When I run this script, I get an error. Here is my error
2021-08-25 20:48:10.964086: W tensorflow/stream_executor/platform/default/dso_loader.cc:60] Could not load dynamic library ‘libnvinfer.so.7’; dlerror: libnvinfer.so.7: cannot open shared object file: No such file or directory
2021-08-25 20:48:10.964404: W tensorflow/stream_executor/platform/default/dso_loader.cc:60] Could not load dynamic library ‘libnvinfer_plugin.so.7’; dlerror: libnvinfer_plugin.so.7: cannot open shared object file: No such file or directory
2021-08-25 20:48:10.964447: W tensorflow/compiler/tf2tensorrt/utils/py_utils.cc:30] Cannot dlopen some TensorRT libraries. If you would like to use Nvidia GPU with TensorRT, please make sure the missing libraries mentioned above are installed properly.
2021-08-25 20:48:10.967269: W tensorflow/stream_executor/platform/default/dso_loader.cc:60] Could not load dynamic library ‘libnvinfer.so.7’; dlerror: libnvinfer.so.7: cannot open shared object file: No such file or directory
2021-08-25 20:48:10.967326: F tensorflow/compiler/tf2tensorrt/stub/nvinfer_stub.cc:49] getInferLibVersion symbol not found.
Aborted (core dumped)
How can I convert my .pb tensorflow model to TensorRT model?
Tensorflow model is trained deeplab segmentation model.
My jetson nano is Jetpack 4.6, TensorRT version is 8.0.1 and cuda10.2.
Environment
TensorRT Version: 8.0.1 GPU Type: 128-core Maxwell Nvidia Driver Version: CUDA Version: 10.2 CUDNN Version: cuDNN 8.2.1 Operating System + Version: Jetpack 4.6 Python Version (if applicable): 3.6 TensorFlow Version (if applicable): 1.15 PyTorch Version (if applicable): Baremetal or Container (if container which image + tag):
Relevant Files
Please attach or include links to any models, data, files, or scripts necessary to reproduce your issue. (Github repo, Google Drive, Dropbox, etc.)
