I bought a JETSON ORIN NANO 8GB developer kit with a 1TB NVME SSD installed. While shortening the FC REC pin and GND pin of the 12-pin header under the module, insert the power supply plug into the DC jack. The baord l turn on the Jetson dev kit in Force Recovery Mode .
The I started the SDK Manager in Ubuntu 20.04 VM and selected JETPACK 5.1.1(REV.1) to install, finally I got the prompt “INSTALLATION FAILED”. I retried several times, the result was same.
From the Terminal, I found such error, what about the root cause?
20:04:25 INFO: File System and OS - target_image: Get:3 file:/var/cuda-repo-ubuntu2204-11-7-local InRelease [1,575 B]
20:04:27 INFO: File System and OS - target_image: 404 Not Found [IP: 185.125.190.52 80]
20:04:33 INFO: File System and OS - target_image: Reading package lists…
20:04:33 ERROR: File System and OS - target_image: The repository ‘Index of /taylorcholberton/tinyalsa/ubuntu focal Release’ does not have a Release file.
20:04:34 INFO: File System and OS - target_image: Building dependency tree…
20:04:34 INFO: File System and OS - target_image: Reading state information…
20:04:34 INFO: File System and OS - target_image: Use ‘sudo apt autoremove’ to remove it.
20:04:34 INFO: File System and OS - target_image: 0 upgraded, 0 newly installed, 0 to remove and 15 not upgraded.
20:04:34 INFO: File System and OS - target_image: Using rootfs directory of: /home/frank/nvidia/nvidia_sdk/JetPack_5.1.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs
20:04:35 INFO: File System and OS - target_image: Installing extlinux.conf into /boot/extlinux in target rootfs
20:04:35 INFO: File System and OS - target_image: /home/frank/nvidia/nvidia_sdk/JetPack_5.1.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/nv_tegra/nv-apply-debs.sh
20:04:35 INFO: File System and OS - target_image: Copying public debian packages to rootfs
20:04:39 INFO: File System and OS - target_image: Skipping installation of nvidia-l4t-dgpu-apt-source_35.3.1-20230319081403_arm64.deb …
20:04:39 INFO: File System and OS - target_image: Skipping installation of nvidia-l4t-dgpu-config_35.3.1-20230319081403_arm64.deb …
20:04:47 INFO: File System and OS - target_image: Start L4T BSP package installation
20:04:47 INFO: File System and OS - target_image: ERROR qemu not found! To install - please run: “sudo apt-get install qemu-user-static”
20:04:47 ERROR: File System and OS - target_image: command terminated with error
20:04:48 SUMMARY: Flash Jetson Linux - flash: Depends on failed component
The Jetson Orin can’t be power on, there is no way for me to run any command in terminal. Am I miss understanding something here?
Yes you do. This is talking about your host PC.
19:13:22 INFO: VPI on Host - host: Get:3 file:/var/cuda-repo-ubuntu2204-11-7-local InRelease [1,575 B]
19:13:22 INFO: VPI on Host - host: Hit:4 htt://mirrors.ustc.edu.cn/ubuntu focal InRelease
19:13:22 INFO: VPI on Host - host: Hit:5 htt://mirrors.ustc.edu.cn/ubuntu focal-updates InRelease
19:13:22 INFO: VPI on Host - host: Hit:7 htt://mirrors.ustc.edu.cn/ubuntu focal-security InRelease
19:13:23 INFO: VPI on Host - host: Hit:8 htt://ppa.launchpad.net/graphics-drivers/ppa/ubuntu focal InRelease
19:13:23 INFO: VPI on Host - host: Ign:9 htt://ppa.launchpad.net/taylorcholberton/tinyalsa/ubuntu focal InRelease
19:13:24 INFO: VPI on Host - host: 404 Not Found [IP: 185.125.190.52 80]
19:13:26 INFO: VPI on Host - host: Reading package lists…
19:13:26 ERROR: VPI on Host - host: E: The repository ‘htt://ppa.launchpad.net/taylorcholberton/tinyalsa/ubuntu focal Release’ does not have a Release file.
19:13:26 ERROR: VPI on Host - host: Unhandled error when running sudo apt-get update : E: The repository ‘htt://ppa.launchpad.net/taylorcholberton/tinyalsa/ubuntu focal Release’ does not have a Release file.;
19:13:26 ERROR: VPI on Host - host: command terminated with error
19:13:26 SUMMARY: VPI on Host - host: First Error: safe_apt_install failed to run.
19:13:43 INFO: Device info before flashing: Jetson Orin Nano 8GB | 001/002 | 1-1 | Recovery
19:13:43 DEBUG: running command < true >
19:13:43 INFO: command finished successfully
19:13:43 DEBUG: running command < /tmp/device_mode_host_setup.sh >
19:13:43 INFO: exec_command: /tmp/device_mode_host_setup.sh
19:13:43 INFO: Found route default ens33, setting up device mode
19:13:43 INFO: net.ipv4.ip_forward = 1
19:13:43 INFO: Device mode on host successfully set with DNS 8.8.8.8!
19:13:43 DEBUG: Flash Jetson Linux - flash: using adapter to install NV_L4T_FLASH_JETSON_LINUX_COMP@JETSON_ORIN_NANO_TARGETS to /home/frank/nvidia/nvidia_sdk/JetPack_5.1.1_Linux_JETSON_ORIN_NANO_TARGETS
19:13:43 INFO: Flash Jetson Linux - flash: sudo ./nvsdkmanager_flash.sh --storage mmcblk1p1 --nv-auto-config --username frank
19:13:43 INFO: Flash Jetson Linux - flash: user entered mmcblk1p1 --nv-auto-config --username frank
19:13:43 INFO: Flash Jetson Linux - flash: *** Checking ONLINE mode … OK.
19:13:44 INFO: Flash Jetson Linux - flash: *** Checking target board connection … 1 connections found.
19:13:44 INFO: Flash Jetson Linux - flash: *** Reading ECID … FUSELEVEL=fuselevel_production hwchipid=0x23 bootauth=NS
19:13:44 INFO: Flash Jetson Linux - flash: *** Reading EEPROM … “/home/frank/nvidia/nvidia_sdk/JetPack_5.1.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/bootloader/tegraflash.py” --chip 0x23 --applet “/home/frank/nvidia/nvidia_sdk/JetPack_5.1.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/bootloader/mb1_t234_prod.bin” --cfg readinfo_t234_min_prod.xml --dev_params tegra234-br-bct-diag-boot.dts --device_config tegra234-mb1-bct-device-p3701-0000.dts --misc_config tegra234-mb1-bct-misc-p3701-0000.dts --bins “mb2_applet applet_t234.bin” --skipuid --cmd “dump eeprom cvm cvm.bin; reboot recovery”
19:13:44 INFO: Flash Jetson Linux - flash: [ 0.0513 ] Pre-processing config: tegra234-mb1-bct-device-p3701-0000.dts
19:13:44 ERROR: Flash Jetson Linux - flash: FileNotFoundError: [Errno 2] No such file or directory: ‘dtc’
19:13:44 ERROR: Flash Jetson Linux - flash: *** ERROR: Parsing boardid failed
19:13:44 ERROR: Flash Jetson Linux - flash: command terminated with error
19:13:44 SUMMARY: DateTime Target Setup - target: Depends on failed component
Another error here.
What that need to check is, does your host PC have any problem in running sudo apt-get update? We actually have a script to install every prerequisite on your host PC, but it seems that installation didn’t work.
BTW, please try to put your log file into block so that it will be easier to others to read…
this is block
Thank you. Now I started the target by flashing a SD card. I will figure out how to boot from NVMe later.
