While running ssd inception v2 coco model over a video with tensorrt engine, after running for 2 mins the process got stopped with Segmentation fault (core dumped) error on Jetson Nano
[TensorRT] INFO: Glob Size is 50485364 bytes.
[TensorRT] INFO: Added linear block of size 4292096
[TensorRT] INFO: Added linear block of size 1522176
[TensorRT] INFO: Added linear block of size 739328
[TensorRT] INFO: Added linear block of size 411648
[TensorRT] INFO: Added linear block of size 204800
[TensorRT] INFO: Added linear block of size 57344
[TensorRT] INFO: Added linear block of size 30720
[TensorRT] INFO: Added linear block of size 20992
[TensorRT] INFO: Added linear block of size 9728
[TensorRT] INFO: Added linear block of size 9216
[TensorRT] INFO: Added linear block of size 2560
[TensorRT] INFO: Added linear block of size 1024
[TensorRT] INFO: Added linear block of size 512
[TensorRT] INFO: Found Creator FlattenConcat_TRT
[TensorRT] INFO: Found Creator GridAnchor_TRT
[TensorRT] INFO: Found Creator NMS_TRT
[TensorRT] INFO: Deserialize required 3084695 microseconds.
Gtk-Message: 11:48:55.371: Failed to load module "canberra-gtk-module"
No, it’s not a jetson_inference, rather I have converted my custom ssd inception v2 coco model to tensorrt engine. I was working fine but crashed all of a sudden after 3 mins with that error.
Could you help to provide a simple reproducible source for us debugging?
Or could you try if this issue can be reproduced with our official sample?
Ex. /usr/src/tensorrt/samples/sampleUffSSD
Usually, this should be related to the data source type you use.
Do you run the inference code with live stream or camera?
i meet the same issue. error info is :
[TensorRT] ERROR: UffParser: Validator error: truediv_14/Cast: Unsupported operation _Cast
[TensorRT] ERROR: Network must have at least one output
I trained a yolo3 model with TF 1.15.0, and then convert it to uff. convertion log is below:
Loading output_frozen_model2.pb
NOTE: UFF has been tested with TensorFlow 1.12.0. Other versions are not guaranteed to work
WARNING: The version of TensorFlow installed on this system is not guaranteed to work with UFF.
UFF Version 0.6.3
=== Automatically deduced input nodes ===
[name: “input”
op: “Placeholder”
attr {
key: “dtype”
value {
type: DT_FLOAT
attr {
key: “shape”
value {
shape {
dim {
dim {
dim {
dim {
I also traind a yolov3 with pytorch. also meet the same error Segmentation fault (core dumped). sample is as below.
def ONNX_build_engine(onnx_file_path):
G_LOGGER = trt.Logger(trt.Logger.WARNING)
EXPLICIT_BATCH = 1 << (int)(trt.NetworkDefinitionCreationFlag.EXPLICIT_BATCH)
with trt.Builder(G_LOGGER) as builder, builder.create_network(EXPLICIT_BATCH) as network, trt.OnnxParser(network, G_LOGGER) as parser:
print('1.1--Loading ONNX file from path {}...'.format(onnx_file_path))
with open(onnx_file_path, 'rb') as model:
print('1.2--Parsing ONNX model')
parser.parse(model.read())
builder.max_batch_size = 100
builder.max_workspace_size = 1 << 30
print('1.3--Completed parsing of ONNX model')
with trt.Builder(TRT_LOGGER) as builder, builder.create_builder_config() as config, builder.build_cuda_engine(network, config) as engine:
print('1.4--Building an engine from file {}; this may take a while...'.format(onnx_file_path))
serialized_engine = engine.serialize()
with trt.Runtime(TRT_LOGGER) as runtime:
runtime.deserialize_cuda_engine(serialized_engine)
print("1.5--Completed creating Engine")
Yup, got it running. Earlier I was using another module along with it, it might be that module was creating the issue, running this object detection task only worked for me. Thanks for the response @AastaLLL and @kayccc
