Hi all,
I’m not going to claim to be the best programmer (by a long shot), but I can not figure out what I am doing wrong in my code. I am trying to initialize a variable that is of a struct type, and then initialize the pointers I have inside that struct. I whipped up a test code so I could isolate the effect, and I will post it below:
[codebox]#include
#include <stdlib.h>
#include <stdio.h>
#include <cuda.h>
using namespace std;
struct test
int a;
int *b;
int main()
test* x;
x=(test*)malloc(sizeof(test));
x->a=2;
x->b=(int*)malloc(10*sizeof(int));
for (int l=0; l<10; l++)
x->b[l]=l;
cout <<"\nx->a= "<<x->a;
cout <<"\nx->b["<<l<<"]= "<<x->b[l];
cout<<endl;
test* x_d;
cudaMalloc((void**)&x_d,sizeof(test));
cudaMemcpy(&(x_d->a),&(x->a),sizeof(test),cudaMemcpyHostToDevice);
cudaMalloc((void**)&(x_d->b),10*sizeof(int*));
//Would add more once I get past this point!
}[/codebox]
The terminal output is as follows:
[codebox]nvcc test.cu -run
x->a= 2
x->b[0]= 0
x->b[1]= 1
x->b[2]= 2
x->b[3]= 3
x->b[4]= 4
x->b[5]= 5
x->b[6]= 6
x->b[7]= 7
x->b[8]= 8
x->b[9]= 9
Segmentation fault
[/codebox]
Thanks for any help you can give, I have been stumped by this for a bit too long now.
Adam
p.s. I forgot to mention: I have had no problems running any of the SDK samples, and so I believe the driver/toolkit/sdk are all installed just fine on my PC.
My setup is a core2duo e6600, Ubuntu 9.04, 2gb ram, 8800gts 312mb.
