Can't install nvdia-jetpack
Why I can’t install nvida-jetpack? I am using
R35 (release), REVISION: 3.1, GCID: 32827747, BOARD: t186ref, EABI: aarch64, DATE: Sun Mar 19 15:19:21 UTC 2023
and I have following this step
sudo apt update
sudo apt dist-upgrade
sudo reboot
sudo apt install nvidia-jetpack
And I steel get this error
Reading package lists... Done
Building dependency tree
Reading state information... Done
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
 nvidia-jetpack : Depends: nvidia-jetpack-runtime (= 5.1.1-b56) but it is not going to be installed
                  Depends: nvidia-jetpack-dev (= 5.1.1-b56) but it is not going to be installed
E: Unable to correct problems, you have held broken packages.
Does sudo apt-get -f install fix it?
If it does not, then please re-flash and try again.
You don’t need them.
Please just do:
sudo apt update
Hi, sudo apt-get -f install cannot fix it.
For the re-flash can you use the ubuntu img on the official ubuntu website? or there is already a special image provided by nvidia, where can I get it, some kind of tutorial?
Please refer to the tutorial for SDK Manager:
https://docs.nvidia.com/sdk-manager/install-with-sdkm-jetson/index.html
sorry, I also have a problem installing sdk manager
Note, selecting 'sdkmanager:amd64' instead of './sdkmanager_2.0.0-11402_amd64.deb'
 sdkmanager:amd64 : Depends: libgconf-2-4:amd64 but it is not installable
                    Depends: libcanberra-gtk-module:amd64 but it is not installable
                    Depends: locales:amd64 but it is not installable
What Ubuntu version are you using on the host PC?
Or please try:
https://docs.nvidia.com/jetson/archives/r35.4.1/DeveloperGuide/text/IN/QuickStart.html
Distributor ID:	Ubuntu
Description:	Ubuntu 20.04.6 LTS
Release:	20.04
Codename:	focal
Can linux host be replaced by mac os?
NO.
Please also avoid using docker/virtual machines, a real Ubuntu host PC is required.
