wrong title, multiple detectors work in Deepstream ?
I have downloaded “facenet-120.tar.gz” “https://nvidia.box.com/shared/static/wjitc00ef8j6shjilffibm6r2xxcpigz.gz”
In single_source.txt
I added this at the bottom, this file also have [primary-gie]
[primary-gie]
enable=1
#model-engine-file=../../models/Secondary_CarColor/resnet18.caffemodel_b16_int8.engine
labelfile-path=../../models/facenet-120/class_labels.txt
batch-size=8
gpu-id=0
gie-unique-id=6
operate-on-gie-id=2
operate-on-class-ids=0;
config-file=face.txt
[property]
gpu-id=0
net-scale-factor=0.0039215697906911373
model-file=../../models/facenet-120/snapshot_iter_24000.caffemodel
proto-file=../../models/facenet-120/deploy.prototxt
#model-engine-file=../../models/Primary_Detector/resnet10.caffemodel_b30_int8.engine
#int8-calib-file=../../models/Primary_Detector/cal_trt.bin
batch-size=16
process-mode=1
model-color-format=0
## 0=FP32, 1=INT8, 2=FP16 mode
#network-mode=2
num-detected-classes=1
interval=0
gie-unique-id=1
output-blob-names=coverage/sig;bbox/regressor
#parse-bbox-func-name=NvDsInferParseCustomResnet
#custom-lib-path=/path/to/libnvdsparsebbox.so
#enable-dbscan=1
[class-attrs-all]
threshold=0.1
group-threshold=1
## Set eps=0.7 and minBoxes for enable-dbscan=1
eps=0.2
#minBoxes=3
roi-top-offset=0
roi-bottom-offset=0
detected-min-w=0
detected-min-h=0
detected-max-w=0
detected-max-h=0
Opening in BLOCKING MODE
Creating LL OSD context new
gstnvtracker: Loading low-level lib at /opt/nvidia/deepstream/deepstream-4.0/lib/libnvds_mot_klt.so
gstnvtracker: Optional NvMOT_RemoveStreams not implemented
gstnvtracker: Batch processing is OFF
0:00:03.873237017 17360 0x203e42a0 WARN nvinfer gstnvinfer.cpp:515:gst_nvinfer_logger:<primary_gie_classifier> NvDsInferContext[UID 6]:checkEngineParams(): Could not find output layer 'coverage/sig' in engine
0:00:03.873341502 17360 0x203e42a0 WARN nvinfer gstnvinfer.cpp:515:gst_nvinfer_logger:<primary_gie_classifier> NvDsInferContext[UID 6]:checkEngineParams(): Could not find output layer 'bbox/regressor' in engine
