Hardware Platform (Jetson / GPU): GPU NVIDIA GeForce RTX 2080 Ti
DeepStream Version: 6.3
TensorRT Version: 8.5.3
NVIDIA GPU Driver Version (valid for GPU only): 530.30.02
Issue Type( questions, new requirements, bugs): Bug
How to reproduce the issue ?
I have problem with software encoder. I’m using deepstream app with Splitmuxsink, when I use enc-type=1 in config file, the app run with fps=0 (I also test with file sink and this problem not happen). You can see this picture:
- My config:
[application]
enable-perf-measurement=1
perf-measurement-interval-sec=5
#gie-kitti-output-dir=streamscl
[tiled-display]
enable=1
rows=1
columns=1
width=2736
height=2736
gpu-id=0
#(0): nvbuf-mem-default - Default memory allocated, specific to particular platform
#(1): nvbuf-mem-cuda-pinned - Allocate Pinned/Host cuda memory, applicable for Tesla
#(2): nvbuf-mem-cuda-device - Allocate Device cuda memory, applicable for Tesla
#(3): nvbuf-mem-cuda-unified - Allocate Unified cuda memory, applicable for Tesla
#(4): nvbuf-mem-surface-array - Allocate Surface Array memory, applicable for Jetson
nvbuf-memory-type=0
[source0]
enable=1
#Type - 1=CameraV4L2 2=URI 3=MultiURI 4=RTSP
type=3
uri=file://../../videos/manypeoples.mp4
num-sources=1
gpu-id=0
# (0): memtype_device - Memory type Device
# (1): memtype_pinned - Memory type Host Pinned
# (2): memtype_unified - Memory type Unified
cudadec-memtype=0
drop-frame-interval=0
latency=10
rtsp-reconnect-interval-sec=3
rtsp-reconnect-attempts=-1
select-rtp-protocol=4
[source1]
enable=0
type=3
num-sources=1
gpu-id=0
cudadec-memtype=0
latency=10
[source2]
enable=0
type=3
num-sources=1
gpu-id=0
cudadec-memtype=0
latency=10
[source3]
enable=0
type=3
num-sources=1
gpu-id=0
cudadec-memtype=0
latency=10
[user-plugin]
enable=1
gpu-id=0
app-config-path=configs/vpd/appConfig.json
nvbuf-memory-type=3
[sink0]
enable=1
#Type - 1=FakeSink 2=EglSink 3=File 4=RTSPStreaming
type=4
#1=h264 2=h265
codec=2
sync=1
source-id=0
bitrate=50000
# set below properties in case of RTSPStreaming
rtsp-port=8554
udp-port=5400
width=1000
height=1000
enc-type=0
[sink1]
enable=1
type=3
output-file=./out%05d.mp4
#1=h264 2=h265
codec=2
sync=0
source-id=0
bitrate=5000000
#1=mp4 2=mkv
container=1
width=2736
height=2736
enc-type=1
max-size-bytes=100000000
max-size-time=0
[osd]
enable=0
gpu-id=0
border-width=3
text-size=15
text-color=1;1;1;1;
text-bg-color=0.3;0.3;0.3;1
font=Serif
show-clock=0
clock-x-offset=800
clock-y-offset=820
clock-text-size=12
clock-color=1;0;0;0
nvbuf-memory-type=0
[streammux]
gpu-id=0
##Boolean property to inform muxer that sources are live
live-source=0
batch-size=1
##time out in usec, to wait after the first buffer is available
##to push the batch even if the complete batch is not formed
batched-push-timeout=100000
## Set muxer output width and height
width=2736
height=2736
##Enable to maintain aspect ratio wrt source, and allow black borders, works
##along with width, height properties
enable-padding=0
nvbuf-memory-type=0
buffer-pool-size=4
drop-pipeline-eos=1
# config-file property is mandatory for any gie section.
# Other properties are optional and if set will override the properties set in
# the infer config file.
[primary-gie]
enable=1
gpu-id=0
batch-size=4
gie-unique-id=1
nvbuf-memory-type=0
config-file=config_infer_primary_yoloV4.txt
[tracker]
enable=1
tracker-width=1280
tracker-height=1280
ll-lib-file=/opt/nvidia/deepstream/deepstream/lib/libnvds_nvmultiobjecttracker.so
ll-config-file=config_tracker_NvDCF.yml
#ll-config-file=config_tracker_DeepSORT.yml
display-tracking-id=1
[tests]
file-loop=1
- This is my update to use Splitmuxsink in deepstream_sink_bin.c:
* Function to create sink bin to generate encoded output.
