Multifilestrc ds 6.1 and ds6.2
Jetson
• DeepStream Version
6.1 and 6.2
5.0.2 and 5.1
bugs
Hi, I have a sample app that uses multifilesrc, jpegparse, and nvv4l2decoder to process a folder of images. This version of the app works on DeepStream 5.0 and 6.0, but it shows the following errors on DeepStream 6.1 and 6.2:
[NvTiler::CheckVICMaxScaleFactorCompatibility] ERROR: Scaling requested from [4096 X 2160] to [458315037 X -180471528] exceeds max scaling factor (16.000000) supported by VIC
[NvTiler::CheckVICMaxScaleFactorCompatibility] Please use a larger tiled window resolution or reduce number of streams
0:00:03.799784567 10583 0xaaab0213d300 WARN                 nvinfer gstnvinfer.cpp:2369:gst_nvinfer_output_loop:<primary-nvinference-engine> error: Internal data stream error.
0:00:03.799807928 10583 0xaaab0213d300 WARN                 nvinfer gstnvinfer.cpp:2369:gst_nvinfer_output_loop:<primary-nvinference-engine> error: streaming stopped, reason error (-5)
nvstreammux: Successfully handled EOS for source_id=65535
the code:
 * Copyright (c) 2019-2020, NVIDIA CORPORATION. All rights reserved.
 * Permission is hereby granted, free of charge, to any person obtaining a
 * copy of this software and associated documentation files (the "Software"),
 * to deal in the Software without restriction, including without limitation
 * the rights to use, copy, modify, merge, publish, distribute, sublicense,
 * and/or sell copies of the Software, and to permit persons to whom the
 * Software is furnished to do so, subject to the following conditions:
 * The above copyright notice and this permission notice shall be included in
 * all copies or substantial portions of the Software.
 * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
 * IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
 * FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT.  IN NO EVENT SHALL
 * THE AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
 * LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING
 * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER
 * DEALINGS IN THE SOFTWARE.
// #include <gst/gst.h>
// #include <glib.h>
#ifndef PLATFORM_TEGRA
#include "gst-nvmessage.h"
#endif
#include "gstnvdsmeta.h"
#include <array>
#include <boost/property_tree/ini_parser.hpp>
#include <boost/property_tree/ptree.hpp>
#include <cstdlib>
#include <dirent.h>
#include <glib.h>
#include <glob.h>
#include <iostream>
#include <iterator>
#include <list>
#include <math.h>
#include <memory>
#include <stdio.h>
#include <string.h>
#include <string>
#include <sys/stat.h>
#include <sys/time.h>
#include <sys/types.h>
#include <unistd.h>
#include <vector>
#include <thread>
#include <boost/algorithm/string.hpp>
// #include <memory>
std::string input_path;
#endif
#define MAX_DISPLAY_LEN 64
double intersection_threshold;
int big_counter = 0;
/* Muxer batch formation timeout, for e.g. 40 millisec. Should ideally be set
 * based on the fastest source's framerate. */
#define MUXER_BATCH_TIMEOUT_USEC 40000
// #define MEMORY_FEATURES "memory:NVMM"
#include <cuda_runtime_api.h>
#include "nvbufsurface.h"
/* NVIDIA Decoder source pad memory feature. This feature signifies that source
 * pads having this capability will push GstBuffers containing cuda buffers. */
