Description
I’m trying to run a simple inference example using a TRT engine that has been converted on the same machine. Since the PyTorch NGC image doesn’t ship with PyCUDA, I installed it with pip install pycuda
. I used the example from the quick guide with the following code:
import numpy as np
import tensorrt as trt
import pycuda.driver as cuda
import pycuda.autoinit
dev = cuda.Device(0)
ctx = dev.make_context()
try:
TRT_LOGGER = trt.Logger(trt.Logger.INFO)
with open("ResNet18Dense.trt", 'rb') as f, trt.Runtime(TRT_LOGGER) as runtime:
engine = runtime.deserialize_cuda_engine(f.read())
except:
print("Not working")
And the code fails with the following:
[TensorRT] INFO: [MemUsageChange] Init CUDA: CPU +151, GPU +0, now: CPU 175, GPU 359 (MiB)
[TensorRT] INFO: Loaded engine size: 135 MB
[TensorRT] INFO: [MemUsageSnapshot] deserializeCudaEngine begin: CPU 311 MiB, GPU 359 MiB
[TensorRT] INFO: [MemUsageChange] Init cuBLAS/cuBLASLt: CPU +243, GPU +100, now: CPU 554, GPU 595 (MiB)
[TensorRT] INFO: [MemUsageChange] Init cuDNN: CPU +245, GPU +102, now: CPU 799, GPU 697 (MiB)
[TensorRT] INFO: [MemUsageChange] Init cuBLAS/cuBLASLt: CPU +0, GPU +0, now: CPU 799, GPU 679 (MiB)
[TensorRT] INFO: [MemUsageSnapshot] deserializeCudaEngine end: CPU 799 MiB, GPU 679 MiB
[TensorRT] INTERNAL ERROR: [defaultAllocator.cpp::free::85] Error Code 1: Cuda Runtime (invalid argument)
[TensorRT] INTERNAL ERROR: [resources.h::operator()::445] Error Code 1: Cuda Driver (invalid device context)
Bus error (core dumped)
Running the code without dev = cuda.Device(0) ctx = dev.make_context()
goes to the error message right away without even getting the INFO logs out.
My guess is that the Cuda runtime/driver is not being initialised correctly, but I found precious little information on what the errors mean here. Any help would be much appreciated.
Environment
TensorRT Version : 8.0.1.6
GPU Type : NVIDIA GTX 1080 Ti x 2
Nvidia Driver Version : Host machine has 470.57.02
CUDA Version : 11.4.1
CUDNN Version : 8.2.2.26
Operating System + Version : Ubuntu 20.04
Python Version (if applicable) : 3.8
TensorFlow Version (if applicable) : N/A
PyTorch Version (if applicable) : 1.10.0a0+3fd9dcf
Baremetal or Container (if container which image + tag) : nvcr.io/nvidia/pytorch:21.08-py3
Relevant Files
The trt engine: https://get.station307.com/QgvvHqXEB42/ResNet18Dense.trt
The original ONNX file: https://get.station307.com/LdcEWrk4oe1/model-ResNet18Dense-10-AffSynth12_ONNX.onnx
Steps To Reproduce
- Convert the onnx file to TRT using
trtexec --onnx=model-ResNet18Dense-10-AffSynth12_ONNX.onnx --saveEngine=ResNet18Dense.trt --explicitBatch
- Run the code described above
