After flashing the Orin AGX with the latest SDK manager ( 2.1.0) I end up with a non-functioning system.
The installer fails to install the container runtime, libgstreamer crashes on boot and on the device itself, it is impossible to open a terminal to even see what is going on.
ok - I thought that this is just one more detail about how broken the whole SDK manager install is.
The issue with the missing library seems to have been around for a while, i.e.
which is from September 2022 1.5 years later, same error.
But one basic item that you can answer first… actually something like “sdkmanager 2.1” does not stand for any helpful info at all…
Sdkmanager is just a tool to install Jetpack. It is Jetpack version that matters…
We don’t actually care about something called sdkmanager 2.1…
(That is why I asked you version of “jetpack” in previous post but didn’t get your answer…)
If you use latest sdkmanager to install jetpack version from 2022, then I expect you would still hit same issue even now.
You can ask your deepstream issue and clarify on the new topic filed.
What I want to say here is the jetpack version is upgraded periodically.
A bug you find may only get fixed in next release. (If it is a critical issue, then it may take more time). And sdkm can install every version.
But it won’t fallback to upgrade the previous one. I don’t know if that means “sorts to install broken packages” to you.
Not every release is totally perfect. I believe this happens to any kind of software release things.
Please be aware that I didn’t know anything about your Deepstream issue. Someone else may help check it.
