I am using gstreamer to stream a video from a using its rtsp stream. In my pipeline everything other element is working fine but when I try to save the recording in form of mp4 the pipeline throws an error “Buffer has no PTS” and the pipeline shutdown. I wan to save an mp4 with duration of 5 mins each.
I have attached the graph which shows the different elements used and their links.
Hey @junshengy is there something I am missing in the pipeline, can you please check and let me know?
This problem may be caused by the pipeline input rtsp stream not containing the rtcp ssrc package.
This may cause the PTS of the GstBuffer output by nvstreamdemux to be set to 0
Is the input of the pipeline an rtsp url and is the attach-sys-ts property of nvstreammux set to false?
If so, use the default value (true) for attach-sys-ts.
Yes, the input is an rtsp url but I have not done any changes to attach-sys-ts property.
Modify your pipeline as below
..... queue --> nvv4l2h264enc --> h264parse --> tee --> |
| --> splitmuxsink
nvv4l2h264enc only needs one instance,
Try the following pipeline
gst-launch-1.0 uridecodebin uri="your rtsp camera" ! m.sink_0 \
nvstreammux name=m batch-size=1 width=1920 height=1080 ! \
nvinfer config-file-path=/opt/nvidia/deepstream/deepstream/samples/configs/deepstream-app/config_infer_primary.txt ! \
nvtracker tracker-width=640 tracker-height=480 ll-lib-file=/opt/nvidia/deepstream/deepstream/lib/libnvds_nvmultiobjecttracker.so \
ll-config-file=/opt/nvidia/deepstream/deepstream/samples/configs/deepstream-app/config_tracker_NvDCF_perf.yml ! \
nvvideoconvert ! 'video/x-raw(memory:NVMM),format=RGBA' ! nvdsosd ! nvvideoconvert ! 'video/x-raw(memory:NVMM),format=NV12' ! \
nvv4l2h264enc ! h264parse ! tee name=t \
t.src_0 ! splitmuxsink location="out%02d.mp4" muxer=mp4mux max-size-time=300000000000 \
t.src_1 ! fakesink
thanks for the suggestion to optimise the script I will make that change.
I tried running the pipeline, but it stopped midway.
modprobe: FATAL: Module nvidia not found in directory /lib/modules/5.10.104-tegra
Setting pipeline to PAUSED ...
Opening in BLOCKING MODE
gstnvtracker: Loading low-level lib at /opt/nvidia/deepstream/deepstream/lib/libnvds_nvmultiobjecttracker.so
gstnvtracker: Batch processing is ON
gstnvtracker: Past frame output is OFF
[NvMultiObjectTracker] Initialized
WARNING: Deserialize engine failed because file path: /opt/nvidia/deepstream/deepstream-6.2/samples/configs/deepstream-app/../../models/Primary_Detector/resnet10.caffemodel_b30_gpu0_int8.engine open error
0:00:04.035906196 58 0xaaaaf03cb040 WARN nvinfer gstnvinfer.cpp:677:gst_nvinfer_logger:<nvinfer0> NvDsInferContext[UID 1]: Warning from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:1897> [UID = 1]: deserialize engine from file :/opt/nvidia/deepstream/deepstream-6.2/samples/configs/deepstream-app/../../models/Primary_Detector/resnet10.caffemodel_b30_gpu0_int8.engine failed
0:00:04.123226923 58 0xaaaaf03cb040 WARN nvinfer gstnvinfer.cpp:677:gst_nvinfer_logger:<nvinfer0> NvDsInferContext[UID 1]: Warning from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:2002> [UID = 1]: deserialize backend context from engine from file :/opt/nvidia/deepstream/deepstream-6.2/samples/configs/deepstream-app/../../models/Primary_Detector/resnet10.caffemodel_b30_gpu0_int8.engine failed, try rebuild
0:00:04.123359275 58 0xaaaaf03cb040 INFO nvinfer gstnvinfer.cpp:680:gst_nvinfer_logger:<nvinfer0> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:1923> [UID = 1]: Trying to create engine from model files
WARNING: [TRT]: The implicit batch dimension mode has been deprecated. Please create the network with NetworkDefinitionCreationFlag::kEXPLICIT_BATCH flag whenever possible.
• DeepStream Version
• TensorRT Version
• The pipeline being used
If you use file:///opt/nvidia/deepstream/deepstream/samples/streams/sample_1080p_h264.mp4, does the pipeline work properly?
Try re-burning DS-7.1 and Jetpack 6.1. On DS-7.1, the above pipeline works fine.
I tried running the pipeline using an mp4, and everything ran fine. The splitmuxsink was able to save an mp4 without any issues.
