I have this model that I am running some sample batches from the MNIST fashion dataset
import torchvision
import torchvision.transforms as transforms
import torch
import matplotlib.pyplot as plt
import numpy as np
import torch.nn as nn
import torch.nn.functional as F
import torch.optim as optim
trainset = torchvision.datasets.FashionMNIST(root = "./data", train = True, download = True, transform = transforms.ToTensor())
testset = torchvision.datasets.FashionMNIST(root = "./data", train = False, download = True, transform = transforms.ToTensor())
trainloader = torch.utils.data.DataLoader(trainset, batch_size = 8, shuffle = True)
testloader = torch.utils.data.DataLoader(testset, batch_size= 8, shuffle = False)
device = torch.device("cuda:0")
print(device)
class vgg16(nn.Module):
def __init__(self):
super(vgg16, self).__init__()
## note that vgg always does same padding on convolutions
## dec img size by pooling and inc channels using kernels
self.cnn_block = nn.Sequential(
nn.Conv2d(1, 64, 3, padding = 1),
nn.ReLU(),
nn.Conv2d(64, 64, 3, padding = 1),
nn.ReLU(),
nn.MaxPool2d(2, 2),
nn.Conv2d(64, 256, 3, padding = 1),
nn.ReLU(),
nn.Conv2d(256, 256, 3, padding = 1),
nn.ReLU(),
nn.MaxPool2d(2, 2),
nn.Conv2d(256, 512, 3, padding = 1),
nn.ReLU(),
nn.Conv2d(512, 512, 3, padding = 1),
nn.ReLU(),
nn.ReLU(),
nn.MaxPool2d(2, 1)
# out = 6x6 img
self.fc_block = nn.Sequential(
# 6x6x512 = 18432
nn.Linear(18432, 4096),
nn.ReLU(),
nn.Linear(4096, 1024),
nn.ReLU(),
nn.Linear(1024, 256),
nn.ReLU(),
nn.Linear(256, 64),
nn.ReLU(),
nn.Linear(64, 10),
# nn.Softmax(dim = 1)
def forward(self, x):
x = self.cnn_block(x)
x = x.view(x.size(0), -1)
x = self.fc_block(x)
return x
I seem to be getting a Segmentation fault after completing one forward propagation. The program is able to do many forward propagation successfully but when it is done i get the segmentation fault. Also I do not have this problem when i set the device to “cpu”. This error only occurs when i set the device to “cuda:0” and it is the only error i get after successfully completing forward prop
Here is the snippet for the forward prop (doing it twice):
net = vgg16().to(device)
loss_func = nn.CrossEntropyLoss()
opt = optim.Adam(net.parameters(), lr = 0.0001)
dat = iter(testloader).__next__()[0].to(device)
print(dat.size())
out = net(dat)
print(out)
print(dat.size())
out = net(dat)
print(out)
- Python 3.6
- PyTorch 1.6
- L4T 32.4.3
- JetPack 4.4
- CUDA: 10.2.89
- cuDNN: 8.0.0.180
Can anybody point out whats wrong? Thanks so much!
