• Hardware Platform (Jetson / GPU):jetson orin nano
• DeepStream Version:6.2
my pipeline is nvurisrcbin-->nvstreammux-->nvinfer-->fakesink
GstPadProbeReturn
sink_sink_pad_buffer_probe(GstPad *pad, GstPadProbeInfo *info, gpointer u_data)
GstBuffer *buf = (GstBuffer *)info->data;
NvDsMetaList *l_frame = NULL;
NvDsMetaList *l_obj = NULL;
NvBufSurface *nvbuf_surface = NULL;
GstMapInfo in_map_info;
if (!gst_buffer_map(buf, &in_map_info, GST_MAP_READ))
return GST_PAD_PROBE_DROP;
NvDsBatchMeta *batch_meta = gst_buffer_get_nvds_batch_meta(buf);
nvbuf_surface = (NvBufSurface *)in_map_info.data;
for (l_frame = batch_meta->frame_meta_list; l_frame != NULL; l_frame = l_frame->next)
NvDsFrameMeta *frame_meta = (NvDsFrameMeta *)(l_frame->data);
int frame_index = frame_meta->batch_id;
auto &s = nvbuf_surface->surfaceList[frame_index];
g_printerr("Surface check: index=%d colorFormat=%d layout=%d memType=%d\n",
frame_index,
s.colorFormat,
s.layout,
nvbuf_surface->memType);
safe_encode_to_jpeg(nvbuf_surface, frame_meta->batch_id, "/home/nvidia/code/tgsd_code/test2/frame.jpg")
gst_buffer_unmap(buf, &in_map_info);
return GST_PAD_PROBE_OK;
In the above probe callback function
colorFormat=NVBUF_COLOR_FORMAT_NV12
layout=NVBUF_LAYOUT_PITCH
memType=NVBUF_MEM_SURFACE_ARRAY
When I add the custom function safe_encode_to_jpeg for encoding and saving images (nvbuf_Surface, frame_ceta ->batch_id, “/home/Nvidia/code/tgsd_comde/test2/frame. jpg”)
Specific Function Implementation:
static std::unique_ptr<NvJPEGEncoder> jpegEnc = nullptr;
bool
safe_encode_to_jpeg(NvBufSurface *surface, int frame_index, const std::string &filename)
if (!surface)
std::cerr << "❌ surface is null." << std::endl;
return false;
NvBufSurface *converted = nullptr;
NvBufSurfaceCreateParams params;
memset(¶ms, 0, sizeof(params));
params.gpuId = surface->gpuId;
params.width = surface->surfaceList[frame_index].width;
params.height = surface->surfaceList[frame_index].height;
params.layout = NVBUF_LAYOUT_PITCH;
params.colorFormat = NVBUF_COLOR_FORMAT_NV12;
params.memType = NVBUF_MEM_SURFACE_ARRAY;
if (NvBufSurfaceCreate(&converted, 1, ¶ms) != 0)
std::cerr << "❌ Failed to create converted surface." << std::endl;
return false;
NvBufSurfTransformParams trans_params;
memset(&trans_params, 0, sizeof(trans_params));
trans_params.transform_flag = NVBUFSURF_TRANSFORM_FILTER;
trans_params.transform_filter = NvBufSurfTransformInter_Default;
NvBufSurfTransformConfigParams config_params;
memset(&config_params, 0, sizeof(config_params));
config_params.compute_mode = NvBufSurfTransformCompute_Default;
config_params.gpu_id = surface->gpuId;
NvBufSurfTransformSetSessionParams(&config_params);
if (NvBufSurfTransform(surface, converted, &trans_params) != 0)
std::cerr << "❌ Transform failed." << std::endl;
NvBufSurfaceDestroy(converted);
return false;
cudaDeviceSynchronize();
if (!jpegEnc)
jpegEnc.reset(NvJPEGEncoder::createJPEGEncoder("jpegenc"));
if (!jpegEnc)
std::cerr << "❌ Failed to create NvJPEGEncoder." << std::endl;
return false;
unsigned char *jpeg_buf = nullptr;
unsigned long jpeg_size = 0;
int fd = converted->surfaceList[0].bufferDesc;
if (jpegEnc->encodeFromFd(fd, JCS_YCbCr, &jpeg_buf, jpeg_size, 80) != 0 || !jpeg_buf)
std::cerr << "❌ JPEG encode failed." << std::endl;
return false;
std::ofstream ofs(filename, std::ios::binary);
ofs.write(reinterpret_cast<const char *>(jpeg_buf), jpeg_size);
ofs.close();
std::cout << "✅ JPEG saved: " << filename << std::endl;
return true;
But in jpegEnc ->encodeFromFd (fd, JCS-YCbCr,&jpegobuf, jpeg_stize, 80)= 0 core crashes occur
I don’t know where the problem lies
