Problems with deepstream reading local images
orin
• DeepStream Version
6.1
35.1.0
• TensorRT Version
8.5
Use DeepStream to read a local JPEG image and display only the first image locally。
the code is ::
int main ()
guint bus_watch_id;
GstElement *pipeline,*bin,*parser,*decoder, *streammux, *nvvidconv, *transform,*sink,*filter2,*convert3,*tiler,*nvdslogger, *seg,*nvsegvisual,*tee, *nvvidconv1,*sink1 ,*nvinfer,*nvosd;
GMainLoop *loop = NULL;
GstBus *bus;
CustomData data1;
gst_init (NULL, NULL);
loop = g_main_loop_new (NULL, FALSE);
pipeline = gst_pipeline_new (“dstensor-pipeline”);
GstElement *queue1, *queue2, *queue3;
queue1 = gst_element_factory_make (“queue”, “queue1”);
queue2 = gst_element_factory_make (“queue”, “queue2”);
queue3 = gst_element_factory_make (“queue”, “queue3”);
////—0
bin=gst_bin_new (“new-bin”);
data1.source = gst_element_factory_make (“multifilesrc”, “file-source0”);
parser = gst_element_factory_make (“jpegparse”, “jpeg-parser0”);
decoder = gst_element_factory_make (“nvv4l2decoder”, “nvv4l2-decoder0”);
////—1
streammux = gst_element_factory_make (“nvstreammux”, “stream-muxer”);
nvdslogger = gst_element_factory_make (“nvdslogger”, “nvdslogger”);
transform = gst_element_factory_make(“nvegltransform”, “transform”);
nvvidconv = gst_element_factory_make (“nvvideoconvert”, “nvvideo-converter”);
sink = gst_element_factory_make (“nveglglessink”, “nvvideo-renderer”);
gst_bin_add_many (GST_BIN (bin),data1.source, parser, decoder, NULL);
GstPad *source_pad = gst_element_get_static_pad(decoder, “src”);
gst_element_add_pad(bin,gst_ghost_pad_new(“src”,source_pad));
seg = gst_element_factory_make (“nvinfer”, “primary-nvinference-engine”);
g_object_set (G_OBJECT (seg),
“config-file-path”, “hdmapnet.txt”, NULL);
nvsegvisual = gst_element_factory_make (“nvsegvisual”, “nvsegvisual”);
g_object_set (G_OBJECT (nvsegvisual), “batch-size”, 1, NULL);
g_object_set (G_OBJECT (nvsegvisual), “width”, 800, NULL);
g_object_set (G_OBJECT (nvsegvisual), “height”, 400, NULL);
nvosd = gst_element_factory_make (“nvdsosd”, “nv-onscreendisplay”);
if (!gst_element_link_many (data1.source, parser, decoder, NULL))
g_printerr (“Elements could not be linked: 0. Exiting.\n”);
return -1;
gst_bin_add_many (GST_BIN (pipeline),bin,streammux,queue1,nvdslogger,queue2,queue3,
nvvidconv, transform, sink,NULL);
if (!pipeline||!data1.source || !parser || !decoder||!streammux || !nvvidconv ||!transform ) {
g_printerr (“One element could not be created. Exiting.\n”);
return -1;
g_object_set(G_OBJECT(data1.source), “location”,“/home/titan/detetct_image/image_%d.jpeg”, NULL);
g_object_set(G_OBJECT( streammux),“width”,1024,“height”,1024, “batch-size”, 1, “batched-push-timeout”, MUXER_BATCH_TIMEOUT_USEC,NULL);
g_object_set (G_OBJECT(sink), “sync”, FALSE, NULL);
// g_object_set (G_OBJECT (sink), “qos”, 0, NULL);
GstPad *sinkpad,*srcpad;
gchar pad_name_src[16] = “src”;
gchar pad_name_sink[16] = “sink_0”;
srcpad = gst_element_get_static_pad (bin, pad_name_src);
if (!srcpad) {
g_printerr (“Decoder request src pad failed. Exiting.\n”);
return -1;
sinkpad = gst_element_get_request_pad (streammux, pad_name_sink);
if (!sinkpad) {
g_printerr (“Streammux request sink pad failed. Exiting.\n”);
return -1;
if (gst_pad_link (srcpad, sinkpad) != GST_PAD_LINK_OK) {
g_printerr (“Failed to link decoder to stream muxer1. Exiting.\n”);
return -1;
if (!gst_element_link_many (streammux,queue1,nvdslogger,queue2,queue3,nvvidconv,transform, sink,NULL)) {
g_printerr (“Elements could not be linked: 2. Exiting.\n”);
return -1;
//进行 修改图像
//GstPad *tiler_src_pad =gst_element_get_static_pad(data1.source,“src”);
//gst_pad_add_probe (tiler_src_pad, GST_PAD_PROBE_TYPE_BUFFER,seg_src_pad_buffer_probe, &data1, NULL); //模型推理的输出
