I’m trying to use libnvjpeg directly to decode some JPEG image.
I don’t want to use gstreamer because neither jpegdec nor nvjpegdec is able to give me the decoded image in the original pixel format.
I have a JPEG image that is 1920*1080, encoded as YUV422 planar.
So I wrote a test program that will decode using jpeg_read_raw_data() calls. It works fine when I compile and link it with the regular libjpeg, but segfaults when I compile and link it with libnvjpeg.
Here is the test image: https://www.dropbox.com/s/gacnmdyrnufgbol/yuv422_planar.jpg?dl=0
And here is the source code:
* To compile:
* 1. Download the gstjpeg source tar ball:
* $ cd && wget http://developer.nvidia.com/embedded/dlc/l4t-Jetson-TK1-Gstjpeg-Sources-R21-5
* 2. Untar it:
* $ tar -xjf gstjpeg_src.tbz2
* 3. Compile the test program:
* $ g++-4.8 -std=c++11 -o tegrajpeg_raw_accelerated tegrajpeg_raw.cpp -I/home/ubuntu/gstjpeg_src/nv_headers -L/usr/lib/arm-linux-gnueabihf/tegra/ -lnvjpeg -O3
* or
* $ g++-4.8 -std=c++11 -o tegrajpeg_raw tegrajpeg_raw.cpp -ljpeg -O3
/* Standard library */
#include <chrono>
#include <cstring>
#include <fstream>
#include <iostream>
#include <iterator>
#include <memory>
#include <string>
#include <vector>
/* libjpeg */
#include "jpeglib.h"
using namespace std;
using namespace ::std::chrono;
vector<char> read_jpg_file() {
string filepath{"/home/ubuntu/yuv422_planar.jpg"};
vector<char> jpg_buffer;
ifstream jpg_file(filepath, ios::binary | ios::ate);
if (jpg_file.is_open()) {
jpg_buffer.reserve(jpg_file.tellg());
jpg_file.seekg(0, ios::beg);
jpg_buffer.assign(istreambuf_iterator<char>(jpg_file), istreambuf_iterator<char>());
jpg_file.close();
else {
cerr << "Error reading yuv422_planar.jpg!" << endl;
return jpg_buffer;
int main(int argc, char** argv) {
// read a jpeg file
vector<char> jpg_buffer = read_jpg_file(); //<char> because ifstream works with char, not unsigned char. :(
unsigned char* output_buffer = new unsigned char[1920 * 1080 * 2];
int i, j;
unsigned char**lines[3];
unsigned char*y[4 * DCTSIZE] = {NULL, };
unsigned char*u[4 * DCTSIZE] = {NULL, };
unsigned char*v[4 * DCTSIZE] = {NULL, };
int v_samp[3];
unsigned char *base[3], *last[3];
// How many bytes per row of Y, U, and V data.
const int stride[3] = {1920, 960, 960};
const unsigned int height{1080};
lines[0] = y;
lines[1] = u;
lines[2] = v;
struct jpeg_decompress_struct cinfo;
struct jpeg_error_mgr jerr;
cinfo.err = jpeg_std_error(&jerr);
jpeg_create_decompress(&cinfo);
jpeg_mem_src(&cinfo, reinterpret_cast<unsigned char*>(jpg_buffer.data()), jpg_buffer.size());
jpeg_read_header(&cinfo, true);
cinfo.raw_data_out = 1;
jpeg_start_decompress(&cinfo);
v_samp[0] = cinfo.comp_info[0].v_samp_factor;
v_samp[1] = cinfo.comp_info[1].v_samp_factor;
v_samp[2] = cinfo.comp_info[2].v_samp_factor;
// Starting positions of the Y, U, and V components in the output_buffer
base[0] = output_buffer; // Y
base[1] = base[0] + 1920 * 1080; // U
base[2] = base[1] + 960 * 1080; // V
for (i = 0; i < height; i += v_samp[0] * DCTSIZE) {
for (j = 0; j < (v_samp[0] * DCTSIZE); j++) {
lines[0][j] = base[0] + (i + j) * stride[0];
lines[1][j] = base[1] + (i + j) * stride[1];
lines[2][j] = base[2] + (i + j) * stride[2];
jpeg_read_raw_data(&cinfo, lines, v_samp[0] * DCTSIZE);
jpeg_finish_decompress(&cinfo);
ofstream out_yuv{"/home/ubuntu/out.yuv", ::std::ios::out | ::std::ios::binary};
out_yuv.write(reinterpret_cast<const char*>(output_buffer), 1920 * 1080 * 2);
out_yuv.close();
jpeg_destroy_decompress(&cinfo);
delete[] output_buffer;
Could somebody take a look and tell me why the libnvjpeg version would segfault? I looked at the gstreamer plug-in source code and I don’t see anything special there, so I don’t understand why it segfaults when I try to use libnvjpeg in my own code.