#define GST_CAPS_FEATURES_NVMM "memory:NVMM"
#define CONFIG_FILE_VW "config/config_vw_detection.txt"
// static struct timeval start_time = { };
// static guint probe_counter = 0;
/* tiler_sink_pad_buffer_probe  will extract metadata received on OSD sink pad
 * and update params for drawing rectangle, object information etc. */
using namespace std;
/*static clock_t start_time = NULL;
list<int> full_list;
int count_array = 0;
static int count = 0;
int a[20];
gint frame_number = 0;
int counter = 0;
// #TODO remove hardcoded lines
static GstElement *create_source_bin(guint index, gchar *uri)
  GstElement *bin = NULL /*, *uri_decode_bin = NULL*/;
  gchar bin_name[16] = {};
  gboolean multi_file_src = FALSE;
  g_snprintf(bin_name, 15, "source-bin-%02d", index);
  /* Create a source GstBin to abstract this bin's content from the rest of the
   * pipeline */
  bin = gst_bin_new(bin_name);
  GstElement *source, *jpegparser, *decoder;
  if (strstr(uri, "%"))
    source = gst_element_factory_make("multifilesrc", "source");
    multi_file_src = TRUE;
  else
    source = gst_element_factory_make("filesrc", "source");
  jpegparser = gst_element_factory_make("jpegparse", "jpeg-parser");
  decoder = gst_element_factory_make("nvv4l2decoder", "nvv4l2-decoder");
  if (!source || !jpegparser || !decoder)
    return NULL;
    /* Set properties of the multifilesrc element */
    GstCaps *caps =
        gst_caps_new_simple("image/jpeg", "format", G_TYPE_STRING, "RGBA",
                            "framerate", GST_TYPE_FRACTION, 35, 1, NULL);
    // GstCapsFeatures *feature = gst_caps_features_new (GST_CAPS_FEATURES_NVMM,
    // NULL); gst_caps_set_features (caps, 0, feature);
    g_object_set(G_OBJECT(source), "location", uri, "caps", caps, NULL);
  else
    g_object_set(G_OBJECT(source), "location", uri, NULL);
  const char *dot = strrchr(uri, '.');
  if ((!strcmp(dot + 1, "mjpeg")) || (!strcmp(dot + 1, "mjpg")) ||
      (multi_file_src == TRUE))
#ifdef PLATFORM_TEGRA
    g_object_set(G_OBJECT(decoder), "mjpeg", 1, NULL);
#endif
  gst_bin_add_many(GST_BIN(bin), source, jpegparser, decoder, NULL);
  gst_element_link_many(source, jpegparser, decoder, NULL);
  /* We need to create a ghost pad for the source bin which will act as a proxy
   * for the video decoder src pad. The ghost pad will not have a target right
   * now. Once the decode bin creates the video decoder and generates the
   * cb_newpad callback, we will set the ghost pad target to the video decoder
   * src pad. */
  if (!gst_element_add_pad(bin,
                           gst_ghost_pad_new_no_target("src", GST_PAD_SRC)))
    return NULL;
  GstPad *srcpad = gst_element_get_static_pad(decoder, "src");
  if (!srcpad)
    return NULL;
  GstPad *bin_ghost_pad = gst_element_get_static_pad(bin, "src");
  if (!gst_ghost_pad_set_target(GST_GHOST_PAD(bin_ghost_pad), srcpad))
      return NULL;
  return bin;
bool Is_path_exist(const std::string &s)
  struct stat buffer;
  return (stat(s.c_str(), &buffer) == 0);
std::string get_image_name(std::string image_name)
  std::string cmd = "find " + input_path + " -samefile " +
                    input_path + "/tmp/" + image_name;
  std::array<char, 128> buffer;
  std::string result;
  std::unique_ptr<FILE, decltype(&pclose)> pipe(popen(cmd.c_str(), "r"),
