I just got the Xavier NX and installed with Jetpack 4.4.
I copied and ran my yolov3 project on NX, but I got a segmentation fault.
The project was pre-trained on a Linux PC and could run perfectly with 0.2s inference time.
Following is what I got.
$ ./yolov3_detect.py
Inference Time: 0:00:03.272489
$ gbd python3
(gdb) run yolov3_detect.py
Starting program: /usr/bin/python3 yolov3_detect.py
[Thread debugging using libthread_db enabled]
Using host libthread_db library "/lib/aarch64-linux-gnu/libthread_db.so.1".
[New Thread 0x7f6171c1f0 (LWP 9075)]
[New Thread 0x7f60f1b1f0 (LWP 9076)]
[New Thread 0x7f5f71a1f0 (LWP 9077)]
[New Thread 0x7f5cf191f0 (LWP 9078)]
[New Thread 0x7f5b7181f0 (LWP 9079)]
[New Thread 0x7f3b40a1f0 (LWP 9080)]
[New Thread 0x7f3ac091f0 (LWP 9081)]
[New Thread 0x7f3a4081f0 (LWP 9082)]
[New Thread 0x7f39c071f0 (LWP 9083)]
[New Thread 0x7f394061f0 (LWP 9084)]
[New Thread 0x7f42e551f0 (LWP 9085)]
Inference Time: 0:00:03.155869
Thread 1 "python3" received signal SIGSEGV, Segmentation fault.
0x0000007f19e1e280 in ?? ()
from /usr/lib/aarch64-linux-gnu/libcudnn_ops_infer.so.8
(gdb) bt
#0 0x0000007f19e1e280 in ?? ()
#1 0x0000007f19e3b8f0 in ?? ()
Backtrace stopped: not enough registers or memory available to unwind further
It runs much slower and shows a segmentation fault.
Jetpack: 4.4
pytorch: v1.1.0 (for python 3.6)
cuda: 10.2
cudnn: 8.0
How to solve this issue?
Thank you!
