When I try to install sdk manager, it reports the following errors:
nvidia@tegra-ubuntu:~/Downloads$ sudo apt install ./sdkmanager_0.9.13-4763_amd64.deb
Reading package lists... Done
Building dependency tree
Reading state information... Done
Note, selecting 'sdkmanager:amd64' instead of './sdkmanager_0.9.13-4763_amd64.deb'
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
sdkmanager:amd64 : Depends: libgconf-2-4:amd64 but it is not installable
Depends: libcanberra-gtk-module:amd64 but it is not installable
Depends: locales:amd64 but it is not installable
E: Unable to correct problems, you have held broken packages.
cat /etc/apt/sources.list
See UpgradeNotes - Community Help Wiki for how to upgrade to
newer versions of the distribution.
deb Index of /ubuntu-ports xenial main restricted
deb-src Index of /ubuntu-ports xenial main restricted
Major bug fix updates produced after the final release of the
distribution.
deb Index of /ubuntu-ports xenial-updates main restricted
deb-src Index of /ubuntu-ports xenial-updates main restricted
Uncomment the following two lines to add software from the ‘universe’
repository.
N.B. software from this repository is ENTIRELY UNSUPPORTED by the Ubuntu
team. Also, please note that software in universe WILL NOT receive any
review or updates from the Ubuntu security team.
deb Index of /ubuntu-ports xenial universe
deb-src Index of /ubuntu-ports xenial universe
deb Index of /ubuntu-ports xenial-updates universe
deb-src Index of /ubuntu-ports xenial-updates universe
N.B. software from this repository may not have been tested as
extensively as that contained in the main release, although it includes
newer versions of some applications which may provide useful features.
Also, please note that software in backports WILL NOT receive any review
deb Index of /ubuntu-ports xenial-backports main restricted
deb-src Index of /ubuntu-ports xenial-backports main restricted
deb Index of /ubuntu-ports xenial-security main restricted
deb-src Index of /ubuntu-ports xenial-security main restricted
deb Index of /ubuntu-ports xenial-security universe
deb-src Index of /ubuntu-ports xenial-security universe
deb Index of /ubuntu-ports xenial-security multiverse
deb-src Index of /ubuntu-ports xenial-security multiverse
nvidia@tegra-ubuntu:~/Downloads$ cat /etc/apt/sources.list.d/*
cat: '/etc/apt/sources.list.d/*': No such file or directory
Does anyone know how to fix it? I almost try every method I search out in Google but they don’t solve the problem.