                                                pclose);
  if (!pipe)
    throw std::runtime_error("popen() failed!");
  while (fgets(buffer.data(), buffer.size(), pipe.get()) != nullptr)
    std::string buffer_data = buffer.data();
    if (buffer_data.find(image_name) == std::string::npos)
      result += buffer.data();
  return result;
std::string exec(const char *cmd)
  std::string result;
  std::unique_ptr<FILE, decltype(&pclose)> pipe(popen(cmd, "r"), pclose);
  if (!pipe)
  return result;
static GstPadProbeReturn tiler_src_pad_buffer_probe(GstPad *pad,
                                                    GstPadProbeInfo *info,
                                                    gpointer u_data)
  NvDsFrameMeta *frame_meta = NULL;
  GstBuffer *buf = (GstBuffer *)info->data;
  guint num_rects = 0;
  NvDsObjectMeta *obj_meta = NULL;
  NvDsMetaList *l_frame = NULL;
  NvDsMetaList *l_obj = NULL;
  NvDsClassifierMetaList *l_classifier = NULL;
  NvDsClassifierMeta *class_meta = NULL;
  NvDsLabelInfoList *l_label = NULL;
  NvDsLabelInfo *label_info = NULL;
  NvDsBatchMeta *batch_meta = gst_buffer_get_nvds_batch_meta(buf);
  std::string image_name = "";
  std::cout<<"do nothing "<<std::endl;
  return GST_PAD_PROBE_OK;
static gboolean bus_call(GstBus *bus, GstMessage *msg, gpointer data)
  GMainLoop *loop = (GMainLoop *)data;
  switch (GST_MESSAGE_TYPE(msg))
  case GST_MESSAGE_EOS:
    // loggger.log_info("bus_call", class_name, 22012);
    g_main_loop_quit(loop);
    break;
  case GST_MESSAGE_WARNING:
    gchar *debug;
    GError *error;
    gst_message_parse_warning(msg, &error, &debug);
    g_free(debug);
    // loggger.log_warning(GST_OBJECT_NAME(msg->src),
    //                     class_name, 22507, error->message);
    g_error_free(error);
    break;
  case GST_MESSAGE_INFO:
    gchar *debug;
    GError *error;
    gst_message_parse_info(msg, &error, &debug);
    g_free(debug);
    break;
  case GST_MESSAGE_ERROR:
    gchar *debug;
    GError *error;
    gst_message_parse_error(msg, &error, &debug);
    // loggger.log_error(GST_OBJECT_NAME(msg->src),
    //                   class_name, 22610, error->message);
    if (debug)
      g_free(debug);
    break;
  case GST_MESSAGE_ELEMENT:
    if (gst_nvmessage_is_stream_eos(msg))
      guint stream_id;
      if (gst_nvmessage_parse_stream_eos(msg, &stream_id))
        g_print("Got EOS from stream %d\n", stream_id);
    break;
#endif
  default:
    break;
  return TRUE;
int main(int argc, char *argv[])
  GMainLoop *loop = NULL;
  GstElement *pipeline = NULL, *streammux = NULL, *sink = NULL,
             *vw_detection = NULL, *nvvidconv = NULL, *nvosd = NULL,
             *tiler = NULL;
  GstElement *transform = NULL;
#endif
  GstBus *bus = NULL;
  guint bus_watch_id;
  GstPad *tiler_src_pad = NULL;
  guint i, num_sources;
  guint tiler_rows, tiler_columns;
  guint pgie_batch_size;
  // commint
  // loggger.init_logging();
  int current_device = -1;
  cudaGetDevice(&current_device);
  struct cudaDeviceProp prop;
  cudaGetDeviceProperties(&prop, current_device);
  input_path = "/opt/nvidia/deepstream/deepstream-6.2/app/test/input/";
  std::string app_path = "/opt/nvidia/deepstream/deepstream-6.2/app/test";
  /* Standard GStreamer initialization */
  gst_init(&argc, &argv);
