I already have a custom engine that I create from an ONNX file in python 3.5. The inference and saving the model runs without a problem. However, when I want to load the engine a “Segmentation fault (core dumped)” occurs. The error occurs in the function “deserialize_cuda_engine”
I am using the DGX station. I use the docker of TensorRT: 18.12-py3
I use the code from the developper guide
with open(“sample.engine”, “wb”) as f:
f.write(engine.serialize())
with open(“sample.engine”, “rb”) as f, trt.Runtime(TRT_LOGGER) as runtime:
engine = runtime.deserialize_cuda_engine(f.read())