static gboolean
create_encode_file_bin (NvDsSinkEncoderConfig * config, NvDsSinkBinSubBin * bin)
GstCaps *caps = NULL;
gboolean ret = FALSE;
gchar elem_name[50];
int probe_id = 0;
gulong bitrate = config->bitrate;
guint profile = config->profile;
const gchar * latency = g_getenv("NVDS_ENABLE_LATENCY_MEASUREMENT");
uid++;
g_snprintf (elem_name, sizeof (elem_name), "sink_sub_bin%d", uid);
bin->bin = gst_bin_new (elem_name);
if (!bin->bin) {
NVGSTDS_ERR_MSG_V ("Failed to create '%s'", elem_name);
goto done;
g_snprintf (elem_name, sizeof (elem_name), "sink_sub_bin_queue%d", uid);
bin->queue = gst_element_factory_make (NVDS_ELEM_QUEUE, elem_name);
if (!bin->queue) {
goto done;
g_snprintf (elem_name, sizeof (elem_name), "sink_sub_bin_transform%d", uid);
bin->transform = gst_element_factory_make (NVDS_ELEM_VIDEO_CONV, elem_name);
if (!bin->transform) {
goto done;
g_snprintf (elem_name, sizeof (elem_name), "sink_sub_bin_cap_filter%d", uid);
bin->cap_filter = gst_element_factory_make (NVDS_ELEM_CAPS_FILTER, elem_name);
if (!bin->cap_filter) {
goto done;
if (config->codec == NV_DS_ENCODER_MPEG4
|| config->enc_type == NV_DS_ENCODER_TYPE_SW)
caps = gst_caps_from_string ("video/x-raw, format=I420");
else
caps = gst_caps_from_string ("video/x-raw(memory:NVMM), format=I420");
g_object_set (G_OBJECT (bin->cap_filter), "caps", caps, NULL);
g_snprintf (elem_name, sizeof (elem_name), "sink_sub_bin_encoder%d", uid);
switch (config->codec) {
case NV_DS_ENCODER_H264:
if (config->enc_type == NV_DS_ENCODER_TYPE_SW)
bin->encoder =
gst_element_factory_make (NVDS_ELEM_ENC_H264_SW, elem_name);
else
bin->encoder =
gst_element_factory_make (NVDS_ELEM_ENC_H264_HW, elem_name);
break;
case NV_DS_ENCODER_H265:
bin->encoder =
gst_element_factory_make (NVDS_ELEM_ENC_H265_SW, elem_name);
else
bin->encoder =
gst_element_factory_make (NVDS_ELEM_ENC_H265_HW, elem_name);
break;
case NV_DS_ENCODER_MPEG4:
bin->encoder = gst_element_factory_make (NVDS_ELEM_ENC_MPEG4, elem_name);
break;
default:
goto done;
if (!bin->encoder) {
goto done;
NVGSTDS_ELEM_ADD_PROBE (probe_id,
bin->encoder, "sink",
seek_query_drop_prob, GST_PAD_PROBE_TYPE_QUERY_UPSTREAM, bin);
probe_id = probe_id;
if (config->codec == NV_DS_ENCODER_MPEG4)
config->enc_type = NV_DS_ENCODER_TYPE_SW;
struct cudaDeviceProp prop;
cudaGetDeviceProperties (&prop, config->gpu_id);
if (config->copy_meta == 1) {
g_object_set (G_OBJECT (bin->encoder), "copy-meta", TRUE, NULL);
if (config->enc_type == NV_DS_ENCODER_TYPE_HW) {
switch (config->output_io_mode) {
case NV_DS_ENCODER_OUTPUT_IO_MODE_MMAP:
default:
g_object_set (G_OBJECT (bin->encoder), "output-io-mode",
NV_DS_ENCODER_OUTPUT_IO_MODE_MMAP, NULL);
break;
case NV_DS_ENCODER_OUTPUT_IO_MODE_DMABUF_IMPORT:
