AMD
• DeepStream Version
deepstream-6.1
• TensorRT Version
tensorrt 8.6.1.6-1+cuda12.0
Driver Version: 530.30.02
bug
I have a C++ code where I’m inserting images from a camera into a pipeline and receiving them at the end with detections. I want to manually modify the timestamp (PTS). The issue arises because I initially read the PTS as a constant at the insertion point, and when I change it, it doesn’t seem to reflect on the other end. The PTS timestamp that I read at the end of the pipeline consistently increases. How can I effectively change the PTS so that I can observe the modifications at the end of the pipeline? Here’s a snippet of the code:
SINK:
if (sample) {
/* Obtain GstBuffer from sample and then extract metadata from it. */
buf = gst_sample_get_buffer (sample);
NvDsBatchMeta *batch_meta = gst_buffer_get_nvds_batch_meta (buf);
std::cout << "pts is " << GST_BUFFER_PTS(buf) << std::endl;
for (l_frame = batch_meta->frame_meta_list; l_frame != NULL;
l_frame = l_frame->next) {
NvDsFrameMeta *frame_meta = (NvDsFrameMeta *) (l_frame->data);
// int offset = 0;
for (l_obj = frame_meta->obj_meta_list; l_obj != NULL;
l_obj = l_obj->next) {
obj_meta = (NvDsObjectMeta *) (l_obj->data);
if (obj_meta->class_id == PGIE_CLASS_ID_ORANGE) {
orange_count++;
num_rects++;
SOURCE:
buffer = create_gst_buffer_from_opencv_image(img);
if (buffer) {
GST_BUFFER_TIMESTAMP(buffer) = 100;
std::cout << "pts beforeeee is " << GST_BUFFER_PTS(buffer) << std::endl;
GstFlowReturn gstret = gst_app_src_push_buffer((GstAppSrc *) data->app_source, buffer);
if (gstret != GST_FLOW_OK) {
g_print("gst_app_src_push_buffer returned %d \n", gstret);
i get:
pts beforeeee is 100
pts is 5699999943
Top Left: (272.6, 247.9)
Width: 145.0, Height: 146.3
FPS: 30.06
Frame Number = 172 Number of objects = 1 Count = 1
pts is 5733333276
FPS: 30.07
Frame Number = 173 Number of objects = 1 Count = 1
pts is 5766666609
FPS: 30.06
Frame Number = 174 Number of objects = 1 Count = 1
pts is 5799999942
FPS: 30.06
Frame Number = 175 Number of objects = 1 Count = 1
pts is 5833333275
FPS: 30.06
Frame Number = 176 Number of objects = 1 Count = 1
pts is 5866666608
FPS: 30.06
Frame Number = 177 Number of objects = 1 Count = 1
pts is 5899999941
FPS: 30.06
Frame Number = 178 Number of objects = 1 Count = 1
