I was using C++ api to serialize and deserialize tensorrt model from file. However, segmentation fault happens when I call deserializeCudaEngine. Here is my code .
// for serializing
std::ofstream trt_file(trt_model_path, std::ios::binary);
auto *serialized_model = this->engine_->serialize();
if(serialized_model == nullptr) {
std::cout<< "could not serialize engine." << std::endl;
trt_file.write(reinterpret_cast<const char*>(serialized_model->data()), serialized_model->size());
trt_file.close();
// for deserializing
std::vector<char> trt_model_stream;
std::size_t size{0};
std::ifstream in_file(trt_file, std::ios::binary);
if(in_file.good())
in_file.seekg(0, in_file.end);
size = in_file.tellg();
in_file.seekg(0, in_file.beg);
trt_model_stream.resize(size);
in_file.read(trt_model_stream.data(), size);
in_file.close();
nvinfer1::IRuntime *runtime = nvinfer1::createInferRuntime(*logger);
nvinfer1::ICudaEngine *engine =runtime->deserializeCudaEngine(trt_model_stream.data(), size, nullptr);
runtime->destroy();
I can serialize the cudaEngine successfully. However, I’ll get segmentation fault when calling deserializeCudaEngine api. I even printed the values in serialized_model->data() and trt_model_stream.data(). They are exactly the same.
I don’t know where can generate the trouble. Thanks in advance.
