• Hardware Platform (Jetson / GPU) Jetson
• DeepStream Version 5.0.1
• JetPack Version (valid for Jetson only) 4 .4
• TensorRT Version 7.1.3.0
• CUDA 10.2
Hi all, i am trying to change video frame with:
pad_buffer_probe
However, i am facing log “Segmentation fault (core dumped)” when convert color from bgr to grba. the bellow is my function.
static GstPadProbeReturn
prep_pad_buffer_probe (GstPad * pad, GstPadProbeInfo * info, gpointer u_data)
GstBuffer *buf = (GstBuffer *) info->data;
GstMapInfo in_map_info;
memset (&in_map_info, 0, sizeof (in_map_info));
if (gst_buffer_map (buf, &in_map_info, GST_MAP_READWRITE))
NvBufSurface *surface = (NvBufSurface *) in_map_info.data;
NvDsBatchMeta *batch_meta = gst_buffer_get_nvds_batch_meta (GST_BUFFER (info->data));
NvDsMetaList *l_frame = NULL;
NvDsFrameMeta *frame_meta = NULL;
NvDsMetaList * l_obj = NULL;
NvDsObjectMeta *obj_meta = NULL;
int left, top, width, height;
for (l_frame = batch_meta->frame_meta_list; l_frame != NULL;
l_frame = l_frame->next)
frame_meta = (NvDsFrameMeta *)(l_frame->data);
NvBufSurface *surface_idx;
surface_idx = surface;
surface_idx->surfaceList = &(surface->surfaceList[frame_meta->batch_id]);
surface_idx->numFilled = surface->batchSize = 1;
NvBufSurfTransformRect src_rect, dst_rect;
int batch_size = surface->batchSize;
src_rect.top = 0;
src_rect.left = 0;
src_rect.width = (guint) surface->surfaceList[frame_meta->batch_id].width;
src_rect.height= (guint) surface->surfaceList[frame_meta->batch_id].height;
dst_rect.top = 0;
dst_rect.left = 0;
dst_rect.width = (guint) surface->surfaceList[frame_meta->batch_id].width;
dst_rect.height= (guint) surface->surfaceList[frame_meta->batch_id].height;
NvBufSurfTransformParams nvbufsurface_params;
nvbufsurface_params.src_rect = &src_rect;
nvbufsurface_params.dst_rect = &dst_rect;
nvbufsurface_params.transform_flag = NVBUFSURF_TRANSFORM_CROP_SRC | NVBUFSURF_TRANSFORM_CROP_DST;
nvbufsurface_params.transform_filter = NvBufSurfTransformInter_Default;
NvBufSurfaceCreateParams nvbufsurface_create_params;
nvbufsurface_create_params.gpuId = surface->gpuId;
nvbufsurface_create_params.width = (guint) surface->surfaceList[frame_meta->batch_id].width;
nvbufsurface_create_params.height = (guint) surface->surfaceList[frame_meta->batch_id].height;
nvbufsurface_create_params.size = 0;
nvbufsurface_create_params.colorFormat = NVBUF_COLOR_FORMAT_RGBA;
nvbufsurface_create_params.layout = NVBUF_LAYOUT_PITCH;
#ifdef PLATFORM_TEGRA
nvbufsurface_create_params.memType = NVBUF_MEM_DEFAULT;
#else
nvbufsurface_create_params.memType = NVBUF_MEM_CUDA_UNIFIED;
#endif
if (NvBufSurfaceCreate(&surface, batch_size, &nvbufsurface_create_params) != 0){
g_print ("NvBufSurfaceCreate failed\n");
return GST_PAD_PROBE_DROP;
NvBufSurfaceMemSet(surface, 0, 0, 0);
if (NvBufSurfTransform (surface_idx, surface, &nvbufsurface_params) != NvBufSurfTransformError_Success) {
g_print ("NvBufSurfTransform failed with error while converting buffer\n");
NvBufSurfaceMap(surface, 0, 0, NVBUF_MAP_READ);
NvBufSurfaceSyncForCpu(surface, 0, 0);
cv::Mat in_mat = cv::Mat((guint) surface->surfaceList[frame_meta->batch_id].height,
(guint) surface->surfaceList[frame_meta->batch_id].width,
CV_8UC4,
surface->surfaceList[frame_meta->batch_id].mappedAddr.addr[0],
surface->surfaceList[frame_meta->batch_id].pitch);
cv::Mat bgr_frame;
cv::cvtColor(in_mat, bgr_frame, (int)cv::COLOR_RGBA2BGR);
cv::rectangle(bgr_frame, cv::Point(100, 100), cv::Point(200, 200), cv::Scalar(255,0,255), 2);
cv::cvtColor(bgr_frame, in_mat, (int)cv::COLOR_BGR2RGBA);
/* We need to transform back to original buffer */
// https://forums.developer.nvidia.com/t/dsexample/81896/7
if (NvBufSurfTransform (surface, surface_idx, &nvbufsurface_params) != NvBufSurfTransformError_Success){
NvBufSurfaceSyncForDevice(surface, frame_meta->batch_id, 0);
NvBufSurfaceUnMap(surface, frame_meta->batch_id , 0);
NvBufSurfaceDestroy(surface);
gst_buffer_unmap (buf, &in_map_info);
return GST_PAD_PROBE_OK;
it raise the error at this line " cv::cvtColor(bgr_frame, in_mat, (int)cv::COLOR_BGR2RGBA); "
can you help me to solve my problem? thanks