NV_DS_ENCODER_OUTPUT_IO_MODE_DMABUF_IMPORT, NULL);
break;
g_object_set (G_OBJECT (bin->encoder), "profile", profile, NULL);
g_object_set (G_OBJECT (bin->encoder), "iframeinterval",
config->iframeinterval, NULL);
g_object_set (G_OBJECT (bin->encoder), "bitrate", bitrate, NULL);
} else {
else {
//bitrate is in kbits/sec for software encoder x264enc and x265enc
g_object_set (G_OBJECT (bin->encoder), "bitrate", bitrate / 1000, NULL);
g_object_set (G_OBJECT (bin->encoder), "speed-preset", config->sw_preset, NULL);
bin->codecparse = gst_element_factory_make ("h264parse", "h264-parser");
break;
bin->codecparse = gst_element_factory_make ("h265parse", "h265-parser");
break;
bin->codecparse =
gst_element_factory_make ("mpeg4videoparse", "mpeg4-parser");
break;
default:
goto done;
g_snprintf (elem_name, sizeof (elem_name), "sink_sub_bin_mux%d", uid);
//disabling the mux when latency measurement logs are enabled
if (latency) {
bin->mux = gst_element_factory_make (NVDS_ELEM_IDENTITY, elem_name);
else {
switch (config->container) {
case NV_DS_CONTAINER_MP4:
bin->mux = gst_element_factory_make (NVDS_ELEM_MUX_MP4, elem_name);
break;
case NV_DS_CONTAINER_MKV:
bin->mux = gst_element_factory_make (NVDS_ELEM_MKV, elem_name);
break;
default:
goto done;
if (!bin->mux) {
goto done;
g_snprintf (elem_name, sizeof (elem_name), "sink_sub_bin_sink%d", uid);
#ifdef USE_SPLITMUXSINK
bin->sink = gst_element_factory_make (NVDS_ELEM_SINK_SPLITMUX, elem_name);
#else
bin->sink = gst_element_factory_make (NVDS_ELEM_SINK_FILE, elem_name);
#endif
if (!bin->sink) {
goto done;
g_object_set (G_OBJECT (bin->sink), "max-size-bytes", config->max_size_bytes,
"max-size-time", config->max_size_time, "muxer", bin->mux, NULL);
g_object_set (G_OBJECT (bin->sink), "location", config->output_file_path,NULL);
#else
"sync", config->sync, "async", FALSE, NULL);
#endif
g_object_set (G_OBJECT (bin->transform), "gpu-id", config->gpu_id, NULL);
gst_bin_add_many (GST_BIN (bin->bin), bin->queue,
bin->transform, bin->codecparse, bin->cap_filter,
bin->encoder, bin->sink, NULL);
#else
bin->encoder, bin->mux, bin->sink, NULL);
#endif
NVGSTDS_LINK_ELEMENT (bin->queue, bin->transform);
NVGSTDS_LINK_ELEMENT (bin->transform, bin->cap_filter);
NVGSTDS_LINK_ELEMENT (bin->cap_filter, bin->encoder);
NVGSTDS_LINK_ELEMENT (bin->encoder, bin->codecparse);
NVGSTDS_LINK_ELEMENT (bin->codecparse, bin->sink);
#else
NVGSTDS_LINK_ELEMENT (bin->codecparse, bin->mux);
NVGSTDS_LINK_ELEMENT (bin->mux, bin->sink);
#endif
NVGSTDS_BIN_ADD_GHOST_PAD (bin->bin, bin->queue, "sink");
ret = TRUE;
done:
if (caps) {
gst_caps_unref (caps);
if (!ret) {
NVGSTDS_ERR_MSG_V ("%s failed", __func__);
return ret;
Thank you for your support!
