I am encountering a problem on my NVIDIA Jetson Xavier NX when running a Python code that utilizes the Sentence Transformer library to do sentence encodings. The code works fine on Intel-based architectures like laptops, but I’m facing a “Segmentation fault (core dumped)” error on my Jetson Xavier NX.
I’ve tried different Sentence Transformer models, and the issue persists. I suspect it might be related to memory allocation or compatibility with the ARM architecture of the Jetson Xavier NX.
Here are my questions:
- How can I adjust memory allocation or flags to ensure that my code has enough resources to run on the Jetson Xavier NX?
- Are there any known compatibility issues between SentenceTransformer and AutoModel on ARM devices?
- How can I access more detailed debugging information to pinpoint the cause of the segmentation fault?, Tried
NCCL_DEBUG=INFOnothing prints on terminal.
I appreciate any insights or suggestions to help resolve this issue. Thank you for your assistance!
