Hi all,
this is my first time on this forum. I have a problem with my application when I enable profiling and multithreading options. My application uses both MPI and OpenMP and it’s written in FORTRAN90. I have followed all the instructions and expedients reported on the documentation but the segmentation fault continue to appear on each execution
I use LSF batch system to submit my application…
export OMP_NUM_THREADS=2
export OMP_STACK_SIZE=256M
mpirun -np 4 […] ./myapp.x
The error is similar to the following
[node0009:11998] *** Process received signal ***
[node0009:11998] Signal: Segmentation fault (11)
[node0009:11998] Signal code: Address not mapped (1)
[node0009:11998] Failing at address: 0xffffffffffffff18
[node0009:11998] *** End of error message ***
$ ldd myapp.x
libmpi_f90.so.0 => /opt/openmpi/1.2.8/pgi–8.0-2–binary/lib/libmpi_f90.so.0 (0x00002aaaaacc6000)
libmpi_f77.so.0 => /opt/openmpi/1.2.8/pgi–8.0-2–binary/lib/libmpi_f77.so.0 (0x00002aaaaaf22000)
libmpi.so.0 => /opt/openmpi/1.2.8/pgi–8.0-2–binary/lib/libmpi.so.0 (0x00002aaaab152000)
libopen-rte.so.0 => /opt/openmpi/1.2.8/pgi–8.0-2–binary/lib/libopen-rte.so.0 (0x00002aaaab4a1000)
libopen-pal.so.0 => /copt/openmpi/1.2.8/pgi–8.0-2–binary/lib/libopen-pal.so.0 (0x00002aaaab76f000)
libibverbs.so.1 => /usr/lib64/libibverbs.so.1 (0x00002aaaab9eb000)
librt.so.1 => /lib64/librt.so.1 (0x00002aaaabbf7000)
libdl.so.2 => /lib64/libdl.so.2 (0x00002aaaabe00000)
libnsl.so.1 => /lib64/libnsl.so.1 (0x00002aaaac004000)
libutil.so.1 => /lib64/libutil.so.1 (0x00002aaaac21d000)
libpthread.so.0 => /lib64/libpthread.so.0 (0x00002aaaac420000)
libpgbind.so => /popt/pgi/linux86-64/8.0-2/lib/libpgbind.so (0x00002aaaac63a000)
libnuma.so => /opt/pgi/linux86-64/8.0-2/lib/libnuma.so (0x00002aaaac73c000)
libm.so.6 => /lib64/libm.so.6 (0x00002aaaac83d000)
libc.so.6 => /lib64/libc.so.6 (0x00002aaaacac0000)
libpgf90.so => /opt/pgi/linux86-64/8.0-2/libso/libpgf90.so (0x00002aaaace11000)
libpgf90_rpm1.so => /opt/pgi/linux86-64/8.0-2/libso/libpgf90_rpm1.so (0x00002aaaad1cc000)
libpgf902.so => /opt/pgi/linux86-64/8.0-2/libso/libpgf902.so (0x00002aaaad2ce000)
libpgf90rtl.so => /opt/pgi/linux86-64/8.0-2/libso/libpgf90rtl.so (0x00002aaaad3e1000)
libpgftnrtl.so => /opt/pgi/linux86-64/8.0-2/libso/libpgftnrtl.so (0x00002aaaad504000)
libpgc.so => /opt/pgi/linux86-64/8.0-2/libso/libpgc.so (0x00002aaaad632000)
/lib64/ld-linux-x86-64.so.2 (0x00002aaaaaaab000)
Compile/linker flags are:
MPIF90 = mpif90
CC = pgcc
F77 = pgf77
CFLAGS = -mp -O1 -W0,-profile,lines -Mprof=lines
F90FLAGS = -mp -O1 -r8 -W0,-profile,lines -Mprof=lines
LD = mpif90 -mp -lpgnod_prof_openmpi -W0,-profile,lines -Mprof=lines
If I remove “-mp” flag, the application works without faults!
I’m using the latest available version of PGI compiler (8.0-2).
How I can resolve this problem?
Thank you very much in advance!