NVIDIA Jetson Xavier NX - AVerMedia NX215 - Jetpack 5.1
I let the pipeline run for a while and got this error,
0:00:04.307920256 639 0xaaaaba39e440 WARN nvinfer gstnvinfer.cpp:677:gst_nvinfer_logger:<nvinfer0> NvDsInferContext[UID 1]: Warning from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:1897> [UID = 1]: deserialize engine from file :/opt/nvidia/deepstream/deepstream-6.2/samples/configs/deepstream-app/../../models/Primary_Detector/resnet10.caffemodel_b30_gpu0_int8.engine failed
0:00:04.384933337 639 0xaaaaba39e440 WARN nvinfer gstnvinfer.cpp:677:gst_nvinfer_logger:<nvinfer0> NvDsInferContext[UID 1]: Warning from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:2002> [UID = 1]: deserialize backend context from engine from file :/opt/nvidia/deepstream/deepstream-6.2/samples/configs/deepstream-app/../../models/Primary_Detector/resnet10.caffemodel_b30_gpu0_int8.engine failed, try rebuild
0:00:04.385060474 639 0xaaaaba39e440 INFO nvinfer gstnvinfer.cpp:680:gst_nvinfer_logger:<nvinfer0> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:1923> [UID = 1]: Trying to create engine from model files
0:05:12.062920950 639 0xaaaaba39e440 INFO nvinfer gstnvinfer.cpp:680:gst_nvinfer_logger:<nvinfer0> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:1955> [UID = 1]: serialize cuda engine to file: /opt/nvidia/deepstream/deepstream-6.2/samples/models/Primary_Detector/resnet10.caffemodel_b30_gpu0_int8.engine successfully
INFO: [Implicit Engine Info]: layers num: 3
0 INPUT kFLOAT input_1 3x368x640
1 OUTPUT kFLOAT conv2d_bbox 16x23x40
2 OUTPUT kFLOAT conv2d_cov/Sigmoid 4x23x40
0:05:12.269448495 639 0xaaaaba39e440 INFO nvinfer gstnvinfer_impl.cpp:328:notifyLoadModelStatus:<nvinfer0> [UID 1]: Load new model:/opt/nvidia/deepstream/deepstream/samples/configs/deepstream-app/config_infer_primary.txt sucessfully
Pipeline is live and does not need PREROLL ...
Progress: (open) Opening Stream
Progress: (connect) Connecting to rtsp://admin:drishti123@192.168.1.153x
ERROR: from element /GstPipeline:pipeline0/GstURIDecodeBin:uridecodebin0/GstRTSPSrc:source: Could not open resource for reading and writing.
Additional debug info:
gstrtspsrc.c(7893): gst_rtspsrc_retrieve_sdp (): /GstPipeline:pipeline0/GstURIDecodeBin:uridecodebin0/GstRTSPSrc:source:
Failed to connect. (Generic error)
ERROR: pipeline doesn't want to preroll.
Setting pipeline to NULL ...
[NvMultiObjectTracker] De-initialized
Freeing pipeline ...
root@tegra-ubuntu:/home/nvidia/triton-deepstream# ./test.sh
0:00:04.443217156 660 0xaaaabd20e440 INFO nvinfer gstnvinfer.cpp:680:gst_nvinfer_logger:<nvinfer0> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:1909> [UID = 1]: deserialized trt engine from :/opt/nvidia/deepstream/deepstream-6.2/samples/models/Primary_Detector/resnet10.caffemodel_b30_gpu0_int8.engine
0:00:04.517458518 660 0xaaaabd20e440 INFO nvinfer gstnvinfer.cpp:680:gst_nvinfer_logger:<nvinfer0> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:2012> [UID = 1]: Use deserialized engine model: /opt/nvidia/deepstream/deepstream-6.2/samples/models/Primary_Detector/resnet10.caffemodel_b30_gpu0_int8.engine
0:00:04.563308967 660 0xaaaabd20e440 INFO nvinfer gstnvinfer_impl.cpp:328:notifyLoadModelStatus:<nvinfer0> [UID 1]: Load new model:/opt/nvidia/deepstream/deepstream/samples/configs/deepstream-app/config_infer_primary.txt sucessfully
From the above two points, this problem is related to your rtsp camera. I tested the internal rtsp test source and it works fine.
Please check your rtsp camera. Also, please dump the rtsp file as a ts file. I will try to reproduce it.
gst-launch-1.0 rtspsrc location=“rtsp” protocols=4 ! queue ! parsebin ! queue ! h264parse ! mpegtsmux ! filesink location=rtsp.ts
I tested the script using a different rtsp source from the a different camera and everything worked fine.
But on the other hand I am facing delay when running the script. When we start the pipeline there isn’t any delays but it slowly builds up. I check the pipeline there isn’t any delay between the elements and processes that we perform, the delay is building up at the start itself.
is there a configuration that would help in nvstreammux or any queuing tips.
