Unable to install jetpack 5.0 ubuntu 20.04 (Jetson AGX Xav)
I want to install Jetpack 5.0 in Ubuntu 20.04 arm64 Jetson AGX Xav. I am following this instructions (How to Install JetPack :: NVIDIA JetPack Documentation) but I get the following error:
nvidia@nvidia-desktop:~$ sudo apt install nvidia-jetpack
Reading package lists… Done
Building dependency tree
Reading state information… Done
E: Unable to locate package nvidia-jetpack
Does somebody know how to solve this issue?
Thank you so much
Hi reyes_rojas,
Are you using the devkit or custom board?
You could refer to the following instructiona for updating jetpack.
Software Packages and the Update Mechanism — To update to a new minor release
And please provide the content of your /etc/apt/sources.list.d/nvidia-l4t-apt-source.list
There’s a similar thread about your issue, you could also refer to check if it could help.
Unable to locate package nvidia-jetpack on Orin devkit - Jetson & Embedded Systems / Jetson AGX Orin - NVIDIA Developer Forums
Good morning
I am sorry for my delay in answering. I am still trying to solve this issue
This is the content of my list
deb https://repo.download.nvidia.com/jetson/common r35.1 main
deb https://repo.download.nvidia.com/jetson/t194 r35.1 main
I want to install jetpack in ubuntu 20.04 (Jetson Javier AGX) so I am proceedig as follow:
  1. I did check the content
  1. sudo apt dist-upgrade`
    sudo reboot
And I get
I will be grateful if somebody could help me with this issue, thank you
Please run sudo apt update first.
Then, try to do sudo apt install nvidia-jetpack later
