Hi All,
Please guide to install sdkmanager on Jetson nano
I have downloaded this .deb file from
the link avalilable on “Jetson Download Center”
under “All Jetson Developer Kits”
NVIDIA SDK Manager “https://developer.nvidia.com/embedded/dlc/nv-sdk-manager” here.
After executing “sudo apt install ./sdkmanager_0.9.11-3405_amd64.deb” following trace is displayed.
Reading package lists… Done
Building dependency tree
Reading state information… Done
Note, selecting ‘sdkmanager:amd64’ instead of ‘./sdkmanager_0.9.11-3405_amd64.deb’
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
sdkmanager:amd64 : Depends: libgconf-2-4:amd64 but it is not installable
Depends: libcanberra-gtk-module:amd64 but it is not installable
E: Unable to correct problems, you have held broken packages.
Please guide to install sdkmanager on Jetson Nano.
Thanks in Advance.
Anand
