GPU
• DeepStream Version
6.3
• TensorRT Version
Version from nvcr.io/nvidia/deepstream:6.3-gc-triton-devel
NVIDIA-SMI 525.147.05 Driver Version: 525.147.05 CUDA Version: 12.0
question (bug?)
Add some handlers to print the pts:
static GstPadProbeReturn pts_probe1( GstPad * pad,
GstPadProbeInfo * info,
gpointer u_data )
static int count = 0;
GstBuffer * buf = ( GstBuffer * ) info->data;
NvDsBatchMeta * batch_meta = gst_buffer_get_nvds_batch_meta ( buf );
GstClockTime pts = GST_BUFFER_PTS ( buf );
g_print ( "pts before [%d]:\t%ld\n", count, pts );
count++;
return GST_PAD_PROBE_OK;
static GstPadProbeReturn pts_probe2( GstPad * pad,
gpointer u_data )
g_print ( "pts after [%d]:\t%ld\n", count, pts );
count++;
Add Probes before and after the streammux, as follows:
GstPad * pad1 = gst_element_get_static_pad ( streammux, "sink_0" );
if ( !pad1 )
g_print ( "Unable to get streammux pad\n" );
else
gst_pad_add_probe ( pad1, GST_PAD_PROBE_TYPE_BUFFER,
pts_probe1, NULL, NULL );
gst_object_unref ( pad1 );
GstPad * pad2 = gst_element_get_static_pad ( pgie, "sink" );
if ( !pad2 )
g_print ( "Unable to get pad2\n" );
else
gst_pad_add_probe ( pad2, GST_PAD_PROBE_TYPE_BUFFER,
pts_probe2, NULL, NULL );
gst_object_unref ( pad2 );
Hi All,
I am trying to run a deepstream app that will save the inference results to a database for later retrieval. I am saving the pts value in the database so I can exactly match back the results, however I noticed that the values being saved are not the same when I then play the video back using gstreamer or opencv.
I have since traced this to the streammux plugin changing the pts. You can see below that after adding probes I get different pts timestamps before and after the the streammux plugin.
pts before [0]: 0
pts after [0]: 0
pts before [1]: 66666666
pts after [1]: 66666666
pts before [2]: 133334166 <---- Correct
pts after [2]: 133333332 <---- Wrong!
I only do one video at a time, so naturally my thought was to remove the streammux plugin, but apparently the streammux is now a required plugin. Either way the pgie was not happy:
error: NvDsBatchMeta not found for input buffer.
ERROR from element primary-nvinference-engine: NvDsBatchMeta not found for input buffer.
So how do I stop streammux from messing with my pts timestamps?
