I have searched the forums and having tried most solutions , I am forced to ask this rather trivial question… But how would you pass a structure as an argument to a kernel when the structure holds a pointer ?
Suppose I have a simple structure as
struct test_pointer{
double *sample;
I have tried
test_pointer *test_object;
test_pointer *device_test_object;
cudaMalloc( (void **)&(device_test_object->sample) , sizeof(double)*5 );
test_object = (test_pointer*) calloc( 1 , sizeof(double) );
test_object->sample[0] = 1.0;
test_object->sample[1] = 2.0;
test_object->sample[2] = 3.0;
test_object->sample[3] = 4.0;
test_object->sample[4] = 5.0;
cudaMemcpy( device_test_object , test_object , sizeof(double)*5, cudaMemcpyHostToDevice );
OR
cudaMemcpy( device_test_object->sample , test_object->sample , sizeof(double)*5, cudaMemcpyHostToDevice );
I am probably missing a few things here…any comments would be appreciated.
Thanks,
Sj
raghu
March 21, 2011, 6:32am
2
double *sample;
I have tried
OR
Thanks,
Sj
You have not done cudaMalloc for device_test_object structure. You can allocate memory for structure containing pointer as below:
STEP 1:
malloc for test_object
malloc for test_object->sample
fill up values for test_object->sample
STEP 2:
cudaMalloc for device_test_object->sample
cudaMemcpy from test_object->sample to device_test_object->sample
cudaMemcpy from test_object to device_test_object
Now you can use device_test_object in your kerner as you access in normal functions
So you actually want to copy this structure to device memory, not pass it as a function argument?
Your underlying problems have nothing to do with CUDA or passing structures and everything to do with improper usage of pointers. I would strongly recommend spending some time with some learning material on pointers in C. While you are doing that, contemplate this:
double * sample;
sample = (double *) calloc( 5, sizeof(double) );
sample[0] = 1.0;
sample[1] = 2.0;
sample[2] = 3.0;
sample[3] = 4.0;
sample[4] = 5.0;
double * device_sample;
cudaMalloc( (void **)&(device_sample) , sizeof(double) * size_t(5) );
cudaMemcpy( device_sample , sample , sizeof(double) * size_t(5), cudaMemcpyHostToDevice );
test_pointer * test_object;
test_object = (test_pointer *) calloc( 1 , sizeof(test_pointer) );
test_object->sample = device_sample;
test_pointer * device_test_object;
cudaMalloc( (void **)&(device_test_object) , sizeof(test_pointer) );
cudaMemcpy( device_test_object , test_object , sizeof(test_pointer), cudaMemcpyHostToDevice );
which is probably much closer to what it seems you are trying to achieve.
STEP 1:
STEP 2:
The last cudaMemcpy call will copy host pointers into device memory. That will not work. In fact several stages in STEP 2 won’t work.
STEP 1:
STEP 2:
Suppose I cudaMalloc it as
cudaMalloc( (void **)&(device_test_object) , MEMSIZE );
what would MEMSIZE be for this structure object ? Almost everything I tried leads to segmentation faults…
raghu
March 21, 2011, 9:07am
7
Here is the complete code to allocate memory for a structure containing pointer:
#include<stdio.h>
#define MAXLIMIT 64
double *sample;
__global__ void myKernel(test_pointer *device_test_pointer)
device_test_pointer->sample[threadIdx.x] = 10.0f + threadIdx.x;
return;
int main()
test_pointer *host_test_object;
double *host_sample, *device_sample;
host_sample = (double*) malloc(MAXLIMIT * sizeof(double));
for(int i = 0; i < MAXLIMIT; i++)
host_sample[i] = (double) i;
cudaMalloc( (void **)&(device_sample) , sizeof(double)*MAXLIMIT );
cudaMemcpy( device_sample, host_sample, sizeof(double)*MAXLIMIT, cudaMemcpyHostToDevice );
host_test_object = (test_pointer*) malloc( sizeof(test_pointer));
host_test_object->sample = device_sample;
cudaMemcpy( device_test_object , host_test_object, sizeof(test_pointer), cudaMemcpyHostToDevice );
myKernel<<<1,MAXLIMIT>>>(device_test_object);
cudaThreadSynchronize();
cudaMemcpy(host_sample, device_sample, sizeof(double) * MAXLIMIT, cudaMemcpyDeviceToHost);
printf("%lf\n", host_sample[i]);
return 0;
Since you are using double, compile the code with nvcc option -arch=sm_13.
That works ! Thanks for all the replies and to Raghu for that code snippet , that is precisely what I needed…
If it is not too much trouble , may I ask what a good reference for these topics would be ?
