My code never reported an error in 3090, but it often did in 4090 “segmentation fault core dumped”. Why? How do I fix it?
Hi @2651449412 ,
This might be a hardware issue.
please check the compatibility matrix of TRT and you can raise the concern to get better support on respective Forum
Related topics
| Segmentation fault (core dumped) error on Jetson Nano | 9 | 3153 | October 14, 2021 | |
| Segmentation Fault (core dumped)” error in the Jetson Nano 2GB | 4 | 1619 | March 7, 2023 | |
| Segmentation fault (core dumped) jetson nano | 3 | 2505 | April 12, 2021 | |
| Issue with TensorRT on Jetson Nano After Extended Use | 2 | 220 | June 25, 2024 | |
| Segmentation Fault (core dumped) occurs when YOLOX is converted to TensorRT | 6 | 3556 | April 4, 2022 | |
| Aborted core dumped error! When running TensorRT code on Jetson Nano 2GB | 4 | 1682 | October 15, 2021 | |
| core dumped | 2 | 862 | October 18, 2021 | |
| Segmentation fault (core dumped) in deit-base-distilled-patch16-224 model | 1 | 491 | September 4, 2023 | |
| Segmentation Fault in Jetson Nano while using Python3 | 4 | 4292 | March 24, 2022 | |
| Segmentation fault (core dumped) | 0 | 881 | April 24, 2019 |
