Segmentation fault when creating PuschRx instance in PyAerial
I’m testing PUSCH channel decoding on Aerial Data Lake data. (with this documentation: Using pyAerial for PUSCH decoding on Aerial Data Lake data — Aerial CUDA-Accelerated RAN)
When attempting to create a PuschRx instance in PyAerial, the Python process immediately terminates with a segmentation fault.
setup details: GH200, with driver version 575.57.08, cuda version 12.9
minimum reproducible code
from aerial.phy5g.pusch import PuschRx
from aerial.phy5g.config import PuschLdpcKernelLaunch
pusch_rx = PuschRx(
    cell_id=0,
    num_rx_ant=4,
    num_tx_ant=4,
    enable_pusch_tdi=False,
    eq_coeff_algo=0,
    ldpc_kernel_launch=PuschLdpcKernelLaunch.PUSCH_RX_LDPC_STREAM_SEQUENTIAL,
Any guidance would be very helpful.
Thank you in advance!
Thanks for finding this bug in the current version, we will resolve this in the next release.
In the meantime, can you please use eq_coeff_algo >= 1
