Segfault with MPI_Send + acc_malloc
I’m on a node with two GPUs attached, running with CUDA-enabled MPI (got it from installing the PGI toolkit) , and I bumped into a weird segfault that I managed to pinpoint to the following minimal reproducer:
#include <mpi.h>
#include "openacc.h"
#include <cuda.h>
#include <cuda_runtime.h>
#include "mpi-ext.h" /* Needed for CUDA-aware check */
int main(int argc, char* argv[])
  MPI_Init(&argc, &argv);
  if (1 == MPIX_Query_cuda_support()) {
      printf("This MPI library has CUDA-aware support.\n");
  } else {
      printf("This MPI library does not have CUDA-aware support.\n");
  int rank = -1;
  MPI_Comm_rank(MPI_COMM_WORLD,&rank);
  //printf("rank=%d\n", rank);
  int ngpus = acc_get_num_devices(acc_device_nvidia);
  int devicenum = (rank)%(ngpus);
  //printf("devicenum=%d\n", devicenum);
  acc_set_device_num(devicenum,acc_device_nvidia);
  acc_init(acc_device_nvidia);
  //int buffer[10];
  int *buffer = acc_malloc((size_t)10*sizeof(int));
  for (int i=0; i<10; i++) buffer[i] = i;
  #pragma acc enter data copyin(buffer[:10])
  if (rank == 0) {
    MPI_Send(acc_deviceptr(buffer), 10, MPI_INT, 1, 0, MPI_COMM_WORLD);
  else {
    MPI_Recv(acc_deviceptr(buffer), 10, MPI_INT, 0, 0, MPI_COMM_WORLD, MPI_STATUS_IGNORE);
    #pragma acc update host(buffer[:10])
    printf("rank=1, %d\n", buffer[2]);
  //acc_free(buffer);
  #pragma acc exit data delete(buffer)
  MPI_Finalize();
If I comment out
and replace it with
int buffer[10];
then it works and no segfault is thrown.
Here’s the error trace:
[pgi-nc12-openacc:43092] *** Process received signal ***
[pgi-nc12-openacc:43092] Signal: Segmentation fault (11)
[pgi-nc12-openacc:43092] Signal code: Invalid permissions (2)
[pgi-nc12-openacc:43092] Failing at address: 0x1f03a5a000
[pgi-nc12-openacc:43093] *** Process received signal ***
[pgi-nc12-openacc:43093] Signal: Segmentation fault (11)
[pgi-nc12-openacc:43093] Signal code: Invalid permissions (2)
[pgi-nc12-openacc:43093] Failing at address: 0x1f03a5a000
[pgi-nc12-openacc:43092] [ 0] /lib/x86_64-linux-gnu/libpthread.so.0(+0x12890)[0x7f1056fb0890]
[pgi-nc12-openacc:43092] [ 1] ./mfe[0x401381]
[pgi-nc12-openacc:43092] [ 2] [pgi-nc12-openacc:43093] [ 0] /lib/x86_64-linux-gnu/libpthread.so.0(+0x12890)[0x7f752da52890]
[pgi-nc12-openacc:43093] [ 1] ./mfe[0x401381]
[pgi-nc12-openacc:43093] [ 2] /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xe7)[0x7f752cb64b97]
[pgi-nc12-openacc:43093] /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xe7)[0x7f10560c2b97]
[pgi-nc12-openacc:43092] [ 3] ./mfe[0x4011ea]
[pgi-nc12-openacc:43092] *** End of error message ***
[pgi-nc12-openacc:43093] *** End of error message ***
In particular, see that “Invalid permission”.
Everything is open source and running on a VM , so if at a loss (I am :-) ) I’m willing to give ssh access to the machine and the commands to reproduce.
BTW, I’m using pgcc 19.10
Thanks a lot!
Hi fablup,
“acc_malloc” returns a device pointer so can’t be accessed on the host and why you’re getting a segv. Instead, only use “buffer” on the device. For example:
% cat test_acc_malloc.c
#include <mpi.h>
  } else {
  int rank = -1;
  //int buffer[10];
  #pragma acc parallel loop deviceptr(buffer)
  if (rank == 0) {
  if (rank == 0) {
    MPI_Send(buffer, 10, MPI_INT, 1, 0, MPI_COMM_WORLD);
  else {
    MPI_Recv(buffer, 10, MPI_INT, 0, 0, MPI_COMM_WORLD, MPI_STATUS_IGNORE);
#pragma acc serial deviceptr(buffer)
  acc_free(buffer);
  MPI_Finalize();
% mpicc -ta=tesla -Minfo=accel test_acc_malloc.c
main:
     30, Generating Tesla code
         31, #pragma acc loop gang, vector(10) /* blockIdx.x threadIdx.x */
     40, Accelerator serial kernel generated
% mpirun -np 2 a.out
rank=1, 2
Though the better solution is to use the “host_data” directive to pass the device pointer to the MPI calls. For example:
% cat test_host_data.c
#include <stdlib.h>
#include <mpi.h>
  } else {
  int rank = -1;
  int *buffer = (int *) malloc((size_t)10*sizeof(int));
  if (rank == 0) {
  if (rank == 0) {
#pragma acc host_data use_device(buffer)
  else {
#pragma acc update self(buffer[:10])
  MPI_Finalize();
% mpicc -ta=tesla -Minfo=accel test_host_data.c
main:
     33, Generating enter data copyin(buffer[:10])
     45, Generating update self(buffer[:10])
     49, Generating exit data delete(buffer[:1])
rank=1, 2
Hope his helps,
Mat
Sorry, there was a copy-paste leftover in the original question: I forgot:
  1. to comment the acc_malloc and replace it by un-commenting the line above (int buffer[10] ) and
  2. placing a parloop over the forloop initializing buffer.
    Sorry about that!
Said that, I managed to fix my bug following your guidelines – for me the key was using the deviceptr(buffer) clause. Thanks!
I’m fairly surprised by openacc not behaving without that clause. I’d have expected that entering a parallel region openacc checks each pointer and:
  • it first looks up an internal map to see whether it’s a host pointer, and if so, it returns the corresponding device pointer
  • then, if no entry in the map is available, it checks whether what was provided is actually a device pointer already (all device pointers returned by acc_malloc and siblings should be known right?), and in such a case it proceeds by just using it
I’m fairly confused about this. Could you shed some light on this, or could you point me to some relevant document?
For compiler runtime managed data, i.e. data managed via the data directives or acc_copy API calls, the runtime creates a “present” table which will map the host copy to the device’s mirrored copy.
Device pointers returned by acc_malloc are user managed with no associated host copy so no entry in the present table is made. So by using “acc_malloc” (or cudaMalloc if targeting NVIDIA GPUs), it’s the programmer’s responsibility to manage the data, including informing the compiler that the variable is a device pointer via the “deviceptr” clause.
If you do want the runtime data management, please use the second example I provided.
-Mat
