Dear Sir/ madam
When I was installing sdkmanager_1.8.0-10363_amd64.deb
I had following error massage. Please help me to solve the issue. I want to flash my Jetson TX2 via Ubantu installed on Jetson nano.
kms@kms-desktop:~/Downloads$ sudo apt install ./sdkmanager_1.8.0-10363_amd64.debReading package lists… Done
Building dependency tree
Reading state information… Done
Note, selecting ‘sdkmanager:amd64’ instead of ‘./sdkmanager_1.8.0-10363_amd64.deb’
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
sdkmanager:amd64 : Depends: libgconf-2-4:amd64 but it is not installable
Depends: libcanberra-gtk-module:amd64 but it is not installable
Depends: locales:amd64 but it is not installable
E: Unable to correct problems, you have held broken packages.
