So I have created a simple pipeline for face mask detection using the triton inference server of DeepStream5.0. The primary-gie is a face detector and the secondary-gie is a classifier that classifies [other, mask, no mask].
The primary-gie face detector is working without any issue, however the secondary-gie which is a classifier only classifies its inputs as mask (the second element of the o/p of the classifier) for all o/ps generated by the primay-gie
I tried using a different classifier model with same o/ps but this time it class prediction is stuck at others (the first element of the o/p )
What am I doing wrong
source1_primary_face_detection.txt (2.9 KB) config_infer_secondary_xception_mask_classification.txt (1.3 KB)
below is the application-config file
[application]
enable-perf-measurement=1
perf-measurement-interval-sec=1
gie-kitti-output-dir=streamscl[tiled-display]
enable=1
rows=1
columns=1
width=1920
height=1080
gpu-id=0
nvbuf-memory-type=0[source0]
enable=1
#Type - 1=CameraV4L2 2=URI 3=MultiURI
type=2
num-sources=1
uri=file:/opt/nvidia/deepstream/deepstream-5.0/models/vid.mp4
gpu-id=0
cudadec-memtype=0[streammux]
gpu-id=0
batch-size=1
batched-push-timeout=40000
enable-padding=0
#set muxer output width and height
width=1920
height=1080
nvbuf-memory-type=0[sink0]
enable=1
#Type - 1=FakeSink 2=EglSink 3=File
type=2
sync=0
source-id=0
gpu-id=0
nvbuf-memory-type=0
container=1
bitrate=4000000
output-file=/opt/nvidia/deepstream/deepstream-5.0/models/output.mp4
codec=1[osd]
enable=1
gpu-id=0
border-width=1
text-size=15
text-color=1;1;1;1;
text-bg-color=0.3;0.3;0.3;1
font=Serif
show-clock=0
clock-x-offset=800
clock-y-offset=820
clock-text-size=12
clock-color=1;0;0;0
nvbuf-memory-type=0[primary-gie]
enable=1
#(0): nvinfer; (1): nvinferserver
plugin-type=1
#infer-raw-output-dir=trtis-output
batch-size=1
interval=0
gie-unique-id=1
config-file=config_infer_primary_face_detection.txt[secondary-gie0]
enable=0
plugin-type=1
batch-size=4
gie-unique-id=2
operate-on-gie-id=1
operate-on-class-ids=1;
config-file=config_infer_secondary_mask_classification.txt[secondary-gie1]
enable=1
plugin-type=1
batch-size=1
gie-unique-id=3
operate-on-gie-id=1
config-file=config_infer_secondary_xception_mask_classification.txt[tracker]
enable=1
tracker-width=640
tracker-height=384
#ll-lib-file=/opt/nvidia/deepstream/deepstream-5.0/lib/libnvds_mot_iou.so
#ll-lib-file=/opt/nvidia/deepstream/deepstream-5.0/lib/libnvds_nvdcf.so
ll-lib-file=/opt/nvidia/deepstream/deepstream-5.0/lib/libnvds_mot_klt.so
#ll-config-file required for DCF/IOU only
#ll-config-file=…/deepstream-app/tracker_config.yml
#ll-config-file=…/deepstream-app/iou_config.txt
gpu-id=0
#enable-batch-process applicable to DCF only
enable-batch-process=1
display-tracking-id=1[tests]
file-loop=0
infer_config {
unique_id: 3
gpu_ids: [0]
max_batch_size: 1
backend {
trt_is {
model_name: "xception_mask_classifier"
version: -1
model_repo {
root: "/opt/nvidia/deepstream/deepstream-5.0/samples/trtis_model_repo"
strict_model_config: true
log_level: 2
tf_gpu_memory_fraction: 0.5
tf_disable_soft_placement: 0
preprocess {
network_format: IMAGE_FORMAT_RGB
tensor_order: TENSOR_ORDER_NHWC
maintain_aspect_ratio: 0
frame_scaling_hw: FRAME_SCALING_HW_DEFAULT
frame_scaling_filter: 1
normalize {
scale_factor: 1.0
channel_offsets: [0, 0, 0]
postprocess {
labelfile_path: "/opt/nvidia/deepstream/deepstream-5.0/samples/trtis_model_repo/xception_mask_classifier/labels.txt"
classification {
threshold: 0.51
input_control {
process_mode: PROCESS_MODE_CLIP_OBJECTS
operate_on_gie_id: 1
operate_on_class_ids: [1]
interval: 0
async_mode: true
object_control {
bbox_filter {
min_width: 16
min_height: 16
The above code is the inferece-config for the secondary-gie
labels:
other;mask;no-mask
Any help is appreciated
**• Hardware Platform GPU
**• DeepStream Version5.0
**• I am using the nvidia docker nvcr.io/nvidia/deepstream:5.0-20.07-triton
• Issue Type( questions)
