Request solution for the “Segmentation Fault (core dumped)” error in the Jetson Nano 2GB while predicting through TensorRT model?
I successfully converted my TF native FP32 (mymodel.h5, Size = 17.0 Mb)) model to a TF-TRT FP32 model. Now I have an output directory named mymodel_saved_model_TFTRT_FP32 folder, which has assets, variables, and saved_model.pb files. While using the mymodel_saved_model_TFTRT_FP32 for the prediction, I used a couple of utility functions mentioned below. During the execution of the python3 script, I got this error " Segmentation fault (core dumped). Also, it shows the linked TenosrRT version: 8.0.1 & Loaded TensorRT version: 8.2.1. But at the time of TF native FP32 to TF-TRT FP32 model, I did not received any TensorRT version information. Below, I have attached screenshots showing error file and memory usage.
I did some research on this and found it may be caused by Nano 2GB board RAM or TensorRT version mismatch, but not fully sure about this.
I followed this ipynb file and stuck at cell no. [17], before this, everything has done successfully.
Environment:
Jetson Nano 2GB board
jetson-nano-jp461-sd-card-image
Architecture: arm64
Python3
TensorRT: 8.2.1
Tensorflow: 2.6.2 + nv21.12
ubuntu: 18.04
Cuda: 10.2
def predict_tftrt(input_saved_model):
“”“Runs prediction on a single image and shows the result.
input_saved_model (string): Name of the input model stored in the current dir
img_path = ‘./data/img0.JPG’ # Siberian_husky
img = image.load_img(img_path, target_size=(224, 224))
x = image.img_to_array(img)
x = np.expand_dims(x, axis=0)
x = preprocess_input(x)
x = tf.constant(x)
saved_model_loaded = tf.saved_model.load(input_saved_model, tags=[tag_constants.SERVING])
signature_keys = list(saved_model_loaded.signatures.keys())
print(signature_keys)
infer = saved_model_loaded.signatures['serving_default']
print(infer.structured_outputs)
labeling = infer(x)
preds = labeling['predictions'].numpy()
print('{} - Predicted: {}'.format(img_path, decode_predictions(preds, top=3)[0]))
plt.subplot(2,2,1)
plt.imshow(img);
plt.axis('off');
plt.title(decode_predictions(preds, top=3)[0][0][1])
def benchmark_tftrt(input_saved_model):
infer = saved_model_loaded.signatures[‘serving_default’]
N_warmup_run = 50
N_run = 1000
elapsed_time = []
for i in range(N_warmup_run):
labeling = infer(batched_input)
for i in range(N_run):
start_time = time.time()
end_time = time.time()
elapsed_time = np.append(elapsed_time, end_time - start_time)
if i % 50 == 0:
print('Step {}: {:4.1f}ms'.format(i, (elapsed_time[-50:].mean()) * 1000))
print('Throughput: {:.0f} images/s'.format(N_run * batch_size / elapsed_time.sum()))
predict_tftrt(‘resnet50_saved_model_TFTRT_FP32’)
I request you to kindly help me in resolving the issue.
Thanking You
