1.21.1ubuntu2.3
Get:3 Index of /ubuntu-ports jammy/main arm64 build-essential arm64 12.9ubuntu3 [4,740 B]
Get:4 Index of /ubuntu-ports jammy/main arm64 libxcb-xinerama0 arm64 1.14-3ubuntu3 [5,404 B]
Get:5 Index of /ubuntu-ports jammy/main arm64 libxcb-xinput0 arm64 1.14-3ubuntu3 [34.8 kB]
Ign:6 https://repo.download.nvidia.com/jetson/common r36.4/main arm64 libopencv-dev arm64 4.8.0-1-g6371ee1
Ign:5 Index of /ubuntu-ports jammy/main arm64 libxcb-xinput0 arm64 1.14-3ubuntu3
Get:7 Index of /ubuntu-ports jammy/universe arm64 libxcb-cursor0 arm64 0.1.1-4ubuntu1 [9,880 B]
Get:8 Index of /ubuntu-ports jammy/main arm64 libxcb-icccm4-dev arm64 0.4.1-1.1build2 [11.2 kB]
Ign:9 https://repo.download.nvidia.com/jetson/common r36.4/main arm64 nvidia-container-toolkit-base arm64 1.14.2-1
Ign:8 Index of /ubuntu-ports jammy/main arm64 libxcb-icccm4-dev arm64 0.4.1-1.1build2
Get:10 Index of /ubuntu-ports jammy/main arm64 fakeroot arm64 1.28-1ubuntu1 [60.5 kB]
Ign:11 https://repo.download.nvidia.com/jetson/common r36.4/main arm64 libnvidia-container1 arm64 1.14.2-1
Ign:10 Index of /ubuntu-ports jammy/main arm64 fakeroot arm64 1.28-1ubuntu1
Get:12 Index of /ubuntu-ports jammy/main arm64 libalgorithm-diff-perl all 1.201-1 [41.8 kB]
Ign:12 Index of /ubuntu-ports jammy/main arm64 libalgorithm-diff-perl all 1.201-1
Get:13 Index of /ubuntu-ports jammy/main arm64 libalgorithm-diff-xs-perl arm64 0.04-6build3 [11.7 kB]
Get:14 Index of /ubuntu-ports jammy/main arm64 libalgorithm-merge-perl all 0.08-3 [12.0 kB]
1% [Waiting for headers] [14 libalgorithm-merge-perl 8,568 B/12.0 kB 71%] 2,906 PB/s 0sBad packet length 3559207282.
ssh_dispatch_run_fatal: Connection to 192.168.68.57 port 22: Connection corrupted
Please check the quick start in developer guide and make sure you follow the steps one by one:
https://docs.nvidia.com/jetson/archives/r36.3/DeveloperGuide/IN/QuickStart.html
If the device still cannot be flashed/booted, please refer to the page to get uart log from the device:
https://elinux.org/Jetson/General_debug
If you are using custom board, you can compare uart log of developer kit and custom board to get more information.
