Hi all,
perhaps whtat I try to do seems a bit strange, but it was an idea to reduce the amount of paramenters which I pass to my kernels.
So the idea is that I make a struct of all the pointers which point to my array which I will use on the GPU. This struct I want to pass to the kernel. So what I did:
typedef struct
xy_struct* xy_coords; //pointer to another struct
z_struct* z_coords; //pointer to another struct
int* b_i;
float* pre_sum;
int* BIN_events;
}ptr_struct_d;
void MLEM(){
ptr_struct_d ptr_array_d;
xy_struct* xy_coords_d;
ptr_array_d.xy_coords = xy_coords_d;
int size_xy= 192*192;
CUDA_SAFE_CALL(cudaMalloc((void **) &ptr_array_d.xy_coords, sizeof(xy_struct)*size_xy));
//doing it in the same way for the other arrays
Sinogram<<<numBlocks, numThreadsPerBlock>>>(ptr_array_d.xy_coords); // in this kernel the array xy_coords is filled, just passing one pointer works
pre_sum_calc<<<numBlocks, numThreadsPerBlock>>>(ptr_array_d, N, n_events); //here I want to pass the whole struct with all pointers, however I get a segmentation fault
my kernels:
__global__ void Sinogram(xy_struct* xy_coords){
//filling of the array...
__global__ void pre_sum_calc(ptr_struct_d ptr_array, int N, int n_events)
int* BIN_events = ptr_array.BIN_events; //I would like to use this array, later another one and so on
int BIN = BIN_events[tID];
So the first kernel, where I just pass one pointer starts and give results, if I want to pass the whole struct, it doesn*t work. Do I have to pass a pointer to the struct and make a cudaMemcpy before. Or is there another problem in my code?
BTW emulation mode runs fine with right results, compilation of device release doesn’t give any warning regarding the pointers. Error which is given is a segmentation fault.
Perhaps this idea seems for a experienced programer senseless, so any comment is welcome!
