im using PyTorch v1.10.0 on my jetson nano. I have installed jetpack v4.6.4 on it.It shows the following error when diagnosed with faulthandler.
Please suggest a fix
JetPack 4.6.4?
Would you check your L4T version?
cat /etc/nv_tegra_release
Does python importing work without faulthandler?
I’m sorry it’s v4.63.
No importing torch shows segmentation fault (core dumped) error
You did follow this link to install Pytorch:
I was following these instructions. I hit the error on verification stage.
By some reasons, library dependencies have some issues I think,
In this case, starting from the bottom might be easy than resolving these problems.
