With version 347.09 WHQL tooks my SDSM tighting compute shader whole 70 ms per frame instead with the old verson 344.75 under 1ms (circa 0.7ms) on my GTX970.
See sdsm_reduce_tighting.glsl at SDSM compute shader NVIDIA driver 347.09 WHQL slowdown bug · GitHub , the $-stuff is my own preprocessor.
I’ver tracked to the “((lLinearZ >= reduceDataPartitions[lPartitionIndex].x) && (lLinearZ <= reduceDataPartitions[lPartitionIndex].w))” (in sdsm_reduce_tighting.glsl) comparsion down, but really just the comparsion itself, because:
70ms per frame:
if((lLinearZ >= reduceDataPartitions[lPartitionIndex].x) && (lLinearZ <= reduceDataPartitions[lPartitionIndex].w)){
minBoundsSun[lPartitionIndex] = min(minBoundsSun[lPartitionIndex], lSunLightSpaceCoord.xyz);
maxBoundsSun[lPartitionIndex] = max(maxBoundsSun[lPartitionIndex], lSunLightSpaceCoord.xyz);
70 ms per frame:
bool b = (lLinearZ >= reduceDataPartitions[lPartitionIndex].x) && (lLinearZ <= reduceDataPartitions[lPartitionIndex].w);
minBoundsSun[lPartitionIndex] = mix(minBoundsSun[lPartitionIndex], min(minBoundsSun[lPartitionIndex], lSunLightSpaceCoord.xyz), b);
maxBoundsSun[lPartitionIndex] = mix(maxBoundsSun[lPartitionIndex], max(maxBoundsSun[lPartitionIndex], lSunLightSpaceCoord.xyz), b);
35 ms per frame:
bool b = (lLinearZ >= reduceDataPartitions[lPartitionIndex].x);
without any comparsion checks, it is under 1ms per frame again but the result is unusable then:
minBoundsSun[lPartitionIndex] = min(minBoundsSun[lPartitionIndex], lSunLightSpaceCoord.xyz); maxBoundsSun[lPartitionIndex] = max(maxBoundsSun[lPartitionIndex], lSunLightSpaceCoord.xyz);
Is it a new GLSL compiler bug in 347.09, or why it is with the new driver version so slow now?