  loop = g_main_loop_new(NULL, FALSE);
  /* Create gstreamer elements */
  /* Create Pipeline element that will form a connection of other elements */
  pipeline = gst_pipeline_new("pipeline");
  /* Create nvstreammux instance to form batches from one or more sources. */
  streammux = gst_element_factory_make("nvstreammux", "stream-muxer");
  if (!pipeline || !streammux)
    return -1;
  if (!streammux)
    return -1;
  gst_bin_add(GST_BIN(pipeline), streammux);
  /* Read Settings file */
  char tmp[256];
  getcwd(tmp, 256);
  // Input Preprocessing
  gchar *image_folder = new char[input_path.length() + 1];
  strcpy(image_folder, input_path.c_str());
  chdir(image_folder);
  char s[100];
  printf("%s\n", getcwd(s, 100));
  exec("mkdir tmp");
  exec("curIdx=0; for curFile in  *.jpg; do  outFile=`printf "
       "\"./tmp/img_%04d.jpg\" \"$curIdx\"`; echo \'File: \'$curFile \'->\' "
       "$outFile; ln $curFile $outFile; curIdx=`expr $curIdx + 1 `; done");
  chdir(app_path.c_str());
  input_path = input_path + "tmp/";
  /*Create full input Path */
  std::string inputFormat_ = "img_%04d.jpg";
  std::string full_path_tmp = input_path + inputFormat_;
  gchar *image_file = new char[full_path_tmp.length() + 1];
  strcpy(image_file, full_path_tmp.c_str());
  GstPad *sinkpad, *srcpad;
  gchar pad_name[16] = {};
  GstElement *source_bin = create_source_bin(0, image_file);
  // log number of images of the input path
  if (!source_bin)
    return -1;
  gst_bin_add(GST_BIN(pipeline), source_bin);
  g_snprintf(pad_name, 15, "sink_%u", i);
  sinkpad = gst_element_get_request_pad(streammux, pad_name);
  if (!sinkpad)
    return -1;
  srcpad = gst_element_get_static_pad(source_bin, "src");
  if (!srcpad)
    return -1;
  if (gst_pad_link(srcpad, sinkpad) != GST_PAD_LINK_OK)
    return -1;
  gst_object_unref(srcpad);
  gst_object_unref(sinkpad);
  num_sources = 1;
  /* Use nvinfer to infer on batched frame. */
  vw_detection =
      gst_element_factory_make("nvinfer", "primary-nvinference-engine");
  /* Use nvtiler to composite the batched frames into a 2D tiled array based
   * on the source of the frames. */
  tiler = gst_element_factory_make("nvmultistreamtiler", "nvtiler");
  /* Use convertor to convert from NV12 to RGBA as required by nvosd */
  nvvidconv = gst_element_factory_make("nvvideoconvert", "nvvideo-converter");
  /* Create OSD to draw on the converted RGBA buffer */
  nvosd = gst_element_factory_make("nvdsosd", "nv-onscreendisplay");
/* Finally render the osd output */
  if(prop.integrated) {
    sink= gst_element_factory_make ("nv3dsink", "nvvideo-renderer");
  } else {
    sink = gst_element_factory_make ("nveglglessink", "nvvideo-renderer");
  g_object_set (G_OBJECT (sink), "sync", 0, NULL);
  if (!vw_detection)
    return -1;
  if (!sink)
    return -1;
  if (!tiler)
    return -1;
  if (!nvvidconv)
    return -1;
  g_object_set(G_OBJECT(streammux), "width", 4096, "height",
               2160, "batch-size", num_sources,
               "batched-push-timeout", MUXER_BATCH_TIMEOUT_USEC, NULL);
  /* Configure the nvinfer element using the nvinfer config file. */
  g_object_set(G_OBJECT(vw_detection), "config-file-path", CONFIG_FILE_VW,
               NULL);
  /* Override the batch-size set in the config file with the number of sources.
