Unexpected Modicifation Of NvBufSurfTransformConfigParams
• Hardware Platform: Jetson AGX Orin
• DeepStream Version: 6.3
• JetPack Version: 5.1.3
• TensorRT Version: 8.5.2-1+cuda11.4
• Issue Type: Question // Bug
• How to reproduce the issue ?
I would like to ask about a specific behavior in the NvBufSurfaceTransform API. It has been stated that the API is thread-safe in the following post: Multimedia API: thread-safety of NvBufSurfTransform? . However we are experiencing unexpected changes to NvBufSurfTransformConfigParams without modifying it ourselves.
How to reproduce:
Begin with /opt/nvidia/deepstream/deepstream-6.3/sources/gst-plugins/gst-nvdsvideotemplate/customlib_impl/customlib_impl.cpp from the official Deepstream examples (part of Deepstream installation).
Change the void SampleAlgorithm::OutputThread(void) to the following demonstrative version, and compile it as usual using: CUDA_VER=11.4 make
/* Output Processing Thread */
  GstFlowReturn flow_ret;
  GstBuffer *outBuffer = NULL;
  std::unique_lock<std::mutex> lk(m_processLock);
  NvDsBatchMeta *batch_meta = NULL;
  if(hw_caps == true) {
    cudaError_t cuErr = cudaSetDevice(m_gpuId);
    if(cuErr != cudaSuccess) {
      GST_ERROR_OBJECT(m_element, "Unable to set cuda device");
      return;
  // set surface transform session when transform mode is on
  int err = NvBufSurfTransformSetSessionParams(&m_config_params);
  if (err != NvBufSurfTransformError_Success) {
    GST_ERROR_OBJECT (m_element, "Set session params failed");
    return;
  NvBufSurfTransformConfigParams query;
  NvBufSurfTransformGetSessionParams(&query);
  printf("ComputeMode: %d, Stream: %p\n",query.compute_mode,query.cuda_stream);
  /* Run till signalled to stop. */
  while (1) {
    /* Wait if processing queue is empty. */
    if (m_processQ.empty()) {
      if (m_stop == TRUE) {
        break;
      m_processCV.wait(lk);
      continue;
    PacketInfo packetInfo = m_processQ.front();
    m_processQ.pop();
    m_processCV.notify_all();
    lk.unlock();
    outBuffer = packetInfo.inbuf;
    nvds_set_output_system_timestamp (outBuffer, GST_ELEMENT_NAME(m_element));
    flow_ret = gst_pad_push (GST_BASE_TRANSFORM_SRC_PAD (m_element), outBuffer);
    lk.lock();
    continue;
  outputthread_stopped = true;
  lk.unlock();
  return;
Start a video processing using this plugin (replace stream with your stream):
#!/bin/bash
gst-launch-1.0 \
  uridecodebin3 uri=rtspt://192.168.5.10:28554/42_speed ! \
  nvvideoconvert ! 'video/x-raw(memory:NVMM),format=I420' ! \
  nvdsvideotemplate customlib-name=/opt/nvidia/deepstream/deepstream-6.3/sources/gst-plugins/gst-nvdsvideotemplate/customlib_impl/libcustom_videoimpl.so ! \
  'video/x-raw(memory:NVMM),format=I420' ! nvvideoconvert ! 'video/x-raw(memory:NVMM),format=NV12' ! \
  fakesink
Observe the standard output of the program:
NvMMLiteOpen : Block : BlockType = 261
NvMMLiteBlockCreate : Block : BlockType = 261
ComputeMode: 1, Stream: 0xaaab23003130
ComputeMode: 2, Stream: 0xffff2c056e50
Additional Observations:
As we can see, the compute mode and CUDA stream does change at some point, even though no NvBufSurfTransformSetSessionParams is called in the while loop. How can this happen?
Per our suspicion, if we remove the second convert nvvideoconvert ! 'video/x-raw(memory:NVMM),format=NV12' from the pipeline, the behaviour ceases to manifest. So it seems that the nvvideoconvert has a part to play in this.
Does this mean that downstream elements can change NvBufSurfTransformConfigParams at any given time without us knowing? Is there any obvious oversight on our part which should be mended to avoid this?
Thank you for your support,
Simon
Post scriptum: Additional findings
The change is very likely caused by the second nvvideoconvert element. The params seem be dictated by the configuration of the second nvvideoconvert. Try setting compute-hw=1, then only cuda stream changes.
Also, adding a queue between nvdsvideotemplate and nvvideoconvert seems to help.
Could you add a queue plugin before the 2nd nvvideoconvert element and check that?
I already mentioned this:
After adding a queue before the second nvvideoconvert, I did not observer this. However given that queue adds a thread to the pipeline, I cannot be sure whether this is not only a ‘timing issue’ (adding a delay that will cause different order of execution). In other words, the problem can happen 1/20 times but still happen. There is not a way for me to know this.
In the example, NvBufSurfTransformSetSessionParams is already ran on a separate std::thread , yet the session parameters are being modified by a downstream element.
Therefore, my question is: how does NvBufSurfTransformSetSessionParams work and how to ensure that the downstream (or any other element) does not modify the value at a random point during the pipeline lifecycle?
Right now, the API is hard to use, given that we do not know if and when does the cuda stream (or the compute mode) change without any explicit call from our nvdsvideotemplate plugin
Thanks for your confirmation. We’ll investigate this issue and inform you in time once we have a conclusion.
Hi, we confirm that it’s expected behaviour. The pad_push is called which has different compute parameters and this changes the session parameters. So if you want to do some customized processing, it is recommended to add a queue after that. Or it will be determined by the downstream plugin.
thank you for investigating. When you speak of pad_push, does it mean this line in customlib_impl.cpp?
Yes. It’s used to send the gstbuffer to the downstream plugin.
