• Hardware Platform (Jetson / GPU) Both
• DeepStream Version 5.01
• JetPack Version (valid for Jetson only) L4T 32.4.4
• TensorRT Version 7.0.0 (GPU) / 7.1.3 (Jetson)
• NVIDIA GPU Driver Version (valid for GPU only) 450.102.04
• Issue Type( questions, new requirements, bugs) question
• How to reproduce the issue ? (This is for bugs. Including which sample app is using, the configuration files content, the command line used and other details for reproducing) N/A
I’m trying to swap pointers from the surface buffer so that I can do whatever I need to with the image data in a different/dedicated thread. Here’s my code from Deepstream that syncs the data for access by the CPU and passes the data to the next function:
cudaError_t cuda_err;
NvBufSurfTransformRect src_rect, dst_rect;
NvBufSurface *surface = (NvBufSurface *) in_map_info.data;
int batch_size = surface->batchSize;
src_rect.top = 0;
src_rect.left = 0;
src_rect.width = (guint) surface->surfaceList[0].width;
src_rect.height = (guint) surface->surfaceList[0].height;
dst_rect.top = 0;
dst_rect.left = 0;
dst_rect.width = (guint) surface->surfaceList[0].width;
dst_rect.height = (guint) surface->surfaceList[0].height;
NvBufSurfTransformParams nvbufsurface_params;
nvbufsurface_params.src_rect = &src_rect;
nvbufsurface_params.dst_rect = &dst_rect;
nvbufsurface_params.transform_flag = NVBUFSURF_TRANSFORM_CROP_SRC | NVBUFSURF_TRANSFORM_CROP_DST;
nvbufsurface_params.transform_filter = NvBufSurfTransformInter_Default;
NvBufSurfaceCreateParams nvbufsurface_create_params;
nvbufsurface_create_params.gpuId = surface->gpuId;
nvbufsurface_create_params.width = (gint) surface->surfaceList[0].width;
nvbufsurface_create_params.height = (gint) surface->surfaceList[0].height;
nvbufsurface_create_params.size = 0;
nvbufsurface_create_params.layout = NVBUF_LAYOUT_PITCH;
#ifdef PLATFORM_TEGRA
nvbufsurface_create_params.colorFormat = NVBUF_COLOR_FORMAT_RGBA;
nvbufsurface_create_params.memType = NVBUF_MEM_SURFACE_ARRAY;
#else
nvbufsurface_create_params.memType = NVBUF_MEM_CUDA_UNIFIED;
#endif
cuda_err = cudaSetDevice(surface->gpuId);
NvBufSurface *dst_surface = NULL;
cudaStream_t cuda_stream;
cuda_err = cudaStreamCreate(&cuda_stream);
int create_result = NvBufSurfaceCreate(&dst_surface, batch_size, &nvbufsurface_create_params);
NvBufSurfTransformConfigParams transform_config_params;
NvBufSurfTransform_Error err;
transform_config_params.compute_mode = NvBufSurfTransformCompute_Default;
transform_config_params.gpu_id = surface->gpuId;
transform_config_params.cuda_stream = cuda_stream;
err = NvBufSurfTransformSetSessionParams(&transform_config_params);
NvBufSurfaceMemSet(dst_surface, 0, 0, 0);
err = NvBufSurfTransform(surface, dst_surface, &nvbufsurface_params);
if (err != NvBufSurfTransformError_Success) {
g_print("DS NvBufSurfTransform failed with error %d while converting buffer\n", err);
NvBufSurfaceMap(dst_surface, 0, 0, NVBUF_MAP_READ);
NvBufSurfaceSyncForCpu(dst_surface, 0, 0);
NvDsConfig *config = &appCtx->config;
NvDsSourceConfig *sources = appCtx->config.multi_source_config;
custom_parser (frame_meta->source_id, dst_surface->surfaceList[0].dataSize,
(std::byte *)dst_surface->surfaceList[0].mappedAddr.addr[0]);
NvBufSurfaceUnMap(dst_surface, 0, 0);
NvBufSurfaceDestroy(dst_surface);
cudaStreamDestroy(cuda_stream);
gst_buffer_unmap(buf, &in_map_info);
I’ve removed most of the code from the following samples as it’s not relevant to the issue.
This is a pointer swap function that’s similar to std::swap. I implemented it manually so that I could try to debug the issue.
void frameSwap(std::byte& _a, std::byte& _b) {
std::byte *_tmp = &_a;
_a = _b;
_b = *_tmp;
Here’s the function that gets called from the deepstream side of things and swaps the pointers.
std::byte *imageData[NUM_THREADS] = {};
// initialization code for imageData is elsewhere on startup
void custom_parser (guint source_id, gint data_size, std::byte *new_frame) {
// there is locking code here to manage thread safe access
frameSwap(imageData[source_id], new_frame);
// notify relevant dedicated thread of new frame data
The issue that I’m having is that this is working 100% perfectly on dGPU, but on Jetson I get a segfault when the dedicated thread accesses imageData[source_id]
. I’m guessing it’s an issue with the memory type allocation on the Jetson and isn’t getting swapping correctly and it’s still getting freed from deepstream, but I’m unsure how I should be going about this.
To forestall any suggestions about copying the data to another pointer entirely (such as with memcpy), this isn’t an option as the copy operation is blocking and takes too much time with what I’m trying to do. Which is the reason I’m going after a pointer swap which takes only a fraction of a millisecond as opposed to over 10 milliseconds on the Jetson.
Any help is appreciated.