  g_object_get(G_OBJECT(vw_detection), "batch-size", &pgie_batch_size, NULL);
  if (pgie_batch_size != num_sources)
    g_object_set(G_OBJECT(vw_detection), "batch-size", num_sources, NULL);
  tiler_rows = (guint)sqrt(num_sources);
  tiler_columns = (guint)ceil(1.0 * num_sources / tiler_rows);
  /* we set the tiler properties here */
  g_object_set(G_OBJECT(tiler), "rows", tiler_rows, "columns", tiler_columns,
               "width", 4096, "height", 2160,
               NULL);
  /* we add a message handler */
  bus = gst_pipeline_get_bus(GST_PIPELINE(pipeline));
  bus_watch_id = gst_bus_add_watch(bus, bus_call, loop);
  gst_object_unref(bus);
  gst_bin_add_many(GST_BIN(pipeline), nvvidconv ,vw_detection, tiler,
                     nvosd, sink, NULL);
  gst_element_link_many(streammux,nvvidconv, vw_detection,
                               tiler, nvosd, sink, NULL);
  GstPad *vw_sink_pad = gst_element_get_static_pad(vw_detection, "src");
  gst_pad_add_probe(vw_sink_pad, GST_PAD_PROBE_TYPE_BUFFER,
                    tiler_src_pad_buffer_probe, NULL, NULL);
  gst_object_unref(vw_sink_pad);
  gst_element_set_state(pipeline, GST_STATE_PLAYING);
  /* Wait till pipeline encounters an error or EOS */
  g_main_loop_run(loop);
  gst_element_set_state(pipeline, GST_STATE_NULL);
  gst_object_unref(GST_OBJECT(pipeline));
  g_source_remove(bus_watch_id);
  g_main_loop_unref(loop);
  return 0;
is multifilesrc not supported on 6.1 and 6.2? because it is only process one image, then showing the error
multifilesrc is supported in all JetPack versions and DeepStream versions.
Can you provide the JPEG files you used?
Attached sample data.
The nvv4l2decoder failed to decode the pictures.
Can you use nvjpegdec instead? Gst-nvjpegdec — DeepStream 6.2 Release documentation
We will investigate why nvv4l2decoder failed.
Could you please share an example on how to use Gst-nvjpegdec ?
 gst-launch-1.0 filesrc location=1.jpeg ! jpegparse ! nvjpegdec ! nvvideoconvert ! jpegenc ! filesink location=out.jpg
when I tried Nvjpegdec it causes multiple issues, wrong and duplicate result.
Hey Fiona. Chen,
Any news on the decoder issue? We need to run the new version on production ASAP. Let me know if you have any updates.
I can work with nvjpeg on my Jetson board. Can you tell us which Jetson board you are using? What is your JetPack version and DeepStream version?
Jetson-AGX- Jetpack 4.6 [L4T 32.6.1]
Deepstream6.0
same code above with nvjpegdec and multifilesrc, try it with more than 3 images, all three images will have the same output metadata of the last one.
Please upgrade to the latest DeepStream 6.2 GA version.
Same error on ds 6.2.
nvv4l2decoder works also with gst-launch but it shows error on ds 6.2 and 6.1
gst-launch-1.0 multifilesrc location="/opt/nvidia/deepstream/deepstream-6.2/sources/apps/sample_apps/deepstream-image-decode-test/input/img_%04d.jpg" ! jpegparse ! nvv4l2decoder ! nvvideoconvert ! m.sink_0 nvstreammux name=m batch-size=1 width=4096 height=2160 ! nvinfer config-file-path= "/opt/nvidia/deepstream/deepstream-6.2/sources/apps/sample_apps/deepstream-image-decode-test/dstest_image_decode_pgie_config.txt" ! nvvideoconvert ! nvdsosd ! nvegltransform ! nveglglessink
Have you debugged your code? If the gst-launch pipeline can work, you should make sure your code implement the same pipeline and configurations.
Hi Fiona Chen,
The issue has been resolved for Jpegdecoder, but it is not working for Nvv4l2decoder. I am certain that the pipeline and configuration for gst-launch are the same.
Have you tested the pipeline with images using multifilesrc and Nvv4l2decoder on DS6.1 and DS6.2?
Thank you.
We are investigating the Nvv4l2decoder bug, it will be fixed in the future release.
It is the same issue with deepstream 6.3
We do not support progressive JPEG images hardware decoding. You may try to use software jpeg decoders.
