I have a simple kmeans application. When I compile I get the following information.
[boz283@honest2 ~/kmeans-pgi]$ make seq
pgcc -ta=nvidia -Minfo -g -c seq_kmeans.c
seq_kmeans:
104, Memory set idiom, loop replaced by call to __c_mset4
119, Generating copyin(clusters[0:numClusters-1][0:numCoords-1])
Generating copyin(objects[numObjs][numCoords])
Generating compute capability 1.3 kernel
120, Loop carried scalar dependence for 'delta' at line 139
Scalar last value needed after loop for 'delta' at line 166
Accelerator restriction: scalar variable live-out from loop: delta
Sequential loop scheduled on host
128, Loop carried scalar dependence for 'min_dist' at line 132
Scalar last value needed after loop for 'index' at line 139
Scalar last value needed after loop for 'index' at line 142
Accelerator restriction: scalar variable live-out from loop: index
130, Loop is parallelizable
Accelerator kernel generated
130, #pragma acc for parallel, vector(256)
131, Sum reduction generated for dist
157, Invariant if transformation
158, Invariant if transformation
pgcc -ta=nvidia -Minfo -g -o seq_main seq_main.o seq_kmeans.o file_io.o wtime.o
When I run the application I get segmentation fault. I used gdb to check where the error occurs. And somehow the host pointer for my host data gets to be 0x0, and then it causes the seqmentation fault. The gdb code is below
[boz283@abe1201 ~/kmeans-pgi]$ gdb ./seq_main
GNU gdb Red Hat Linux (6.3.0.0-1.132.EL4rh)
Copyright 2004 Free Software Foundation, Inc.
GDB is free software, covered by the GNU General Public License, and you are
welcome to change it and/or distribute copies of it under certain conditions.
Type "show copying" to see the conditions.
There is absolutely no warranty for GDB. Type "show warranty" for details.
This GDB was configured as "x86_64-redhat-linux-gnu"...Using host libthread_db library "/usr/local/lib64/tls/libthread_db.so.1".
(gdb) run -i out20 -b -n 20 -o -d
Starting program: /u/ac/boz283/kmeans-pgi/seq_main -i out20 -b -n 20 -o -d
File out20 numObjs = 1000000
File out20 numCoords = 20
[Thread debugging using libthread_db enabled]
[New Thread 46912502230752 (LWP 27777)]
Program received signal SIGSEGV, Segmentation fault.
[Switching to Thread 46912502230752 (LWP 27777)]
0x00002aaaaaebbf30 in memcpy () from /usr/local/lib64/tls/libc.so.6
(gdb) where
#0 0x00002aaaaaebbf30 in memcpy () from /usr/local/lib64/tls/libc.so.6
#1 0x00002aaab09fc0fb in ?? () from /usr/lib64/libcuda.so
#2 0x00002aaab09d72d9 in ?? () from /usr/lib64/libcuda.so
#3 0x00002aaab09d762f in ?? () from /usr/lib64/libcuda.so
#4 0x00002aaab09c792f in ?? () from /usr/lib64/libcuda.so
#5 0x00002aaab0a5a2c5 in ?? () from /usr/lib64/libcuda.so
#6 0x0000000000407c70 in __pgi_cu_upload1_p (devptr=1115904, hostptr=0x0, devx=0,
hostx=1000020, size=1, hoststride=1, elementsize=4, lineno=119,
name=0x409fe9 "objects") at ../src/nvupload1.c:48
#7 0x0000000000407f33 in __pgi_cu_upload2_p (devptr=1115904, hostptr=0x0, devx=0,
devy=0, hostx=20, hosty=1000000, size1=1, size2=1, devstride2=1, hoststride1=1,
hoststride2=1, elementsize=4, lineno=119, name=0x409fe9 "objects")
at ../src/nvupload2.c:51
#8 0x0000000000405b48 in __pgi_cu_uploadpx (devptr=1115904, hostptr=0x2aaaab081010,
dims=2, desc=0x7fffffffcda0, elementsize=4, lineno=119, name=0x409fe9 "objects")
at ../src/nvuploadp.c:79
#9 0x00000000004063bb in __pgi_cu_uploadp_p (devptr=1115904, hostptr=0x2aaaab081010,
at ../src/nvuploadp.c:213
#10 0x0000000000402036 in seq_kmeans (objects=0x2aaaab081010, numCoords=20,
numObjs=1000000, numClusters=20, threshold=0.00100000005, membership=0x2aaab046f010)
at ./seq_kmeans.c:117
#11 0x0000000000401abc in main (argc=8, argv=0x7fffffffd008) at ./seq_main.c:106
(gdb) quit
My input dataset is 1million records, with each record consisting of 20 dimensions of floats.
Berkin