GstPad *tiler_src_pad_s =gst_element_get_static_pad (streammux,“src”);
gst_pad_add_probe (tiler_src_pad_s, GST_PAD_PROBE_TYPE_BUFFER,tile_sink_pad_buffer_probe, NULL, NULL);
//GstPad *tiler_src_pad_s =gst_element_get_static_pad ( nvosd,“sink”);
//gst_pad_add_probe (tiler_src_pad_s, GST_PAD_PROBE_TYPE_BUFFER,nvinfer_src_pad_buffer_probe1, NULL, NULL); //修改了图像大小
//GstPad *tiler_src_pad_c =gst_element_get_static_pad (nvdslogger,“sink”);
//gst_pad_add_probe (tiler_src_pad_c, GST_PAD_PROBE_TYPE_BUFFER,nvinfer_src_pad_buffer_probe1, NULL, NULL);
GST_DEBUG_BIN_TO_DOT_FILE(GST_BIN (pipeline),
GST_DEBUG_GRAPH_SHOW_ALL, “pipeline-playing”);
gst_element_set_state (pipeline, GST_STATE_PLAYING);
bus = gst_pipeline_get_bus (GST_PIPELINE (pipeline));
bus_watch_id = gst_bus_add_watch (bus, bus_call, loop);
gst_object_unref (bus);
/* Iterate */
g_print (“Running…\n”);
g_main_loop_run (loop);
/* Out of the main loop, clean up nicely */
g_print (“Returned, stopping playback\n”);
gst_element_set_state (pipeline, GST_STATE_NULL);
g_print (“Deleting pipeline\n”);
gst_object_unref (GST_OBJECT (pipeline));
g_source_remove (bus_watch_id);
g_main_loop_unref (loop);
return 0;
please refer to sample deepstream-image-decode-test in DS6.1 or deepstream-can-orientation-app in DS6.2, they all use multifilesrc to read jpeg files.
I refer to his , only I read the folder. The image is named image_0.jpeg~image_734.jpeg
can you share the error logs and configurations?
reading jpeg files is in Gstreamer 's code, please refer to gst-plugins-good/gstmultifilesrc.c at master · Kurento/gst-plugins-good · GitHub
The code runs smoothly, but only shows the first image。
v4l2_test2.cpp (4.9 KB)
new_image.zip (57.1 MB)
The problem is seen through DEBUG ::v4l2 gstv4l2object.c:4481:gst_v4l2_object_probe_caps:nvv4l2-decoder0:src Failed to probe pixel aspect ratio with VIDIOC_CROPCAP: Unknown error -1。
How to solve?
please ignore this debug log.
you can open Gstreamer debug log by doing “export GST_DEBUG=6”, then check if multifilesrc is reading jpg file one by one, here is the keyword “reading from file”, please refer to gst-plugins-good/gstmultifilesrc.c at master · GStreamer/gst-plugins-good · GitHub
I used nvjpegdec instead of nvv4l2decoder, which can be displayed. But when the split network is inserted, an error is displayed. ERROR jpegdec gstjpegdec.c:1147:gst_jpeg_dec_negotiate: Empty caps
what do you mean about “split network is inserted”? please refer to the following pipelines, they work fine.
gst-launch-1.0 filesrc location=test_sample_0043.jpg ! nvjpegdec ! nvvideoconvert ! ‘video/x-raw,format=NV12’ ! jpegenc ! filesink location=7.jpeg
or
gst-launch-1.0 multifilesrc location=/home/movies/pic/dump265jpg/“h265frame%d.jpg” index=0 caps=“image/jpeg,framerate=(fraction)20/1” ! jpegdec ! videoconvert ! ‘video/x-raw,format=I420’ ! nvvideoconvert nvbuf-memory-type=3 ! ‘video/x-raw(memory:NVMM),format=NV12’ ! mux.sink_0 nvstreammux name=mux batch-size=1 width=1920 height=1080 nvbuf-memory-type=3 ! nvinfer config-file-path=./pgie_peopleSegNetv2_tao_config.txt ! nvvideoconvert ! ‘video/x-raw(memory:NVMM),format=RGBA’ ! nvdsosd ! fakesink.
This is my flowchart for gstreamer
Running the following commands should work:
gst-launch-1.0 multifilesrc location=/home/titan/detetct_image/“image_%d.jpeg” index=0 ! jpegdec ! videoconvert ! ‘video/x-raw,format=I420’ ! nvvideoconvert ! ‘video/x-raw(memory:NVMM),format=NV12’ ! mux.sink_0 nvstreammux name=mux batch-size=1 width=1024 height=1024 ! nvdslogger ! nvinfer config-file-path=/home/titan/deepstream_cui/build/hdmapnet.txt ! nvsegvisual ! nvvideoconvert ! nvegltransform ! nveglglessink
Sorry for the late reply, Is this still an DeepStream issue to support?
