Error when recording videos using splitmuxsink in deepstream python
• Hardware Platform (Jetson / GPU) - Jetson Nano
• DeepStream Version - 6.0.1
• JetPack Version (valid for Jetson only)** - 4.6.3
• TensorRT Version - 8.2.1.9
• NVIDIA GPU Driver Version (valid for GPU only) - 10.2
Error: gst-stream-error-quark: Could not multiplex stream. (10): gstqtmux.c(4561): gst_qt_mux_add_buffer (): /GstPipeline:pipeline0/GstSplitMuxSink:recording-sink2/GstMP4Mux:muxer:
Buffer has no PTS.
streammux->nvvideoconvert->capsfilter->inference->demux->queue->nvvideoconvert->nv4l2h264enc->h264parse->splitmuxsink
I need solve the above error without changing muxer to matroskamux
Please help me dump stream to reproduce this issue.
It may be related to your stream.
It would be better if you provide sample code or a command line
thanks.
sample code.
deepstream_split_record.py (23.1 KB)
Due to lack of same stream,I did not run your code successfully.
But I try to build the same pipeline using the command line,It’s normal.
This is my command line
gst-launch-1.0 -e nvstreammux name=mux batch-size=1 width=1920 height=1080 ! nvinfer config-file-path=/opt/nvidia/deepstream/deepstream/samples/configs/deepstream-app/config_infer_primary.txt batch-size=1  ! nvstreamdemux name=demux uridecodebin uri=file:///opt/nvidia/deepstream/deepstream/samples/streams/sample_1080p_h264.mp4 ! mux.sink_0 demux.src_0 ! queue ! nvvideoconvert ! "video/x-raw(memory:NVMM),format=NV12" ! nvv4l2h264enc ! h264parse ! splitmuxsink location=split_out.mp4
so I think this issue is related to your stream.
Can you dump the rtp stream to local file for me reproduce this issue ?
thanks
how to dump the rtp stream to local file?
Such as
gst-launch-1.0 urisourcebin uri=rtsp://10.19.225.227/media/video1 ! queue ! parsebin ! queue ! h264parse ! mpegtsmux ! filesink location=rtsp.ts
One more things, export GST_DEBUG=3,then run your python code give log for me ?
Maybe you can try the cmd replace with your uri first to make sure the pipeline work fine on your environment
